Proper green paint code for 79 Westy
Becklerwesty
Becklerwesty is offline
PostPosted: Tue Oct 30, 2018 6:33 pm    Post subject: Proper green paint code for 79 Westy Reply with quote
New here to forum. Friend told me I could get help. I restored my 79 once with sage green l63h. Hated yellow-white creamy shade. Looking for color closer to interior color. Brighter green. Any help need it. It's in shop now getting re-restored and hated this sage more now, same yellow-white blend. Anybody here tried a different green but close to same code? Was the green color different in earlier years, let's say 73-76?[img]
[/img]
Above are the greens in question. Bus with open door is close to l63h, shiny bus 2 is color I'm looking for. Obviously bus 2 is wetsanded but the shade I want. I'm so new to this guys, I'm doing my best. Any help much appreciated. Bus 1 is precisely 79 sage. You can see the yellow-white influence in color. Everytime I see a beautifully painted solid green it's the shade I'm looking for...just not when I paint. Thanks for the help ahead of time. I'll post my finished product in a week or 2 here...if I can find my color
static
static is offline
PostPosted: Tue Oct 30, 2018 6:46 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
https://www.thesamba.com/vw/archives/info/colorstype2.php
Like VW campers? Join us!
https://www.facebook.com/groups/2362239654/
SGKent Premium Member
SGKent is offline
PostPosted: Tue Oct 30, 2018 7:09 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Your first photo looks off. Is that representative of the color? Here are a couple sage green photos.
faded original paint
Godspeed to all who undertake a journey in a VW Bus. You only get one shot at life - go out and enjoy it - let the Light shine.
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. I love winning but now I figure it is your turn. My goal is only to share what has been learned on my path. Smile
1971 (sold)
1977
[email protected]
Samba Peckerhead
PostPosted: Tue Oct 30, 2018 8:42 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
you can't go by code with modern paints and expect a match to original paint.
you need to get a nice original dash piece and color map it off of that, do a spray out and tint as needed. sometimes a color map is dead nuts, other times, not so much....
so many fail to realize this, and most body guys don't give a shit if they are doing an overall....if they are doing a blend they are forced to play the tint game.
not sure what you are looking for, something close to the original color or something else?
here is an example of a color map
https://www.thesamba.com/vw/forum/viewtopic.php?p=7894752#7894752
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Bleyseng
Bleyseng is offline
PostPosted: Wed Oct 31, 2018 7:09 am    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Here is the PPG code I got from [email protected] that matches
My Westy after painting as the outside paint matches the inside perfectly.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
jtauxe Premium Member
jtauxe is offline
PostPosted: Wed Oct 31, 2018 7:15 am    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Becklerwesty wrote:
No photo is going to get it right, since the science of color and cameras and lighting and all is so complex. In the above photo, the color seems not quite right, and the nose is definitely different -- a bit... whiter?
Was your bus originally sage green?
Is that the color you want, or are you after something else?
If you want to go with an original sage green, find a suitable unfaded piece, as skills says, and match to that. Like part of the front air duct.
If not, then you will just have to experiment and judge for yourself. We really can't help.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab, 1978 Irish 4-door double cab RHD
orwell84
orwell84 is offline
PostPosted: Wed Oct 31, 2018 7:30 am    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Some colors must be harder to get right. I have always found whatever I buy in L20B brilliant orange matches the original paint compared to untouched interior sections.
Becklerwesty
PostPosted: Wed Oct 31, 2018 12:29 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Thanks a lot. Hey blessing , is that sage? Did you mix that color or did u order the paint? My shop using DuPont I think. Any suggestions on a different brand that might match?
Becklerwesty
PostPosted: Wed Oct 31, 2018 12:40 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Thanks man. I have this chart, and sage is obvious. However, a paint mix that worked is what I need. I have 2 days to get this right. I was certain it was going to match. Shop chose alpine white for top and that's too dark. This is tough
Becklerwesty
PostPosted: Wed Oct 31, 2018 12:42 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Thanks SG. My 'alpine white is worse. What did you use for the white? I had to paint the top. I absolutely love your paint . It's what I'm looking for. The white for sure too. Thanks to all of you guys. I'm a quadriplegic , it's so hard for me to do anything. Just to type here. This is my sage Thanks so much oh SG, what brand or where did u find that sage?.[img]
[/img]
Becklerwesty
PostPosted: Wed Oct 31, 2018 2:21 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Heres my bus prior to paint. So 2-tone or back to original green? Help me out
Bleyseng
Bleyseng is offline
PostPosted: Wed Oct 31, 2018 4:30 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Have a sample pint made with my code to see how it matches yours
notchboy
notchboy is offline
PostPosted: Wed Oct 31, 2018 4:54 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
Becklerwesty
PostPosted: Wed Oct 31, 2018 5:51 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
notchboy wrote:
Notch, I want this green. This ain't my sage, but I love the hell out of it. Out of the thousand greens I've looked at, this is DEAD NUTS what I'm looking for. SG has a nice shade, bleseng as well, but this? Good stuff. Thanks too bleseng. I'll spray your mix. Notch, you have a code for this? I'm in a pinch, a big pinch. This is a beautiful bus
notchboy
notchboy is offline
PostPosted: Wed Oct 31, 2018 8:49 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
I don't I have no idea what this dude did. It is a very original bus that's clean. You recently posted up to Facebook and I knew it was spot-on for what you were looking for but I don't have any codes or anything for it. Sorry mate 🤨
1964 1500 S
Xevin Premium Member
Xevin is offline
PostPosted: Wed Oct 31, 2018 9:47 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
Odd seeing a late bay, sage green without a top engine hatch and exhaust on left side. I understand it. Just unique on this side of the pond.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
Bleyseng
Bleyseng is offline
PostPosted: Fri Nov 02, 2018 12:54 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
You can't tell jack shit about color on the internet! Get a test pint made and test it on a spot on your bus where it is oem paint.
SGKent is offline
PostPosted: Fri Nov 02, 2018 1:37 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
those look like European license holders on that bay. I'd guess that the body was really straight to begin with and that he went with lots of clear on it for the depth it shows - in addition lots of coats of wax.
1971 (sold)
1977
Becklerwesty
PostPosted: Fri Nov 02, 2018 4:01 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
I very well can tell color on the "internet", but thanks dude. Here for help is all. Btw, already sprayed my code sage next to original behind a panel, which I guess u missed,, it's why I'm here. If u would have you'd know I sprayed it the 1st time, then became a quad, thus have to have a shop spray it 20 years later. If i could use my legs and arms, I'd do it myself and get it right. Why I'm asking for help from you guys here. SG was a big help, thanks alot, and the other guys... just looking for help pal;)
Like was said, you get one chance at this, doing everything I can do to get it right ble.
Abscate Premium Member
Abscate is offline
PostPosted: Fri Nov 02, 2018 6:33 pm    Post subject: Re: Proper green paint code for 79 Westy Reply with quote
You canít use pictures of Busses on computers to gauge colour matching.
Period.
.ssS!
