everyhumanvw Samba Member
Joined: November 16, 2018 Posts: 44 Location: mICHIGAN
Posted: Fri Nov 16, 2018 3:58 pm Post subject: 1991 VW Syncro calipers and brakes question |
Getting a Syncro back up to snuff starting with the brakes. Was my dad's van here in Michigan and he did not do the underbody washes and drove it in winter. Have had several brake lines replaced. Brought some new old stock Girlings to my mechanic and found out the van must take the ATE calipers. Am wondering if I can get still get ATE calipers and carriers or if not what is best option for stock replacement. I also need the caliper carriers which the NOS Girlings did not come with.
Just found this at vanagain.com: "Most of the '86-91 Syncro Vanagons used the Girling Caliper. If you have a Syncro, my advice would be to just replace these in pairs. No one has any late ATE calipers that I know of. They are interchangeable as long as you replace them in pairs you are good to go." My mechanic seemed to not know or not think I could change out both of the ATE calipers with the NOS Girlings I have once carriers are found. Either way still need carriers and backing plates as they are also corroded. Were Girling or ATE calipers and carriers better? Any advice much appreciated!!!
Last edited by everyhumanvw on Sat Dec 01, 2018 12:53 pm; edited 1 time in total |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Fri Nov 16, 2018 5:43 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
thanks, that looks like a 2015 ad but still sent message to inquire.
I think I found that ATE calipers can be directly swapped with Girling model. May require different carrier. Same backing plates and all else I think and hope
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Fri Nov 16, 2018 5:57 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
I can verify as long as you have complete calipers with their mounting brackets they will fit on a late model Syncro I installed some on mine many years ago when I re built my brakes. I did have a little issue on one wheel that had some corrosion causing a reduced diameter a little wire wheeling and the slight clicking went away. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work |
Posted: Fri Nov 16, 2018 6:42 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
everyhumanvw wrote: |
No that was the date he joined the forum. The ad was just renewed a few days ago. |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Fri Nov 16, 2018 8:51 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
Talk about timing...I am also just doing the brakes on my 1988 Syncro. Took everything apart today.
The caliper piston is rather rusted and the dust boot is very dry. I called around for a set of calipers - $51 each. At this price I am just going to replace them.
But the guy asked if I had ATE or Girling.
I went with Girling...I could not find a 'G' on them, nor an ATE. Just a VW/Audi logo, a MO. I am hoping it's the correct one. I'll take a picture tomorrow and post it up. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Sat Nov 17, 2018 3:54 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
The guide pins areas are the obvious visual difference. The Girling has 2 plainly visible 13mm head m8 bolts that attach the caliper at the guides.
The ATE has no such bolts, but the 2 ATE guide pins have allen socket holes for removing the pins from the ATE carrier. There are usually rubber plugs hiding the allen holes.
VW Parts shows the ATE fitted beginning in 1989 model year.
This is another omission from the Bentley, nothing about the late ATE calipers.
Above is for 86+ calipers.
Mark |
Posted: Sat Nov 17, 2018 7:33 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
Here are some from my '89 Model Year Syncro van with a mfg date of 6/88.
Posted: Sat Nov 17, 2018 8:03 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
Do you know if these are Girling or ATE? they look identical to mine. |
Posted: Sat Nov 17, 2018 8:05 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
crazyvwvanman wrote: |
Mark |
Based on your description, it looks like I have ATE. However my Syncro is a 1988. Perhaps they were swapped later. |
Posted: Sat Nov 17, 2018 8:07 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
Those are ATE. See the small allen bolt holes in the guide pins.
(also the stylized ATE cast in the top like the VW)
VW Parts says at start of 89 model year for 2wd.
I didn't check Syncros, which were built in a different factory/country until the near very end.
EDIT: just checked Syncros, VW says ATE starting late in 88 model year.
88 vin# 105001 and later. Very last of 88 Syncro production.
Of course 89 model production began in summer of 88 so you have to check the VIN year letter to see actual MODEL year,
J=88
K=89
Mark |
Posted: Sat Nov 17, 2018 3:28 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
Yes I do have ATE - now I know for sure. I went to NAPA and look it up.
Duh, I just realized my Syncro is 1989, not 88.
VIN is WV2YB025XKG000279
Now it all makes sense...
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sun Nov 18, 2018 9:03 am Post subject: Re: 1991 VW Syncro calipers and brakes question |
SyncroChrick wrote: |
Yeah they all look the same!
My 91 has Girling G60 single pucks on it as opposed to the ATE57.
Looks almost the same, but sure the mounting holes to the carrier are different.
The 3mm difference your not going to notice and ATE has been stopping cars just as good as Girling's. _________________ This free advice is worth exactly what you paid for it.
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Mon Dec 03, 2018 6:53 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
What caliper do you have on there now?
The Girling is a single puck 60mm dia.
The ATe is a single puck probably a 57mm dia.
(You will not feel the difference between 60 and 57mm dia. It much like stereo equipment quoting sound frequencies only a dog can hear.)
Keep it the way you found it. Both ATE and Girling brakes have been around a long long time and it's usualy the driver beng the reason the brakes don't work.
Rockauto.com has the same calipers going for 25-45 bucks.
If you do decide to change make sure the ones you buy have the carriers coming with them. _________________ This free advice is worth exactly what you paid for it.
Posted: Sun Mar 24, 2019 4:42 pm Post subject: Re: 1991 VW Syncro calipers and brakes question |
UPDATE NEARLY 4 MONTHS LATER: Still waiting on ATE caliper and bracket rebuilds from Summit Racing.
Someone above says these Audi ATE brake calipers from RockAuto fit, but they look different and part number different.
https://www.rockauto.com/en/moreinfo.php?pk=2039832&cc=1411311&jsn=555[/url]
So, seems best option is to swap out to Girling calipers and brackets with guide pin bolts. |
