74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Tue Nov 06, 2018 7:04 am Post subject: Weber 40s leak from throttle shaft after shutdown |
So I've noticed that if I go on a long drive, my dual weber 40's seem to seep a little and drip on my engine tin after the engine has been shut down. It doesn't happen quick, it usually takes about 5 minutes or so for it to actually show up. Any ideas? I've check my floats and my fuel pressure.
1980 Vanagon, type iv dual weber 40s _________________ 73 Thing
80 Vanagon Westy |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Nov 06, 2018 7:14 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
your fuel is boiling in the float bowls,, can be fixed by installing some insulating gasket 's search the subject _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Tue Nov 06, 2018 8:41 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
Any other options other than phenolic? I have access to lexan, kydex, and composite at work.. _________________ 73 Thing
80 Vanagon Westy |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Nov 06, 2018 11:55 pm Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
Whats your fuel pressure at?
Jetting?
Distributor? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Nov 07, 2018 3:54 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
udidwht wrote: |
Jetting?
Distributor? |
3.5psi , 1.25 main, centrifugal dizzy _________________ 73 Thing
80 Vanagon Westy |
Posted: Wed Nov 07, 2018 4:32 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
Don't know if Lexan will work?
might just try a cheap electric fuel pump _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Thu Nov 08, 2018 5:02 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
How much fuel are we talking about here?
It isn't entirely unusual for Webers to do this after shutdown.
You will end up with fuel on the outside of these carbs. That's a given.
Float height correct? 10-11.5mm with gasket in place ball NOT depressed.
Fuel pressure 3.5 max?
Carb top gaskets not blocking air bleed holes? _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Thu Nov 08, 2018 6:24 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
" Carb top gaskets not blocking air bleed holes? " X2 on this one. Sometimes when the gaskets are punched out, the vent/bleed holes still have the blanks left in the gasket, and this will cause fuel to siphon out of the bowls and down the venturi, where it can bleed out the throttle shafts. Only happens 5-10 minutes after shutdown, when the fuel heats up. |
Posted: Thu Nov 08, 2018 6:26 am Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
Posted: Wed Jan 02, 2019 1:52 pm Post subject: Re: Weber 40s leak from throttle shaft after shutdown |
Update: Phenolic blocks installed, no more issues. It was the manifolds heating my carbs after shutdown _________________ 73 Thing
80 Vanagon Westy |
