vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Thu Aug 10, 2017 5:59 pm Post subject: Re: 1964 "Barn Find" |
It's working good so far. I still need to tweak the adjustments because there's a slight grind going into reverse and 2nd gear takes a little finesse to find.
I've got an autostick in my trike. They do drive pretty similar. But there's no skipping gears with the Saxomat, you definitely need to start out in first. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Aug 10, 2017 6:32 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
Yes, the torque converter is a definite advantage on the autostick. I liked drivng it in city traffic ... no shifting. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sun Aug 20, 2017 8:41 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
Took the Bug to Symco Weekender a traditional hot rod and kustom show. Only pre-'65 period correct cars are allowed. No trophies are awarded, just getting in is the prize. Since they aren't familiar with VWs, I had to show them my vehicle registration to prove it's a '64.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9769 Location: Oregon
Posted: Mon Aug 21, 2017 4:42 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
I have what looks like a Saxomat user/installation manual. It outlines adjustments and the like. It's very detailed for all of it's 16 pages. Including one that was hand typed and stapled to the trouble shooting page
It's copyright date is 1/61.
I have no use for it other than it was the right price at the right time. So I bought it thinking of this thread.
Nice that the Saxomat serves your special needs. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Oct 03, 2017 5:49 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
Since I drive the car after dark on occasion, I decided to upgrade the headlights. I went with Autopal Cibie z-beam knock-offs, because I wanted the OEM look curved glass, and after searching a bit found some LED h4 replacements that work on 6 volts. Now I can see at night.
Posted: Mon Nov 12, 2018 11:31 am Post subject: Re: 1964 "Barn Find" now with Saxomat |
Looks like it's been awhile since I've updated this thread. I haven't done much work in the last year, just mostly driving it.
I added a dimmer switch from a '66 to the turn signal, since I can't operate the foot switch.
I fabricated a set of hand controls that look a little more period correct.
I really wanted to save the '64 only seat upholstery, but it was getting pretty bad from regular use. I recovered them with TMI covers and pads.
A roof rack popped up for sale on craigslist, so I picked that up along with a bunch of VW tools (the guy used to be a VW mechanic back in the day).
That brings everything up to date. I've been gathering parts for a big bore 40hp, so hopefully I can put that together this winter. _________________ Kenneth
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Tue Nov 13, 2018 7:15 am Post subject: Re: 1964 "Barn Find" now with Saxomat |
Looks awesome, that rack matches the car perfectly! Pardon my ignorance, but how do the hand controls work? It looks like the throttle twists like a motorcycle, and the whole lever moves forward to operate the brake? _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Posted: Tue Nov 13, 2018 3:23 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
vwuberalles wrote: |
Looks awesome, that rack matches the car perfectly! Pardon my ignorance, but how do the hand controls work? It looks like the throttle twists like a motorcycle, and the whole lever moves forward to operate the brake? |
That is correct. _________________ Kenneth
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Nov 13, 2018 3:45 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
vwfreek61 wrote: |
It looks like you swapped the high and low beam wires at the fusebox. White-to-yellow is wrong. Swap the short wires from the relay to the fusebox and you'll be set.
White is high beam, yellow is low. And the dash light should go to the white. |
Posted: Tue Nov 13, 2018 4:14 pm Post subject: Re: 1964 "Barn Find" now with Saxomat |
KTPhil wrote: |
Even though it didn't look right to me, I wired it according to the '66 wiring diagram which has the colors reversed. After the picture was taken, I swapped them around and now it looks proper. _________________ Kenneth
