Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sun Sep 30, 2018 6:18 pm Post subject: Re: Stock Engine eating cam gears |
I have a variety in sizes of shims, along with a few .24mm/.010 shims and none go that thin. I'm leaning towards taking the flywheel to a machine shop and having them shave .005 off to give me wiggle room for clearance, then if need be I can always add thicker shims to get to where I want to be. |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Sun Sep 30, 2018 6:22 pm Post subject: Re: Stock Engine eating cam gears |
Two shims is ok.
You should not check the end play on an assembled engine with no shims, there is no way to know if the flywheel is touching the bearing, OR if some other part has hit first. |
Posted: Sun Sep 30, 2018 7:59 pm Post subject: Re: Stock Engine eating cam gears |
modok wrote: |
Two shims is ok.
I tried it with the 3 shims and it wouldn't budge. I felt no movement at all, so then I decided to try with no shims and attached the dial indicator to get an exact measurement so I would have an idea of end play. I even measured end play without the flywheel on and it was the same. I don't have the pistons on yet so it's easy to push the crank back and forth. I remember a topic about going with 2 shims and the consensus seemed to be a bad idea that the 3 shims were needed for the specific reason that 3 shims create less friction then 2. If I was certain that 2 shims would work and not cause me any more headaches then what this engine has already given me, I would go with 2 shims in a heartbeat. |
Zundfolge1432 Samba Member
Posted: Sun Sep 30, 2018 8:10 pm Post subject: Re: Stock Engine eating cam gears |
I hate to say it but this is another one of those things that can be figured before the case gets closed up. But since you are beyond that point your idea of taking some off the flywheel would work. Not sure about using 2 shims never had to do that. I suspect bearing is made a little too thick causing loss of clearance. |
Posted: Sun Sep 30, 2018 8:22 pm Post subject: Re: Stock Engine eating cam gears |
Zundfolge1432 wrote: |
I just figured it's the same case, flywheel & crank so the same 3 shims that measured .030 SHOULD work. It does sound like the thrust bearing is on thicker side which would prevent proper endplay. |
modok Samba Member
Posted: Sun Sep 30, 2018 9:59 pm Post subject: Re: Stock Engine eating cam gears |
It is less confusing to set the end play before assembling the engine.
To check the end play with the engine assembled, used two thin shims, because the crankshaft clearance without the flywheel may be as low as .020
Will two shims work ok? yes.
Consensus?
I don't worry about that. |
Posted: Wed Oct 17, 2018 6:34 am Post subject: Re: Stock Engine eating cam gears |
Did the 20 minute break-in on Sunday, then did a 6-7 mile drive yesterday and all seems well so far. Going to change the oil, and check the valves and I'll give it a go from there. |
Posted: Wed Oct 17, 2018 8:34 am Post subject: Re: Stock Engine eating cam gears |
Thanks for the update! Will keep fingers crossed.... _________________ In Stereo, Where Available! |
Posted: Wed Oct 17, 2018 12:10 pm Post subject: Re: Stock Engine eating cam gears |
Changed the oil and.....more aluminum. I flushed everything real well before putting it back together. I can only hope it's residual and/or normal wear of things breaking in. The oil was much darker then what I think it should be for being run only about an hour. After changing the oil I took it for about a 25 mile run. It runs like a champ, but for how long is the question. |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Oct 17, 2018 1:13 pm Post subject: Re: Stock Engine eating cam gears |
I was hoping you solved it.
Was it just a bit of a sheen in the oil? Or more? |
Posted: Wed Oct 17, 2018 1:17 pm Post subject: Re: Stock Engine eating cam gears |
You could see on the oil sump cover a silver sludge. |
Posted: Wed Oct 17, 2018 1:27 pm Post subject: Re: Stock Engine eating cam gears |
Dwayne1m wrote: |
Yeah that's not a good sign |
Posted: Wed Oct 17, 2018 2:05 pm Post subject: Re: Stock Engine eating cam gears |
Pruneman99 wrote: |
Dwayne1m wrote: |
Did you use the same oil cooler? Did you remove oil gallery plugs and really clean case? Might just be residual contamination from before. I’d buy some cheap 10w30 and flush it several more times. It’s not uncommon to see some stuff after first run especially if you aren’t running full flow filtering. Don’t throw in towel |
Posted: Wed Oct 17, 2018 2:32 pm Post subject: Re: Stock Engine eating cam gears |
I removed both pressure relief plugs and flushed it the best I could for quite a long time. I used the same oil cooler and flushed that several times as well. I'm not using an oil filter. Still the stock filtering system. I'm using Valvoline Racing Oil 10W 30 which is high in zinc. Used that for the break-in and for the first oil change. Not cheap. |
Posted: Wed Oct 17, 2018 3:29 pm Post subject: Re: Stock Engine eating cam gears |
It’s normal to see some stuff first change or two. I’m glass is half full optimist here. |
Posted: Wed Oct 17, 2018 5:23 pm Post subject: Re: Stock Engine eating cam gears |
I hope you're right. |
Posted: Wed Oct 17, 2018 7:08 pm Post subject: Re: Stock Engine eating cam gears |
Hopefully you have an oil filter/pump installed. _________________ In Stereo, Where Available! |
vamram Samba Member
Posted: Wed Oct 17, 2018 7:40 pm Post subject: Re: Stock Engine eating cam gears |
Dwayne1m wrote: |
... I'm not using an oil filter. Still the stock filtering system. ... |
Cbperformance MaxiII is a big improvement over the stock screen. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Wed Oct 17, 2018 8:01 pm Post subject: Re: Stock Engine eating cam gears |
There are real benefits to having a filter but I’ve built many an engine without just like VW. So Without the filter I’d buy some name brand but not fancy or expensive 10w30 and flush it several times. It should settle down after 2 or 3 changes. What have you got to lose? |
