tsimek2 Samba Member
Joined: September 07, 2017 Posts: 27 Location: High Point, NC
Posted: Wed Nov 14, 2018 3:54 am Post subject: '65 1500 Crankshaft Play |
I have a 65 1500 type 2 early bus case that came with a beat up dune buggy I bought for $600.
When I opened up the case, the crank shaft was completely sheared. I got a type 2 crankshaft and new bearings and realize I have about 1/4" play in the axial direction.
Does this mean that my case is screwed or can this be fixed?
Thank you, |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Nov 14, 2018 4:08 am Post subject: Re: '65 1500 Crankshaft Play |
Probably better placed in the performance/engine forum but sounds like you will need the case thrust cut. As someone who has used a 1500 case and gone through this, I would probably suggest looking for another case. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Nov 14, 2018 9:13 am Post subject: Re: '65 1500 Crankshaft Play |
tsimek2 wrote: |
Does this mean that my case is screwed or can this be fixed?Thank you, |
Depends.. on a lot of factors..
Is the flywheel attached? The flywheel and shims are how thrust is set..
Did you check bearing to case fit ?
Did you measure for an oversize case and "line boring".
Did you check the thrust bearing surface for milling?
WAY too many variables when it comes to old antique VW engines just to assume .
The case can have line boring. . no thrust milling.. no line boring with thrust milling, both milled.. none milled. Worn out, overheated, warped.. you name it..
Measure.. re measure.. inspect and re inspect.. get a good VW engine repair book.. and read it .. twice
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Thu Nov 15, 2018 3:37 am Post subject: Re: '65 1500 Crankshaft Play |
Thank you for things to look for |
