telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Oct 22, 2018 11:16 am Post subject: Re: Electrical Oddity In Tucson AZ |
Much better. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
SGKent Samba Member
Posted: Mon Oct 22, 2018 11:51 am Post subject: Re: Electrical Oddity In Tucson AZ |
am at a loss where thread went about new cable. Bus Depot had the factory cables in the correct color for the longest time. I just replaced one a year ago.
http://www.busdepot.com/211971228a _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Oct 22, 2018 12:12 pm Post subject: Re: Electrical Oddity In Tucson AZ |
SGKent wrote: |
http://www.busdepot.com/211971228a |
If I can get an extra 0.5 volts at the starter on a cold morning by buying a larger diameter cable that is the direction I would go. |
SGKent Samba Member
Posted: Mon Oct 22, 2018 1:39 pm Post subject: Re: Electrical Oddity In Tucson AZ |
Gary - what gauge is the welding cable you are using? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Oct 22, 2018 5:49 pm Post subject: Re: Electrical Oddity In Tucson AZ |
SGKent wrote: |
Gary - what gauge is the welding cable you are using? |
#2
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Mon Oct 22, 2018 5:55 pm Post subject: Re: Electrical Oddity In Tucson AZ |
you can get crimp on battery clamp ends too for those who go straight to the battery. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wcfvw69 Samba Purist
Posted: Mon Oct 22, 2018 7:52 pm Post subject: Re: Electrical Oddity In Tucson AZ |
Holy smokes Gary, you don't screw around with your battery cables!
Dayum! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Oct 22, 2018 10:42 pm Post subject: Re: Electrical Oddity In Tucson AZ |
The nice thing about welding cable is that it is made from hundreds of strands of fine wire (kind of the exact opposite of building wire), making it extremely flexible and vibration-resistant. Add to that a covering designed to be used in a shower of sparks and hot metal environment, and you've got a pretty rugged cable. Love the stuff - but it's not cheap...
And having something like this is helpful for the bigger terminals:
Hammer Crimping Tool
< $20 on Amazon. _________________ '71 panel, now with FI
Posted: Tue Oct 23, 2018 4:35 am Post subject: Re: Electrical Oddity In Tucson AZ |
telford dorr wrote: |
Any further advantage to soldering the ends after crimping then pulling down some heat shrink to cover it? _________________ Contact me at [email protected]
Posted: Tue Oct 23, 2018 4:52 am Post subject: Re: Electrical Oddity In Tucson AZ |
wcfvw69 wrote: |
Any further advantage to soldering the ends after crimping then pulling down some heat shrink to cover it? |
There are proper ways to solder such things, but most people will end up with a less dependable joint by trying to solder it.
Smear dielectric grease all over the exposed end of the wire and use the correct crimp with a decent crimper and apply heat shrink over the joint and you should have a long lived joint. |
Posted: Tue Oct 23, 2018 8:36 am Post subject: Re: Electrical Oddity In Tucson AZ |
wcfvw69 wrote: |
No, and a major disadvantage: solder wicks up the wire a few 1/10's of an inch, making it stiff. When the wire flexes, it's a larger bend radius that starts away from the connector's support, creating a weak point where failure will start. (Yeah, it's a big wire, and failure will take a while, but still...) General rule of thumb: no solder in a high vibration environment without supplemental wire support.
Heat shrink is a good idea, however - helps keep corrosive stuff away from the joint. _________________ '71 panel, now with FI
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Tue Oct 23, 2018 8:38 am Post subject: Re: Electrical Oddity In Tucson AZ |
asiab3 wrote: |
1,028 miles and four states since you posted this thread Colon, how about yourself?
RobbieFromColorado |
Why thanks for asking, Robbie. We are at an additional 2,028 miles and 7 states as I pull into Pensacola this evening, poor car, 22,000 miles since friggen May. You just can't give us nice things, we just wear them out.
Colin
_________________ www.itinerant-air-cooled.com |
Posted: Tue Oct 23, 2018 8:49 am Post subject: Re: Electrical Oddity In Tucson AZ |
SGKent wrote: |
That ugly thing with the "universal end" and the dangling red wire is not my original cable, nor is it factory with that garish red insulation. I did buy one of those for the Road Warrior, Steve, and looked like an idiot (a happy idiot) painting the red insulation with a matte black plastic paint to cool down the garish.
So yeah, we're 2,028 miles into this repair and it is working fine. The 2018 Itinerary ends in six hours. What a remarkable bus this has been:
tommu Samba Member
Posted: Tue Oct 23, 2018 12:30 pm Post subject: Re: Electrical Oddity In Tucson AZ |
Engine bay looks a little dirty there Colin. _________________ |
SGKent Samba Member
Posted: Tue Oct 23, 2018 1:10 pm Post subject: Re: Electrical Oddity In Tucson AZ |
You may think no one will ever work on your bus but some day someone will who just knows to hook the red jumper cable up to red, and the black to black. Copper braid is reddish in color and black is positive. Poof _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
