wayne1230cars Samba Member
Posted: Mon Oct 22, 2018 9:41 am Post subject: Swing axle rear brake line |
While replacing the rear wheel cylinders on my 1960 bug, I also changed the metal lines between wheel cylinder and flex hose. The old steel line still had the tag on it showing it as a 3/16 European line. I was puzzled by it not being metric size. Brakes worked ok with no leakage at the connections. Any insights on this?
_________________ 1960 beetle
1970 beetle convertible |
calvinater Samba Member
Posted: Mon Oct 22, 2018 9:53 am Post subject: Re: Swing axle rear brake line |
I should think being from internet days , it is safe to say it is not original. _________________ "Albatross"! |
anthracitedub Samba Member
Posted: Mon Oct 22, 2018 1:05 pm Post subject: Re: Swing axle rear brake line |
4.76mm X 304.8mm... there, fixed it for ya😁 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Mon Oct 22, 2018 2:44 pm Post subject: Re: Swing axle rear brake line |
calvinater wrote: |
I should think being from internet days , it is safe to say it is not original. |
Lol, ya gotta point! Unless it was originally foe a special DeLorean! |
Posted: Mon Oct 22, 2018 6:23 pm Post subject: Re: Swing axle rear brake line |
calvinater wrote: |
Lol. The “Sarnia, Ontario” was another subtle clue. I did measure the thread pitch and it was 1.0 mm as original. The bubble flare seems to be like original. Only difference was that the 3/16 non-original fitting is longer so that when fully tightened there are 4 threads still exposed. No leaks though. _________________ 1960 beetle
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Mon Oct 22, 2018 9:15 pm Post subject: Re: Swing axle rear brake line |
Another clue is that in Europe they don't call it "European brake line," they just call it "brake line." _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Mon Oct 22, 2018 9:50 pm Post subject: Re: Swing axle rear brake line |
wayne1230cars wrote: |
calvinater wrote: |
Lol. The “Sarnia, Ontario” was another subtle clue. I did measure the thread pitch and it was 1.0 mm as original. The bubble flare seems to be like original. Only difference was that the 3/16 non-original fitting is longer so that when fully tightened there are 4 threads still exposed. No leaks though. |
I've gotten lines like that off the shelf from my local parts place.
No problem using them but as you said, the ends were a little weird (long).
When I've done that it was sort of an emergency situation, like once a wrench slipped and it broke the metal line.
Where am I going to get a line at 9PM at night when there's a show the next morning?
I replaced them later with normal VW metric lines from a VW parts place. _________________ How to Post Photos
pupjoint Samba Member
Posted: Tue Oct 23, 2018 1:23 am Post subject: Re: Swing axle rear brake line |
i have used 3/16" with no issues.
any idea what metric size the originals are? 4.5mm? 5mm? |
