BJT Samba Member
Posted: Mon Oct 22, 2018 5:26 pm Post subject: New exhaust, rubbing on bumper |
Installed a nice looking exhaust that exits out the bumper, as a Thing exhaust should, however, the exhaust isn’t quite straight out the center of the bumper holes and rubs badly on the bumper. I’m looking for a silicone/ high temp rubber grommet to put around the bumper exit, has anyone found such a thing or have any other recommendations? Thanks |
Posted: Mon Oct 22, 2018 6:40 pm Post subject: Re: New exhaust, rubbing on bumper |
The engine moves around a lot as various torques are applied so the pipes need to be pretty well centered in the holes. If you don't have a friend with a torch and/or welder who can fix it for you take it in to your local muffler shop.
Of course you should contact the vendor and manufacture first. |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Oct 22, 2018 7:20 pm Post subject: Re: New exhaust, rubbing on bumper |
Since our cars are not built perfect some parts must be fitted. Motor mounts, age, bumper not centered, etc. Try putting a pipe in the tail pipe and move it in place. We have had to do this before. |
BJT Samba Member
Posted: Tue Oct 23, 2018 7:29 am Post subject: Re: New exhaust, rubbing on bumper |
Well, I bought the exhaust for cheap from a local shop, so no idea who the manufacturer is, might try the pipe in the exhaust to bend it a little, don’t know any welders or such. I have seen a pic of a California Thing with a rubber piece around the bumper hole, but no clue where the got that or what it’s made out of. |
BJT Samba Member
Posted: Sat Oct 27, 2018 6:37 am Post subject: Re: New exhaust, rubbing on bumper |
Found something that may work. Time will tell how it holds up to heat. Looks decent though and quiets the bouncing.
lowsquare Samba Member
Joined: May 29, 2004 Posts: 287 Location: Queen Creek, AZ
Posted: Sun Oct 28, 2018 9:59 pm Post subject: Re: New exhaust, rubbing on bumper |
All I know is that the exhaust gets pretty dang hot. I suspect it's gonna melt those rubber pieces in no time.
Not sure if you can see it or not but I was running a tri-mil exhaust and it was hot enough to melt the rubber on the inside face of those bumper stops.
_________________ PRAISE THE LOWERED.
1973 THING |
BJT Samba Member
Posted: Tue Oct 30, 2018 4:02 pm Post subject: Re: New exhaust, rubbing on bumper |
Just drove around for an hour, no sign of burning or melting of the rubber. The chrome extensions actually stay relatively cool, compared to the actual pipes... plus they are made of a pretty heavy rubber. Completely eliminated the banging noise. Problem solved! |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Tue Oct 30, 2018 6:00 pm Post subject: Re: New exhaust, rubbing on bumper |
Those grommets look nice. Mine bangs a little in reverse, ok going forward. |
74 Thing Samba Member
Posted: Tue Oct 30, 2018 7:08 pm Post subject: Re: New exhaust, rubbing on bumper |
Where did you get that grommet? |
BJT Samba Member
BJT Samba Member
Posted: Sat Nov 10, 2018 8:27 pm Post subject: Re: New exhaust, rubbing on bumper |
Just as a follow-up. Drove from Chicago area to St Louis area today, about 6-7 hours driving, only stopped for gas, grommets showed zero wear/melt. Granted it was 7 degrees outside when I left so everything was a tad cooler, but grommets are working good |
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Tue Dec 18, 2018 1:05 am Post subject: Re: New exhaust, rubbing on bumper |
BJT wrote: |
Thanks for the update. Just ordered a set for myself, and your link worked great! _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
