YosemiteBound Samba Member
Joined: August 09, 2018 Posts: 327 Location: Los Angeles
Posted: Thu Oct 18, 2018 3:04 pm Post subject: Go Westy Alternator Harness Upgrade Woes (with pics) |
Squad,
Attempting my first wiring upgrade (ever). The GW Alternator Harness Upgrade. Right away, something looks wrong. Going by past posts and the GW instructions - my alternator situation looks different. The red wire is screwed into the right post but the blue wire is plugged in with a plastic clip. There is no 5mm nut holding the blue wire in place. Does that mean I need something else? Is there a way around this?
Thanks I've included pics. Trying to get it done today as I was going to tackle installing the pop top and aux battery this weekend.... tho now I'm doubting myself lol.
Do I not have the oem alternator in here?
_________________ 1985 Westy Round Headlights "Liam" |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Thu Oct 18, 2018 3:13 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Yes, the original 1.9 alternators used a male spade post for the blue wire connection. If your replacement harness came with a ring terminal on the blue wire then you need to adapt it. You could get a female spade terminal, cut the ring terminal off, strip the end of the wire, and crimp the new female spade terminal on the wire end.
Mark |
Posted: Thu Oct 18, 2018 3:28 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Thanks Crazyvanman. Although I really have no idea what you're talking about. I'm such a newb. I already gave up and put everything back. I couldn't even figure out where the original harness was running?
I thought this was an easy - unscrew what's there and put in the new one where the old one was - thing. When actually, it's a get under the bus - get under the firewall, splice new plugs etc.
I think I'm gonna have to wait on this one. And the aux battery job. Blah. _________________ 1985 Westy Round Headlights "Liam" |
Posted: Thu Oct 18, 2018 4:03 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
It is understandable that it looks confusing. You have an earlier van with wires run differently from the alternator than later vans. The replacement harnesses do things the later van way so you can't hook it up exactly like your old one. The later way is better though so what you need are good instructions that don't assume you have a later van.
Mark |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu Oct 18, 2018 4:10 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Yosemite,
Don't give up. This is a great opportunity to learn about auto electrics, and start getting to know your van. See it as a project. The project is not "install the gowesty thing", it's "learn how the alternator works, and put my knowledge to use by upgrading the harness".
1/ Do you have a Bentley manual?
2/ Where do you stand with electricity? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
Posted: Thu Oct 18, 2018 9:26 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Thanks everyone. I'm definitely going to do it.
My list currently looks like:
Alternator harness
Pop Top Seal and luggage rack seal replace
Pop top canvas replace
Aux battery plus inverter and charger hookup
I have all of the parts in my garage from GW and BD.
I just need to make sure I'm not royally screwing anything up first.
And thanks for the vid! Anyone happen to have a video about how to adapt spade terminals lol? Or how to put the GW alternator harness on a 1.9??
Yeah, totally looking to have my hand held. But, also, not looking to be the guy that just wants to plug and play. Or else I won't last long in vanagon land. I know it.
Edit: Why does the Go Westy page for the alternator harness I ordered say: "Fits all 1983-91 water-cooled Vanagons (2WD and 4WD)"? _________________ 1985 Westy Round Headlights "Liam" |
Posted: Thu Oct 18, 2018 9:34 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
YosemiteBound wrote: |
Edit: Why does the Go Westy page for the alternator harness I ordered say: "Fits all 1983-91 water-cooled Vanagons (2WD and 4WD)"? |
Because it does fit all those years. The original early harness was an engineering disaster so the replacement harness more closely resembles the better engineered later harness.
Be sure to remove the ground strap from the battery before dealing with this level of electrical repair. |
Posted: Thu Oct 18, 2018 9:40 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Wildthings wrote: |
Thanks, yes I removed the whole battery to be safe.
And it doesn't fit all of those years... without some gerry rigging/modifying/customization. With that logic you could put "fits all years" on anything. Or maybe I'm just anal. _________________ 1985 Westy Round Headlights "Liam" |
Posted: Thu Oct 18, 2018 9:44 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
And it doesn't fit all of those years... without some gerry rigging/modifying/customization. With that logic you could put "fits all years" on anything. Or maybe I'm just anal. |
The replacement is a perfect fit for the early WBXer engines, just not the poorly thought out original fit. If you could even get the original you wouldn't want to use it.
It does not require anything more than a minor reroute, I would not call it jerry rigging. It is about the simplest modifying and upgrading you can do. |
Posted: Fri Oct 19, 2018 1:59 am Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
One of the GW wires has the wrong kind of end on it for early wbx alternators so not such a perfect fit. Cutting an end off a new harness to crimp on the correct end isn't what most people would expect to have to do, minor as some may consider it. If the kit truly fit it would include the proper ends. Even if they would have included the other end loose it would be better, and a note saying you may need to change it to match your alternator.
Mark
Wildthings wrote: |
The replacement is a perfect fit for the early WBXer engines,.....
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Oct 19, 2018 9:12 am Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
^^^ x2...
I installed Jay's alt. upgrade harness a couple years back & I seem to recall it came
with both connectors & instructions for swapping if needed. I wouldn't be surprised
if you give him a call he'd ship one with the exact connector needed, in your choice
of color (pumpkin spice optional/extra charge)...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Oct 19, 2018 12:47 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
dhaavers wrote: |
^^^ x2...
- Dave |
Will he take my GW one on trade? _________________ 1985 Westy Round Headlights "Liam" |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Fri Oct 19, 2018 3:23 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
I no longer produce the alternator harness. The hydraulic crimping tool I used to install the heavy duty lugs broke beyond repair and I didn't feel like investing another $400+ into a tool that I only used for one job
I chose to set all of my harnesses up with a 1/4" female disconnect and included a tab to ring converter terminal so you could use it for any alternator likely to be found on a water cooled Vanagon.
A standard 1/4" female disconnect for the B+ connection can be found at any hardware store or home center. For best results, use a fully insulated terminal (or cover a standard non-insulated terminal with heat shrink). I would send you one of the OEM style terminals I use, but the crimping tool to properly install it will set you back at least $25.00, so it's not something worth investing in unless you plan to do a lot of electrical work on your van. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
msinabottle Samba Member
Posted: Mon Nov 05, 2018 12:00 am Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Here's a pretty good play-by-play, and how I got it done on Winston:
https://www.thesamba.com/vw/forum/viewtopic.php?t=597051&highlight=harness
Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Sat Feb 27, 2021 9:34 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Bumping this old thread for a quick question. I installed the GW alternator harness today. The install went great but I am second guessing my wiring route from the starter to the black junction box.
The original harness runs behind the firewall with a few clips. I decided to route the wires in front of the firewall (inside the engine bay), on top of the coolant tubes and bleeder valve.
Any harm in running the wires here?
_________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
Posted: Sun Feb 28, 2021 6:27 pm Post subject: Re: Go Westy Alternator Harness Upgrade Woes (with pics) |
Can anyone comment on how they routed their alt. harness wiring? Thanks. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
