balljoint Samba Member
Posted: Mon Oct 15, 2018 1:23 pm Post subject: oil cooler adapter leak thru stud |
So I bought a new aftermarket cooler and adapter to replace a old style cooler that somehow ended up on my 1600 case.
Put it on using 4 red seals and of course had a leak from between the adapter and case and a new one I've never heard of before ie from the lower stud itself that bolts the cooler to the adapter!
I can see what looks like a pin hole from the oil gallery of the adapter that is close to the threaded hole that holds this lower stud so maybe the oil is getting through there and being pushed out through the threading and out along the stud.
Anyway never seen this mentioned before so just giving you guys a heads up of yet another inferior part and possible source of leak to look out for.
What do you suggest..... an oem adapter? or is there a quality one available instead one of those run of the mill Chinese crap I have now? |
74 Thing Samba Member
Posted: Mon Oct 15, 2018 2:02 pm Post subject: Re: oil cooler adapter leak thru stud |
Can you post a photo of yours?
If you look in the classified Berg has used/cleaned orig dog house adapters for $20 |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4848 Location: sanger ca
Posted: Mon Oct 15, 2018 2:08 pm Post subject: Re: oil cooler adapter leak thru stud |
Almost every aftermarket adaptor does that, very crappy part. Just had one last week. You will see some of them filled with epoxy in the hole on the bottom to try and fix this. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Oct 15, 2018 2:11 pm Post subject: Re: oil cooler adapter leak thru stud |
balljoint wrote: |
Crazy!! Out of the thousands that I have used over the years, I have never had one like that......until last month. I couldn't believe what I was seeing. So yeah, you're not crazy. I buy them from a couple different places so I wasn't sure if it was a bad batch or what. I've used 10 since then without a problem. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Oct 15, 2018 9:10 pm Post subject: Re: oil cooler adapter leak thru stud |
I could not find the Berg ones. Here is a clean used original one...https://www.thesamba.com/vw/classifieds/detail.php?id=1230148
Better than having to clean it yourself! |
Posted: Tue Oct 16, 2018 5:34 pm Post subject: Re: oil cooler adapter leak thru stud |
Yeah...I got one of the berg ones
Thanks |
