markdam Samba Member
Posted: Sat Nov 10, 2018 7:58 pm Post subject: Body seal suggestions |
My dune buggy was missing the seal that goes over the camel hump in front where the body meets the pan. I have a little bit of a gap there and I'm not planning on unbolting the body but I would like to seal it.
Any suggestions as for what product would be in durable yet flexible sealant in that little Gap
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Nov 10, 2018 8:06 pm Post subject: Re: Body seal suggestions |
Silicone RTV....
Small size....
Or large size...
Comes in white, black and clear and some other colors... Bonds well to clean surface and remains flexible... Several brands and different types for almost any application... Paint section of hardware or big box store...
Posted: Sat Nov 10, 2018 9:02 pm Post subject: Re: Body seal suggestions |
Excellent that was what my first thought was but I thought maybe there was some new high-tech polymer fiberglass Steel resin 5 part 21st century stuff LOL good old silicone it is |
Tha Driver Samba Member
Posted: Sun Nov 11, 2018 1:07 am Post subject: Re: Body seal suggestions |
I would use windshield urethane. Sticks better, seals better, & tough as nails (but still flexible).
Just make sure you have some lacquer thinner for cleanup, & use gloves. _________________ ~ Paul
aka "Tha Driver" |
62kellison Samba Member
Posted: Sun Nov 11, 2018 6:18 am Post subject: Re: Body seal suggestions |
markdam ,x2 what Dale suggested.I used it with a caulk gun.its working great.Sean... |
joescoolcustoms Samba Member
Posted: Sun Nov 11, 2018 8:08 am Post subject: Re: Body seal suggestions |
I used to seal mine with either a silicone based material or a Mastic like windshield material. That all ended rather abruptly when I had to take a body off the chassis for chassis repairs. Spent hours cutting it, cleaning it up again, and suffered slight damage to the body.
I know, "I will never remove this body again". But when the owner strips the torsion splines in the rear torsion housing, the only way to repair it is to strip the chassis down bare and do it.
I now only use the stock VW pan seal on the sides. For the front and rear, I use the foam tape that fill the gap between 1/8 inch and 3/4 inch. At the 4 meeting points is the only place I use sealer, and very little.
You never know what the future holds, so try to make it more maintenance friendly. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Nov 11, 2018 10:29 am Post subject: Re: Body seal suggestions |
I used foam weatherstrip to act as a backer and then silicone. Urethane is great, BUT very hard to get apart. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Nov 11, 2018 10:48 am Post subject: Re: Body seal suggestions |
andk5591 wrote: |
I used foam weatherstrip to act as a backer and then silicone. Urethane is great, BUT very hard to get apart. |
You use this method with the body already installed or while putting the body on? Did you just tuck the weather stripping to the Gap? |
rodjr Samba Member
Joined: October 12, 2015 Posts: 223 Location: stanwood washington
Posted: Sun Nov 11, 2018 2:07 pm Post subject: Re: Body seal suggestions |
markdam wrote: |
andk5591 wrote: |
This was a new Berrien body. I had done the regular seal down the side, but was totally bummed about the fit on the front and rear. The rear was quite a bit of fabrication and was done before setting the body. The front was more of a gap than I was commfortable willing with just sealer, so I jammed some weatherstrip in the gap to provide a backing and then caulked inside and out . _________________ D-Dubya Manx clone - 63 Short pan,1914.
