balljoint Samba Member
Posted: Mon Oct 22, 2018 11:28 am Post subject: H30/31 or 30 pict 1 |
I have a 30 pict 2 that runs but needs replacing due to leaky shaft etc.
My distributor is a Brazilian 009 that I'm reusing as I have a lot of other stuff to sort out on this car and cannot focus on changing both carb and dist at the same time.
I've done lots of research and see the H30/31 or the 30 pict 1 with power circuit plays best with the 009 so it's gonna be one of these but I'm leaning more towards the H30/31 because of the larger venturi and should be better suited for my stock 1600DP.
Opinions? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Oct 22, 2018 1:18 pm Post subject: Re: H30/31 or 30 pict 1 |
I run a 30/31 PICT (that I rebuilt myself as a precaution since wan't used for a decade) on a stock dual port manifold on the 1600cc DP engine I rebuilt 1.5 years ago. I use a vintage German 009 with it too. Runs good. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Nov 03, 2018 6:33 am Post subject: Re: H30/31 or 30 pict 1 |
Yes I see you have had good success with that set up.
Anyone else? |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Sat Nov 03, 2018 11:27 am Post subject: Re: H30/31 or 30 pict 1 |
balljoint wrote: |
Opinions? |
You could re bush the 30 pict 2, either buying replacement bushes or standard fitting metric engineering bushings.
Neither of the carburettors you have are really ideal for a 1600DP. But then with an 009 as well you arent getting the most from it either so I suppose it doesnt matter .. _________________ Ancient vehicles and vessels
Posted: Sat Nov 03, 2018 3:33 pm Post subject: Re: H30/31 or 30 pict 1 |
The pict 2 isn't ideal either! |
gt1953 Samba Member
Posted: Sun Nov 04, 2018 7:02 am Post subject: Re: H30/31 or 30 pict 1 |
Just do yourself a favor and runt he H30/31. Flexible carb actually. Running that on my stock single port 1600cc with a Bosch 205 M vacuum distributor. Ya the 009 will work as long as it is a good German one. Another option is to send the carb to Tim Volkzbiz and when it is returned to you it will be as good as or better then New Old Stock =NOS. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sun Nov 04, 2018 7:34 am Post subject: Re: H30/31 or 30 pict 1 |
Whatever carb I decide on I will be getting it from Tim.
Even if I go the H30/31 personally I feel one from him will be better because of the upgraded bronze throttle shaft bushes....don't know what the new ones come with tho.
Not too keen re-using the 30 pict 2 because of the know issues. |
