Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sat Nov 10, 2018 7:38 pm Post subject: Tie Rod End Installation |
I am fitting new ends to the tie rods while they are off the car and neither the tie rods or the ends have flats where I can wrench on. I am trying to do it in a vice using vice grips and so far I have split both the rubbers on my vice jaw guards in half by tightening the vice so much and have damaged a boot on one of the new tie rod ends.
I have used antisize on the threads and they are all turned into the thread so properly but I cannot get them to go in far enough to be close to the correct length. Can someone advise (a) why the f@ck anyone would make tie rods and ends without flats to allow them to be fitted and (b) how I am supposed to do this? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sat Nov 10, 2018 8:28 pm Post subject: Re: Tie Rod End Installation |
Umm, either put them back in the car, loosen the lock nut & lock clamp & turn the tie rod, or, slip the box end of a wrench over the tapered stud, put the nut on & twist the end off that way. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Sat Nov 10, 2018 8:33 pm Post subject: Re: Tie Rod End Installation |
And... Correct me if I'm wrong, it's been a while since I installed mine... But one side, loosening it actually tightens it. Lefty tighty, righty loosey sort of speak. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sat Nov 10, 2018 8:51 pm Post subject: Re: Tie Rod End Installation |
xzener wrote: |
And... Correct me if I'm wrong, it's been a while since I installed mine... But one side, loosening it actually tightens it. Lefty tighty, righty loosey sort of speak. |
This is correct, one end on each tie rod is left hand thread so that you can turn the tie rod to adjust the length. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
slalombuggy Samba Member
Posted: Sun Nov 11, 2018 6:44 am Post subject: Re: Tie Rod End Installation |
Did you compare the length and threaded section on the old and new parts? Some parts come with a shorter body but longer threaded section so they have to bw turned in more. Unfortunarely 50 years or ruat accumulates on the threads unside the shaft.
To be honest. This is why i just replace the entire tierod assembly.
brad |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Mon Nov 12, 2018 4:09 pm Post subject: Re: Tie Rod End Installation |
They really should turn by hand fairly easily.
I just replaced mine as well. With the locknuts and clamps loose, you should be able to turn the rod by hand to set the toe.
Yes one side of each tie rod is left hand thread. _________________ Volkswagen!
(Compression 8.7:1) |
carguytroy Samba Member
Posted: Mon Nov 12, 2018 5:09 pm Post subject: Re: Tie Rod End Installation |
Mellow Yellow 74 wrote: |
I have used antisize on the threads and they are all turned into the thread so properly but I cannot get them to go in far enough to be close to the correct length. Can someone advise (a) why the f@ck anyone would make tie rods and ends without flats to allow them to be fitted and (b) how I am supposed to do this? |
Flats so you can put a wrench on them I guess? Pipe wrench would work if they are just round. I just replaced steering stuff on the 68. Went with all new parts. 50 year old car with 50 year old parts and 50 years of rust. Seemed to make more sense to just replace the whole thing rather than fight with getting them apart. |
