Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Mon Nov 05, 2018 10:34 am Post subject: Re: What did you do to your Beetle this week? |
Restored the windshield wiper assembly for my 66 Bahama Blue project car. Disassembled it a while back (after taking LOTS of photos so I'd remember how to put it back together!!) and then ordered some small replacement parts from Wolfsburg West: nylon bushings, some tiny c-clips, rubber grommets, etc. I soaked the parts (except for the motor, of course) in a vinegar / water solution for a couple of days to remove the rust; then wire-brushed them clean; primed them and then painted with semi-gloss Rustoleum black spraycan paint. The re-assembly went fairly smooth (thanks to the reference pics!!) ...only problem was with the 4 nylon bushings: they were VERY tight on the posts, so once I had pressed them into the connecting arms, I had to ream them out with an electric drill and small bit to get them to fit on the pivot mounting posts. I figured if they were too tight it would put undue strain on the 52 year old wiper motor. Now I see what guys charge so much for reconditioned assemblies: all told it took me about 5 hours to complete the work, plus parts costs (not including paint drying time) !!
_________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Thu Nov 08, 2018 3:02 pm Post subject: Re: What did you do to your Beetle this week? |
Took it for an 80 mile run today. Perfect fall day _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu Nov 08, 2018 6:15 pm Post subject: Re: What did you do to your Beetle this week? |
Fall tune up. Oil change, valve adjustment, spark plug gapping and cleaning, belt check, dwell gap adjustment, distributor lube, fuel pump screen check, timing, brake adjustment, silly smile test drive. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9762 Location: Oregon
Posted: Sun Nov 11, 2018 4:44 pm Post subject: Re: What did you do to your Beetle this week? |
Fixed my 67 backup lights. It was a bugger to see backing up in my driveway in the morning.
Then to celebrate. I took the car for a drive in the country.
Have a great week. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2661 Location: Long Island, NY
Posted: Sun Nov 11, 2018 8:10 pm Post subject: Re: What did you do to your Beetle this week? |
Got the bug running properly after 4 months (weekends only) of searching for the problem.
Problem was the condenser, but I had installed the replacement incorrectly, replicating the problem with the first one.
Once I got that fixed, I reset the accelerator pump diaphragm, did an oil change, and now I'm all set for a few weeks of driving before it's put away before the snow. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Sat Nov 17, 2018 5:39 pm Post subject: Re: What did you do to your Beetle this week? |
Took my 59 and my beautiful wife out for lunch at DQ and a short drive. Gave the car its first oil change. Must have all of 50 miles on it now!!
BTW what is the easiest way to drain the oil from fan shroud mounted Fram filter on my Okrasa build)
Bruce
Oct 58 Capri Blue sunroof
fjar226 Samba Member
Joined: March 20, 2016 Posts: 7 Location: Houston Texas
Posted: Sun Nov 18, 2018 8:15 am Post subject: Re: What did you do to your Beetle this week? |
Did a brake job on all 4 wheels ,,changed out the wheel bearing on the front spindles .... things still mto do is install wiper assy, drop the ass 2 inches ,buy and install exhaust |
Posted: Sun Nov 18, 2018 12:33 pm Post subject: Re: What did you do to your Beetle this week? |
After getting 'er running last weekend, this week I had a starter system failure. Currently in the process of sorting it out. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Mon Nov 19, 2018 7:06 pm Post subject: Re: What did you do to your Beetle this week? |
I gave it new front wheel bearings and grease seals. The weird thing is the driver side is popping my dust cap off. When I removed the drum my grease cap was off and the bearing was stuck on the spindle. I guess I better smooth that out. |
Mark.P Samba Member
Joined: November 16, 2018 Posts: 2 Location: NORTHAMPTON
Posted: Tue Nov 20, 2018 3:50 pm Post subject: Re: What did you do to your Beetle this week? |
I've finished biulding a third cave so I can start my vert resto project
Cave one now houses my 66 spit screen camper ( Gerry )
cave two & three now houses the new project 66 vert that need full resto
OOOOO and by the way this is my first ever post on here ... so hello everyone
IMG_1252.JPG |
REDKAFER Samba Member
Posted: Sun Dec 09, 2018 8:46 pm Post subject: Re: What did you do to your Beetle this week? |
Alternator issues were giving me a headache, so instead of trying to sort out the integrated regulator I scrapped that and went back to a generator. All sorted and ready to take on the winter. Also, all lights with the exception of the headlights are now LED... HUGE improvement. For anyone thinking about that upgrade, they sell DOT-style flashers that are actually tiny compys for use with LED turn signal lamps. WAY better than wiring in resistors to prevent hyper-flash... |
Posted: Sun Dec 09, 2018 10:19 pm Post subject: Re: What did you do to your Beetle this week? |
REDKAFER wrote: |
Interesting info, but not very helpful. You need to include lots of details (brand names, sources, etc.). ...just saying.... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
BarnFine Samba Member
Posted: Mon Dec 31, 2018 4:13 pm Post subject: Re: What did you do to your Beetle this week? |
MeeferMadness wrote: |
Bruce
-snip- |
Really nice 59 ragtop, excellent work. As for the oil filter question, one method I use for draining oil without making a mess is fashion a drain or funnel out of the side of a cardboard box, it's really easy to fashion and bend how you want it. Then cover and glue down plastic wrap so it's easy to wipe off and reuse. |
67ctbug Samba Member
Posted: Mon Dec 31, 2018 4:48 pm Post subject: Re: What did you do to your Beetle this week? |
Not mine, but a buddy’s, learned how to drive stick in a ‘67. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
likestoparty Samba Member
Joined: April 27, 2011 Posts: 58 Location: Dallas, TX
Posted: Tue Jan 01, 2019 8:17 pm Post subject: Re: What did you do to your Beetle this week? |
I flat-dragged my '60 from Seattle to Dallas... Behind an '81 El Camino. This month is our 20th anniversary together, me and the Beetle. The Beetle did great, it is a previous veteran of a DC-to-Seattle crossing 7 years ago under its own power with zero breakdowns.
