Oil Pump Housing Question
Forane
Forane is offline
PostPosted: Fri Oct 12, 2018 3:32 pm    Post subject: Oil Pump Housing Question Reply with quote
Hello,
My oil pump housing on the third piece of my early 1957 356A T1 Normal is toast. Does anyone know which VW housing fits?
Thanks in advance.
J
badsix
badsix is offline
PostPosted: Sun Oct 14, 2018 8:36 pm    Post subject: Re: Oil Pump Housing Question Reply with quote
I don't any VW will fit, you'll need a Porsche 3rd piece case part. I would check and see if the later style with the larger oil pump will fit. I know they fit 58 A as mine has one. your cover is different with that seal arrangement
Jay D.
Forane
Forane is offline
PostPosted: Mon Oct 15, 2018 5:47 am    Post subject: Re: Oil Pump Housing Question Reply with quote
Thanks Badsix.
I am starting to believe that the VW oil pump housing fitting a Porsche 3rd piece may be urban legend.
J
MoPor
MoPor is offline
PostPosted: Wed Oct 17, 2018 11:03 am    Post subject: Re: Oil Pump Housing Question Reply with quote
I'm confused. If you had a third piece with the separate oil housing you might wonder if a VW housing will fit. The one in the pic looks like the typical integral oil pump which are all Porsche items.
Matt
'58 356A coupe
'00 Boxster S
