The Stupid Question Thread
Page: Previous  1, 2, 3 ... 382, 383, 384 ... 513, 514, 515  Next
advCo
advCo is offline
PostPosted: Thu Oct 04, 2018 1:12 pm    Post subject: Re: The Stupid Question Thread Reply with quote
busdaddy wrote:
70-71 would be the closest fit, 72 could be adapted with minimal drama, 68-69 would also work if it's just that section you are replacing and stay in front of the beam.
Thanks, busdaddy. The donor piece is from a '68 and AFAIK the damage ends around 12" from the front so we should be good to go.
"He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett
scubaseas
scubaseas is offline
PostPosted: Thu Oct 04, 2018 5:35 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hi everyone, I just bought a '73 Campmobile and wanted to introduce myself. I really like the camaraderie and the way you all support each other. It makes me feel proud to be a new, old VW owner.
I've read the forum rules and downloaded the manuals. Searching this site has answered most of my questions already - you people have a LOT of knowledge and experience. I bought a copy of How to Keep Your Volkswagen Alive and I have access to my father's tools.
I don't know much about motors or old cars in general so I have a lot to learn. My goal is to keep Clementine roadworthy and take good care of her.
So...here's my stupid question for anyone who lives in Virginia: If I'm reading the VA State Police website correctly, vehicles manufactured after 1972 must have the pollution control system intact. Clem had some kind of smog device that was removed. I've been reading various threads on this site and it appears that she is not a California vehicle - does that matter? Do I have to reinstall this device to pass inspection? Part of my problem researching this is that I'm not sure what the device is called. The motor is a dual carb, 1700cc, if that helps.
I'd be grateful if someone could point me to the right information; at this point, I'm at a loss
Welcome. You may want to try posting in Bay Window Bus forum.
If there is no emissions diagram sticker on the Bus you might plead ignorance and see if the Commonwealth picks up on the lack of controls. Or you could do the easy stuff like cold air hose to the air filter, crankcase vent and evaporative emissions etc. and let them tell you what's missing and deal with it from there.
https://www.thesamba.com/vw/archives/manuals/73emissions.php
Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired
scubaseas
PostPosted: Thu Oct 04, 2018 5:40 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Al
Retired
andrewtf
andrewtf is offline
PostPosted: Fri Oct 05, 2018 6:30 am    Post subject: Re: The Stupid Question Thread Reply with quote
My stupid window seal question:
We are trying to install a rear driver's side window (full glass, no vent).
I got new seals from Bus Depot.
We tried for over an hour last night to just get the seal on the glass. SO far, I'd say it is 25% on the glass ( only the two short ends.) The 'slit' to insert the glass in is so tight that it won't even go in. I could barely even get my fingers to open it up. We tried lubing up the seal and really no luck.
We've put in several windows before and never ran into this issue.
The search function did me no good - so I'm forced to be stupid in public.
Keep trying?
bad seal?
idiot installers?
thanks
'75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey
andrewtf
andrewtf is offline
PostPosted: Sat Oct 06, 2018 6:23 pm    Post subject: Re: The Stupid Question Thread Reply with quote
well - we did it (installed the windows as per above).
Patience
Brute Strength
Lots of lube
'63 Austin Healey
spk5063
spk5063 is offline
PostPosted: Mon Oct 08, 2018 12:46 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Has anyone ever brought a compression tester to conduct the test on a bus they are looking at to purchase?
Is this overkill? From what I'm thinking it's pretty reasonable but a little awkward to do, IDK. What have your experiences been?
I love stupid questions javascript:emoticon('Razz')
Wildthings
Wildthings is offline
PostPosted: Mon Oct 08, 2018 12:50 pm    Post subject: Re: The Stupid Question Thread Reply with quote
A compression test is certainly a good idea. Remember you need a well charged battery and a hot engine to do a good test. All plugs removed and the throttle blocked open.
You don't want to pay much for any vehicle that will not run well enough to test drive. If any one thing is bad enough that it can't be driven assume lots and lots of expensive things aren't going to work.
lil-jinx
lil-jinx is offline
PostPosted: Sat Oct 13, 2018 8:02 pm    Post subject: Re: The Stupid Question Thread Reply with quote
the seller may want his mechanic to do the test for you,
1968 Dune Buggy
1974 parts bus
airkooledchris
airkooledchris is offline
PostPosted: Thu Oct 18, 2018 12:05 pm    Post subject: Re: The Stupid Question Thread Reply with quote
This is Tom Hanks old bus, apparently, and is up for sale in the classifieds right now.
Note the wheels. Are they wider than usual?
They certainly look wider than stock to me, or the offset is wrong/different from stock.
Would you widen a bus rim to help accommodate a different tire for some reason?
Side note - why black bumper bolt covers? They make them in white. I imagine that would look better.
wihr
wihr is offline
PostPosted: Thu Oct 18, 2018 12:08 pm    Post subject: Re: The Stupid Question Thread Reply with quote
They are probably Mercedes wheels. They fit the same bolt pattern.
