Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1089 Location: Atlanta, GA
Posted: Mon Oct 22, 2018 7:08 am Post subject: Evap Tank Repair |
Well, I discovered last night that one of the plastic nipples on the right side fuel evap tank has broken off. The rest of the tank is OK. The part that's broken off has been lost. Is there any way to repair those tanks that'll hold up to fuel vapors? _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Zeitgeist 13 Samba Member
Posted: Mon Oct 22, 2018 7:25 am Post subject: Re: Evap Tank Repair |
Just buy a new rollover valve and grommet from one of the usual vendors _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Mon Oct 22, 2018 7:57 am Post subject: Re: Evap Tank Repair |
@dobryan, yep...it's one of the nipples on the bottom edge. There's a little bit of the original left, but not enough to have the hose and clamp stay in position. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Oct 23, 2018 5:53 am Post subject: Re: Evap Tank Repair |
@ dobryan, I would think that with all the plastic evap tanks ( not just for Vanagons) that someone has a way of repairing them.
@shagginwagon83, Thanks! I'll contact them and see if they have a right side. BTW...someone on Craigslist in Copperhill, TN is advertising VW parts. They've got a few pictures of cars, and there's a few Vanagons in the mix. I'm going to contact them to see if they have some things I'm looking for. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Tue Oct 23, 2018 6:19 am Post subject: Re: Evap Tank Repair |
Although this is a thread more related to the tank itself, I think you are looking for something like this "permanent fix", for the evap's. I'm guessing there is a sealant goop that would withstand fuel and vapors. [those tanks get fuel in them sometimes too you know]
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Oct 23, 2018 8:37 am Post subject: Re: Evap Tank Repair |
There are 2 tanks, probably overkill, but you should be able to loop the r/s with a piece of hose and bypass one tank safely. Go easy on the neck filling. _________________ ☮️ |
Posted: Tue Oct 23, 2018 9:27 am Post subject: Re: Evap Tank Repair |
I've never seen it myself, but I've read of folks who fill a tank on a cool morning, from a cool underground gas station tank, and when temps come up in the afternoon, they see both expansion tanks about half full of liquid fuel. I guess you'd want to remember that sort of thing if you were using only one. I guess just don't fill it full? _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Oct 23, 2018 9:51 am Post subject: Re: Evap Tank Repair |
While they are reparable the cost will exceed that of a good used tank. If you are determined to fix it buy a nipple that is threaded on one end can be inserted from inside the tank and fixed in place with a nut. Permatex makes a kit for about $10 that includes an appropriate adhesive for sealing the new nipple. Or buy a plastic nipple and fix it into place with the above adhesive. Cost for the primer and adhesive will run about $15-17. |
Posted: Tue Oct 23, 2018 11:36 am Post subject: Re: Evap Tank Repair |
I gave my evap tanks away when I converted to diesel, so they're out there. _________________ Casey--
y u rune klassik? |
Posted: Tue Oct 23, 2018 11:53 am Post subject: Re: Evap Tank Repair |
Casey, I could be wrong, but I think our 82 factory diesel still has the expansion tanks. The syncro I am building does not, but seems it would benefit from one. _________________ ☮️ |
Posted: Tue Oct 23, 2018 12:32 pm Post subject: Re: Evap Tank Repair |
Yep, Bentley shows them, but I don't think they're necessary. I ran tank breather lines up into the pillars on both sides. No vacuum or pressure problems since. None of my MB diesels have had evaporator tanks. _________________ Casey--
y u rune klassik? |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Wed Oct 24, 2018 8:21 am Post subject: Re: Evap Tank Repair |
Zeitgeist 13 wrote: |
Just buy a new rollover valve and grommet from one of the usual vendors |
An aside here... but I had broken the nipple on one of my rollover valve, or float valve, the day this post went up. After exploring some rarely used vocabulary with myself (thinking this has to be NLA), I held the broken nipple to the valve with some Gorilla Tape and then buried it in two-part 2,000 lb epoxy. Came in the house thinking that one day I will be someone else's "prior owner" when they unearth that mess. Flipped open the computer saw this post, ran "rollover valve Vanagon" on google, and ordered a brand new one with another grommet. Two days from now it will arrive in the mail and I will no longer be "that guy" and will be sleeping better thinking of my disciplined Vanagon build. Lol.
Thank you for the search term Zeitgeist. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Posted: Thu Oct 25, 2018 5:27 am Post subject: Re: Evap Tank Repair |
I'm going to try the repair method with the brass nipple and see if it's successful. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
