Dermechaniker50 Samba Member
Joined: March 26, 2018 Posts: 20 Location: Charleston, SC
Posted: Thu Oct 11, 2018 12:11 pm Post subject: 1972 Beetle Baja SE wheel center caps |
I recently acquired a set of 4 Lemmerz 10-spoke steel wheels minus the center caps. These "special, one year only" wheels were used on the 1972 Baja SE bug (in the USA) and the Marathon/Weltmeister models in other countries. My search for center caps has revealed they are quite rare and expensive.
My question is about identifying suitable aftermarket caps that will fit these wheels. The wheel center opening is 3.140 inches (80mm), which is larger than the center caps used on the VW "Sport" wheels offered on several different 70's models.
I would appreciate hearing from anyone that has encountered this issue. The wheels are going on a 1976 standard bug, so originality is not an issue. I just need to cover the wheel center holes at a reasonable cost. Thanks! |
Starbucket Samba Member
Posted: Thu Oct 11, 2018 1:51 pm Post subject: Re: 1972 Beetle Baja SE wheel center caps |
Try Summit racing search "wheel center caps". |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Oct 11, 2018 7:00 pm Post subject: Re: 1972 Beetle Baja SE wheel center caps |
I have a set of the center caps, what retains them? A special lug bolt or the plastic cap that goes over the bolt? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Oct 11, 2018 7:22 pm Post subject: Re: 1972 Beetle Baja SE wheel center caps |
The real ones (stainless cups)?, or those flat Brazilian caps that cover the whole bolt area that everyone sold 20 years ago?
Real ones had a thin O ring on them and went in from the back IIRC. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Oct 11, 2018 7:34 pm Post subject: Re: 1972 Beetle Baja SE wheel center caps |
TDCTDI wrote: |
I have a set of the center caps, what retains them? A special lug bolt or the plastic cap that goes over the bolt? |
Here are the photos of the washers that hold the center cap in place. 2 per wheel.
_________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Posted: Fri Oct 12, 2018 4:40 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
Thanks to everyone for the feedback. Very helpful! |
gt1953 Samba Member
Posted: Fri Oct 12, 2018 6:54 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
Every once and a while they show up and even on craiglist. Some time reasonable too. I found some in the classifieds a few years ago before they became gold plated prices. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Oct 12, 2018 8:48 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
If you're a real cheap ass, you can trim down some red SOLO cups & paint them black. If you're a real tightwad, you'll recycle them out of the trash. They stick out a bit far & you might be able to find another cheap plastic cup that fits better. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Nov 02, 2018 2:41 pm Post subject: Re: 1972 Beetle Baja SE wheel center caps |
APPLEGREENVW wrote: |
TDCTDI wrote: |
Where can I get these washers? I got a new set of these center caps but no washers came with them. Two of the four holes are molded to engage the lug bolt, but torqueing the bolts down on plastic makes no sense. |
Posted: Wed Feb 27, 2019 4:51 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
Can you share the details of how the retaining washers were made? Thx |
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Thu Feb 28, 2019 9:33 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
Why not try a readily available aftermarket center cap, normally used for a stock wheel?
Posted: Sun Sep 13, 2020 9:32 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
The "readily available" center caps used on the Sport wheels do not work on the Baja wheels. The center cap hole on the Baja wheel is a relatively unique, hard to find size -80 mm. I found some caps that fit, however they do not have the VW logo in the center.
Back to the original question - does anyone know where i can get the washers needed to mount the Brazilian VW center caps as suggested earlier???? I prefer how these center caps look mounted on the Baja 10 spoke wheel. I do not have the means to fabricate the washers shown in an earlier post on this topic, which appear to be exactly what is needed to safely and securely mount these center caps. |
PDX_VW_Erik Samba Member
Joined: November 15, 2015 Posts: 199 Location: Oregon
Posted: Sun Sep 13, 2020 11:18 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
TDCTDI wrote: |
If you're a real cheap ass, you can trim down some red SOLO cups & paint them black. If you're a real tightwad, you'll recycle them out of the trash. They stick out a bit far & you might be able to find another cheap plastic cup that fits better. |
vamram Samba Member
Posted: Sun Sep 13, 2020 11:52 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
These pop/clip in, no washers. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
gt1953 Samba Member
Posted: Mon Sep 14, 2020 7:06 am Post subject: Re: 1972 Beetle Baja SE wheel center caps |
I used the plastic center caps for some time till the real deal ones showed up here in the classifieds. I was lucky to have a spare one.
Wow just looked at the classifieds. Pricey for those. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
