What year did parking bulb move from reflector to bottom of can?
sonoma_vw
sonoma_vw is offline
PostPosted: Tue Oct 30, 2018 12:13 pm    Post subject: What year did parking bulb move from reflector to bottom of can? Reply with quote
How can you tell what pre-focus headlamp assemblies will have the smaller parking light within the reflector? (Cause you can't tell when the unit is assembled.) One type it is within the reflector next to the center main bulb, and another style is at the bottom of the can by the 3 drain holes (which I assume is a younger version).
Here's a unit listed for the 1300 style car. It had the parking bulb at the bottom of the can (near the 3 drain holes).
...vs reflectors that had small holes adjacent to the center of the reflector.
janerick3
janerick3 is offline
PostPosted: Fri Nov 02, 2018 1:25 pm    Post subject: Re: What year did parking bulb move from reflector to bottom of can? Reply with quote
Euro (rest of world) headlights will have the parking light bulb inside the reflector.
It's possible these are universal-fit assemblies, assuming the buckets are NOS Bosch and not repainted U.S. market Hella buckets.
The date code on the box is "922," which translates to Feb 1979.
Thanks,
Jan K.
finster
finster is offline
PostPosted: Sat Nov 03, 2018 6:13 am    Post subject: Re: What year did parking bulb move from reflector to bottom of can? Reply with quote
Keith Seume's vw book says that from april 1955 US beetles were fitted with headlamps that had clear outer glass and a parking light (the bulb at the bottom of the can).
sonoma_vw
PostPosted: Sat Nov 03, 2018 11:20 am    Post subject: Re: What year did parking bulb move from reflector to bottom of can? Reply with quote
Good info, thank you.
So if we fast forward to 1960, a Euro model Bug would still have the "city" or "position" light bulb (what I've been told that small bulb is referred to across the pond) still resides within the reflector. Yes?
finster
finster is offline
PostPosted: Sat Nov 03, 2018 12:28 pm    Post subject: Re: What year did parking bulb move from reflector to bottom of can? Reply with quote
yes, in the UK we would call them sidelights, I don't think we ever had the US style over here until the 80s - 90s cal-look trend of removing the wing-top indicators and using the parking lights as indicators.
