robin.richard Samba Member
Joined: February 17, 2012 Posts: 497 Location: V. Beach VA
Posted: Wed Oct 17, 2018 2:21 pm Post subject: Strange size hole in case |
What's up with the small opening into the case and the louvers facing upwards. They don't fit down into the opening like they should. Is this something different? I've never seen this before.
-Rich _________________ Drive your bus! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Oct 17, 2018 2:25 pm Post subject: Re: Strange size hole in case |
Old 40 horse case. Louvers installed incorrect. |
satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Wed Oct 17, 2018 2:27 pm Post subject: Re: Strange size hole in case |
Older 40 hp case. Pre '64 I believe. VW made a deflector "tower" for these cases. _________________ DDC racing |
Posted: Wed Oct 17, 2018 2:40 pm Post subject: Re: Strange size hole in case |
Okay, knew the louvers were installed incorrectly. Interesting that this is a 40h case. My brother is running it in his 70's Baja bug. He has a alternator and alternator stand. Any work around? Need to seal that stand up right.
Posted: Wed Oct 17, 2018 2:48 pm Post subject: Re: Strange size hole in case |
Case Sn. H6634263. Isn't that a 1500 bus engine? '65? _________________ Drive your bus! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Oct 17, 2018 6:18 pm Post subject: Re: Strange size hole in case |
Idk what baffle goes on a 40, but you should spin that one 180 so the louvers point toward the #4 cylinder instead of #2. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Wed Oct 17, 2018 8:12 pm Post subject: Re: Strange size hole in case |
Oh duh, I wasn't thinking. That baffle won't fit the small hole case. That's why it is put on upside down. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Wed Oct 17, 2018 8:15 pm Post subject: Re: Strange size hole in case |
bugguy1967 wrote: |
Idk what baffle goes on a 40, but you should spin that one 180 so the louvers point toward the #4 cylinder instead of #2. |
Are you sure?
The service book indicates a different scenario.
Op good luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
modok Samba Member
Posted: Wed Oct 17, 2018 8:33 pm Post subject: Re: Strange size hole in case |
That case takes an OLD style baffle.
Evidently some goof has installed the wrong thing in there. It doesen't fit because it's not supposed to fit. You could use it if you enlarged the hoel to match. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Oct 18, 2018 5:34 am Post subject: Re: Strange size hole in case |
like these
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Thu Oct 18, 2018 10:50 am Post subject: Re: Strange size hole in case |
Simple: Put a standard baffle on, upside down like it was. Then get a stainless steel pot scrubber and stuff inside the alternator stand before installing. The pot scrubber will stop oil drops from slinging out of the oil filler neck and the stock baffle will prevent the scrubber from falling further down into the case. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
