73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Wed Oct 17, 2018 7:07 pm Post subject: Chrome Trim on front trunk |
I accidentally bent my hood chrome trim installing a new windshield (long story). Since then, I've added a vw emblem and a wolfsburg crest in what would be the factory position on an older bug. Does the chrome trim from the earlier beetles fit a late model (i need it to fit around my crest and vw badge)? _________________ Daily driven....Slowly. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Oct 19, 2018 8:04 am Post subject: Re: Chrome Trim on front trunk |
You must trim it back to have it look right- but it will work. Follow the instructions on trimming a strip back for the Wolfsburg crest- but simply cut off more length. _________________
EverettB wrote: |
FU#5 |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Fri Oct 19, 2018 8:22 am Post subject: Re: Chrome Trim on front trunk |
Hi,
the Wolfsburg crest was discontinued in 1963, when Beetles still had long front hoods and no ventilation grille. So, apart fron being too broad, older trim does not fit. All later front hood trim is too long too, because it was built to match the VW badge, but not the crest.
The only trim that would fit is the one from the 2003 Mexican Ultima Edicion, but I donīt think it is available:
Brian Samba Moderator
Posted: Sat Oct 20, 2018 3:37 pm Post subject: Re: Chrome Trim on front trunk |
My '69 had trim like the '03 beetle. The PO just chopped the trim at the top and stuck the Wolfsburg crest on above the handle.
Was a total hackey car
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
hitest Samba Member
Posted: Sat Oct 20, 2018 8:39 pm Post subject: Re: Chrome Trim on front trunk |
alex857 wrote: |
Hi,
Enlarge the holes and recurve the strip and an earlier one will fit. Been done many times when folks want the old look on a newer car.
That Ultima crest looks pretty stupid with the underlap and gap. That is NOT the way to do it. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Oct 24, 2018 4:52 pm Post subject: Re: Chrome Trim on front trunk |
Here's what i ended up with on my old beater. I tested with my old bent up chrome piece, but i think i like it. I'll buy a new strip and do the same.
