Drewmon Samba Member
Posted: Mon Oct 08, 2018 11:33 am Post subject: Anyone lower their seats?? |
I just started getting the 56 going and realized the seats sit too high for me. Has anyone lowered their seats while retaining the ability to still slide back and forth? |
kpf Samba Member
Joined: March 01, 2017 Posts: 853 Location: California, US
Posted: Mon Oct 08, 2018 12:58 pm Post subject: Re: Anyone lower their seats?? |
I have not lowered my seats, but I've noticed that a lot of seats get over-stuffed when people re-cover them. In vintage photos, the seats look fairly flat across the seating surface. If yours are puffed up with a rounded, pillow look, you might be sitting an inch or two higher simply because of extra stuffing in the seat. Similarly, an over-stuffed seat back might be pushing you forwards an inch or so. _________________ 1971 Super Beetle |
Posted: Mon Oct 08, 2018 1:16 pm Post subject: Re: Anyone lower their seats?? |
Yes, they have been recovered by the previous owner with extra padding. I was hoping to be able to keep the padding because it’s comfortable, but the seating position is just too high. The seat is almost 2” taller then the seats in my 66 (original seats). |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Oct 09, 2018 4:05 am Post subject: Re: Anyone lower their seats?? |
I wouldn’t mess with the seat rails...better to fix the padding
The only other way would be to cut an inch out of the seat frame and weld back together |
misterwhitefolkz Samba Member
Joined: August 30, 2008 Posts: 3 Location: Temecula CA 92591
Posted: Fri Oct 19, 2018 6:39 pm Post subject: Re: Anyone lower their seats?? |
I was thinking of doing the same thing as I am 6'3" and if I could drop the seats about 2 to 3 inches it would be great. I did install a cheap set of recliners and it did help. A good starting point on a custom project would be a pair of seats out of a ghia as they are way lower in stock form, just find a way to adapt to a bug!! |