I made the towing lights the night before we left out of two Tupperware containers, a Harbor Freight trailer harness, a spare set of pre-62 Beetle tail light assemblies, and two Barbie doll heads as rubber bumpers on the roof.
The El Camino is actually a rarer GMC version badged as a Cabellero with the Amarillo package. I replaced the dumb standard shocks it came with with factory-correct air shocks that really helped with stability back there. My girlfriend and I traded her Honda Civic for it, and that started a murderous 3 months of me suddenly becoming an American car restorer. The right lower ball joint failed on us on our way home from acquiring it, 5 miles into owning it! You haven't lived until you find yourself suddenly grinding a layer of asphalt off of an elevated downtown Seattle waterfront viaduct at 50mph. I fixed that, only to find it devoid of coolant with breaches in both head gaskets. I tore the engine down and fixed THAT myself, too. Helluva introduction to water-cooled cars, man.
Anyway, there's too many little stories to tell here about the 5-day, 2700 mile journey to spin here now, but the most unbelievable was randomly running into my pals in the NYC ska band The Slackers from my days in The Pietasters, in the middle of NOWHERE California!
We made it! Only one pit-stop to replace a worn-out center link in the steering that made navigating through Tacoma, WA hair-raising.
And then I flew back to Seattle 3 days later to make the same trip in our 1980 Dodge TranStar RV, converted into a moving van filled with our belongings. 5400 miles of sheer terror this month! _________________ 1960 Beetle - 1600SP - DC-to-Seattle Coast-to-Coast Veteran - Flat towed behind an El Camino Seattle-to-Dallas Dec. 2018. Daily Driven 50 miles every day. |
aam76 Samba Member
Joined: February 24, 2012 Posts: 131 Location: Houston
Posted: Fri Jan 04, 2019 10:25 am Post subject: Re: What did you do to your Beetle this week? |
Removed more of the old primer to reveal OG paint. Paprika red 1960 Vert.
a.marscapone Samba Member
Joined: May 08, 2017 Posts: 107 Location: The Quiet Corner, CT
Posted: Tue Jan 08, 2019 7:37 pm Post subject: Re: What did you do to your Beetle this week? |
Fixed my driving/fog lights and replaced bulbs with LEDs
kevzo1 Samba Member
Joined: February 10, 2016 Posts: 9 Location: Sebastopol, Ca
Posted: Thu Jan 10, 2019 3:23 pm Post subject: Re: What did you do to your Beetle this week? |
Refurbished the windshield washer switch on my 66
Krink Samba Member
Joined: October 14, 2018 Posts: 31 Location: Oldsmar, Fl
Posted: Wed Jan 16, 2019 3:38 pm Post subject: Re: What did you do to your Beetle this week? |
Bought it.
1962 Beryl Green. Needs some TLC and is going to get it.
TonyB Samba Member
Joined: December 11, 2018 Posts: 173 Location: Kansas
Posted: Sat Jan 26, 2019 9:10 pm Post subject: Re: What did you do to your Beetle this week? |
I put a Bosch Blue Coil and an EMPI distributor with centrifical advance and electronic ignition in this 1972 dual port 1600 and made sure it was working correctly
Then pulled the engine ...
And put it in my '62 Baja Ragtop
I've got dual carbs for it but am waiting for my headers/exhaust to show up before installing them |
