Tim MacDonald Samba Member
Joined: October 11, 2004 Posts: 1346 Location: Edmonton alberta
Posted: Sat Oct 20, 2018 7:15 pm Post subject: Spring plate notching?? |
So from all the searches and threads I have read it seem some people have to notch their plate and some don’t when lowering the rear of their thing. I was thinking about lowering 2 outer notches. Will I need to notch? If so how much? Does anyone have a pic? Even better does anyone have a template? _________________ 61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Oct 22, 2018 5:00 am Post subject: Re: Spring plate notching?? |
I'm down one outer spline and I needed to notch slightly as the plates were bouncing off the stops on hard bumps. |
Ray the Vulture Samba Member
Posted: Wed Oct 24, 2018 8:25 am Post subject: Re: Spring plate notching?? |
I lowered mine 2 outer notches. You will definitely need to cut a notch in your spring plate. When you push the plate back on,you'll see how much you'll need to remove. Be sure to drill a hole in the corner of where the two cuts change direction, to avoid any cracks. It's a stiff ride, but it's low.
I can text you a ton of pictures if you need them, just DM me a number to send them to.
Posted: Wed Oct 24, 2018 2:55 pm Post subject: Re: Spring plate notching?? |
Ray the Vulture wrote: |
Awesome looking thing. I’ll send you a message thanks _________________ 61 so34 flip seat
88 cabriolet |
