technowar Samba Member
Posted: Thu Oct 18, 2018 1:05 am Post subject: 1969 front and rear brake questions |
First off, I have a 1969 standard beetle with front and rear drum brakes.
I changed the stock front drum brakes to a Brasilia's (Type 321) front disc brake. Should the type 3 brake pads (311698151C) fit on the disc brakes I have? If not, which part number should I be looking?
Currently, the rear drum brakes are 4 lugs, and planning on changing it with 113501615G. Will they fit? |
Posted: Fri Oct 19, 2018 12:05 am Post subject: Re: 1969 front and rear brake questions |
Anyone who could help me? |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9950 Location: Huntington Beach, CA
Posted: Fri Oct 19, 2018 8:04 am Post subject: Re: 1969 front and rear brake questions |
I cannot help you, as I have never worked on a type 321. My first time seeing one was today, 10 minutes ago, after reading your post. Sorry.
But maybe they share components, as you are suggesting, with other VW cars. How about posting some photos to help us see what is there and what needs to be thought about? I think that may get the ball rolling. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Fri Oct 19, 2018 8:36 am Post subject: Re: 1969 front and rear brake questions |
From this:
https://www.autoanything.com/brakes/centric-c-tek-semi-metallic-brake-pads
It looks like they are the same as classic rabbit/dasher. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Fri Oct 19, 2018 1:33 pm Post subject: Re: 1969 front and rear brake questions |
Yeah, it was my mistake for not taking the pads out and took pictures. In addition, will the rear drum brakes fit a '69 beetle? |
Posted: Fri Oct 19, 2018 5:34 pm Post subject: Re: 1969 front and rear brake questions |
If you don't get a direct answer, look into the difference between type 3 rear brakes and type 4 rear brakes. This may help figure out what's on the back of the Brasilia. For example ,to use type 3 brakes on the rear of a U.S bug you need the backing plates and the hubs from a type 3 as well.
Are the Brasilia wheels 4 X 130 like the beetle's. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Sat Oct 20, 2018 12:15 am Post subject: Re: 1969 front and rear brake questions |
Yes, Brasilia's have 4 lugs similar to the 68 onwards standard beetle. Anyways, I have a stock drum rear brakes and planning on changing it. I'm not only sure if part #113501615G would fit. |
Posted: Sat Oct 20, 2018 6:02 am Post subject: Re: 1969 front and rear brake questions |
On the Ebay, listings they have the same part number for the beetle but I would not go only on that information. So they might have the same brakes. Why don't you measure the drums and see if the diameter or width is different? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sun Oct 21, 2018 1:42 am Post subject: Re: 1969 front and rear brake questions |
Yeah, I noticed that as well so I asked here.
I will check them brakes when I get back home. |
