markdam Samba Member
Posted: Thu Oct 18, 2018 10:44 am Post subject: California Clipper hood off pics |
Does anyone have any California clipper resotration pictures with the hood off? im trying to get my hood off to refresh fuel tank and brakes and wiring.
Posted: Thu Oct 18, 2018 10:45 am Post subject: Re: California Clipper hood off pics |
do I have to remove the windshield to get the hood off? |
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Thu Oct 18, 2018 11:09 am Post subject: Re: California Clipper hood off pics |
It all depends on who built it and how they put it together. It was a kit build, no two are the same. Take the screen off to save weight and possible damage, undo any cables and wiring from under the dash then undo whatever screws, bolts or rivets that are holding the hood to the tub. Remove the headlights and gas cap by whatever holds them on then lift it off. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Thu Oct 18, 2018 11:11 am Post subject: Re: California Clipper hood off pics |
It is impossible to speculate on how the builder put it together. You are going to have to stick your head up under there and take a look. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Thu Oct 18, 2018 11:12 am Post subject: Re: California Clipper hood off pics |
You can't do things by the book when there is no book. |
Cammie Samba Member
Posted: Thu Oct 18, 2018 12:13 pm Post subject: Re: California Clipper hood off pics |
Mine isn't a californian clipper, but the steering column went through a hole in the dashboard, so that needed to come out first too |
Posted: Thu Oct 18, 2018 3:26 pm Post subject: Re: California Clipper hood off pics |
Thanks for all the replies people looks like I just got to go old fashioned I thought I'd be able to cheat a little bit with some visual cues the screws are so Rusty I'm having to drill out and punch through so when I reattach the hood I'm going to have to make new attachment points anyway and same with the gas cap screws are going to have to be chiseled off |
Posted: Thu Oct 25, 2018 1:25 am Post subject: Re: California Clipper hood off pics |
got it off separated dash from hood
overdue Samba Member
Posted: Thu Oct 25, 2018 9:20 pm Post subject: Re: California Clipper hood off pics |
mine was one piece and notched |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Thu Oct 25, 2018 11:46 pm Post subject: Re: California Clipper hood off pics |
How were you able to loosen the hose clamp for the filler neck? Could you see it and reach it from under the dash? |
Posted: Fri Oct 26, 2018 9:40 am Post subject: Re: California Clipper hood off pics |
If you're asking me I didn't I just Twisted the gas cap back and forth after I cut the heads of the bolt. It was snug but it did come out |
dustymojave Samba Member
Posted: Tue Oct 30, 2018 3:24 pm Post subject: Re: California Clipper hood off pics |
markdam wrote: |
I like having the hood separate from the dash for service-ability. I plan to separate them for my Glitterbug. But then, I plan to make a panel to separate the "trunk" from the cockpit too. It might be a good idea to add a fiberglass lip to the back edge of the hood so it overlaps the edge of the dash going back together.
I'm also planning to NOT have the gas cap exposed. Maybe cut a small gas cap door and hinge it with a cable latch and a spring to pop it open. Maybe even a late Bug gas tank with a side filler door from the Bug fitted into the back corner of the hood? Gotta look into that. _________________ Richard
SoCalBajas Member