WW
WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
airkooledchris
PostPosted: Thu Oct 18, 2018 12:09 pm    Post subject: Re: The Stupid Question Thread Reply with quote
WW
and fit the stock hubcaps?
wihr
wihr is offline
PostPosted: Thu Oct 18, 2018 12:14 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I don't know. I have a 70 with the wide five pattern. The wheels on my Mercedes do have a slight ridge outside of the bolt pattern. It possibly could hold a hub cap.
WW
WIHR
ivwshane
ivwshane is offline
PostPosted: Fri Oct 19, 2018 7:59 pm    Post subject: Re: The Stupid Question Thread Reply with quote
In this post it mentions an exhaust stud. Where are these studs used and how many are there? Are they what's used on the crossover pipe?
Tcash wrote:
Muffler, Exhaust and Heater 1975-1978
Some items shown in the next two pictures are becoming VERY difficult to obtain in good used, much less new. The manifolds and pipes are long ago discontinued items. Did you know that many Bus owners are now retro-fitting the 72-74 Bus exhaust system to their 75-78's? A very workable retro-fit. Just be sure to use the 039-256-251 Copper Exhaust Gaskets from the Head to the Heater Box Manifold Pipes for proper sealing. For more info, go to the Exhaust - Muffler & Heater 1972-1974 Section for all of the necessary parts listings. In addition, the Heater Control Flap/Boxes on the 72-74 are the same as your 75-78, so you don't have to replace these.
Note: This retro-fit is NOT legal for street use, especially in areas of the US that still have periodic emission-control (smog) checks, especially those requiring the installation of the Catalytic Converter. Check with Local Laws first before performing this retro-fit.
Muffler & Tailpipe
Ref. Part Number Description
A. 071-251-053C Muffler
B. 021-251-521 Muffler Strap
C. 021-251-541 Connecting Pipe From Elbow To Muffler
Note: This pipe is only used on 75-78 models NOT originally
equipped with a Catalytic Converter.
Not Legal For Street Use On Models Originally Equipped
With Catalytic Converter.
Not Legal For Street Use On California Models 75-78.
D. 021-251-185F Tailpipe
E. 023-298-051 Exhaust Donut/Clamp Kit - Connects Pipe or Converter to Muffler
F. 025-251-235 Gasket Only, Tailpipe
Manifolds & Heater System
A. 021-251-551 Exhaust Manifold, Left
B. 021-251-552 Exhaust Manifold, Right
C. 039-256-251 Copper Gasket, Manifold to Head, 1800 1975, 2000 76-78
D. 043-251-509 Exhaust Triangle Gasket
E. 021-251-201 Exhaust "Afterburner" Pipe, Left or Right Side
F. 021-256-091T Heater Box, Left
G. 021-256-092T Heater Box, Right
H. 021-251-501 Exhaust Crossover Pipe With PreHeat Tube 75-Mid 76
To VIN 2x6 2070 000
J. 021-251-501A Exhaust Crossover Pipe Mid 76-78
From VIN 2x6 2070 001
K. 021-251-531 Exhaust Elbow
L. 070-251-235 Gasket, Elbow to Crossover Pipe
M. 021-256-205K or L Heater Control/Flap Box, Left
M. 021-256-206K or L Heater Control/Flap Box, Right
N. 311-129-777 Swivel Pin/Clamp, Heater Cable
P. N 014 684 1 Stud, Exhaust Port (Special 8x9x56)
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
ivwshane
ivwshane is offline
PostPosted: Fri Oct 19, 2018 8:52 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I'll answer my own question. The studs are on the cylinders where the exhaust connects.
Muffler & Tailpipe
To VIN 2x6 2070 000
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
tonysantacruz
tonysantacruz is offline
PostPosted: Mon Oct 22, 2018 6:35 am    Post subject: Re: The Stupid Question Thread Reply with quote
Is there a cheat sheet for what you should check before you drive your bus? Oil level, tire pressure and the like? I'd like to have one laminated in my glove box, but I'm not sure how many things would need to be checked daily, weekly, monthly?
I tried searching, but after forty-five minutes, I came up empty.
KentABQ Premium Member
KentABQ is offline
PostPosted: Mon Oct 22, 2018 7:31 am    Post subject: Re: The Stupid Question Thread Reply with quote
It's not a cheat sheet, but one can be made from its information...
Download the owner's manual for your year from the "Technical" section. All maintenance is referenced in it.
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
stevespeirs
stevespeirs is offline
PostPosted: Tue Oct 23, 2018 7:26 am    Post subject: Re: The Stupid Question Thread Reply with quote
79 Bus. Canyon Brown interior. Correct color front kick panels -
Black or brown?
1979 Microbus
airkooledchris
PostPosted: Wed Oct 24, 2018 3:00 pm    Post subject: Re: The Stupid Question Thread Reply with quote
there's definitely something different about those wheels. like a bee in my bonnet, what the heck...
Wildthings
PostPosted: Wed Oct 24, 2018 3:47 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Low profile tires on a jacked up bus?
busdaddy
busdaddy is offline
PostPosted: Wed Oct 24, 2018 5:02 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Look like widened rims from here.
Слава Україні!
Page 383 of 515
