Nico2 Samba Member
Joined: January 06, 2017 Posts: 12 Location: Fair Oaks, CA
Posted: Sat Nov 17, 2018 8:32 am Post subject: Super beetle strut mount - broken ring |
On my 1977 super convert I noticed a broken ring (stop ring??) on the strut mount. Is this an issue, do I need to replace?
If so, replace just the ring or the whole strut mount? Where do I get the ring-I looked around, doesn’t seem to be a typical spare part...
I also looked for replacing the strut mount, some run $40, others up to $75 a piece....
Anyone having a recommendation for a good source for a decent part?
Thanks much,
Nico |
vwoldbug Samba Member
Posted: Sat Nov 17, 2018 8:59 am Post subject: Re: Super beetle strut mount - broken ring |
Do you know where that one came from ( don't buy there ) . Contact Topline . |
Nico2 Samba Member
Posted: Sat Nov 17, 2018 9:03 am Post subject: Re: Super beetle strut mount - broken ring |
No, came with the car when I bought it. Other side is fine, but I will also replace!! |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1291 Location: Modesto, CA
Posted: Sat Nov 17, 2018 9:51 am Post subject: Re: Super beetle strut mount - broken ring |
All they do is provide less than metal to metal contact when/if your car goes over a bump causing the suspension fully extend. You could live without them(the ring). I would wait to replace until it was needed, but thats just me. Topline sells the same upper strut mounts everyone else does.
On my coil overs, I used the rubber part of the mount from a VW Fox because its higher durometer. I actually ground off the part where that plastic ring attaches to give a bit more clearance for the top piece to spin more freely.
JohnL (aka H2OSB)
www.superbeetlesonly.com _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Nov 17, 2018 2:41 pm Post subject: Re: Super beetle strut mount - broken ring |
Don’t worry about it. It will still buffer between the two pieces of metal. It’s just a crack. If a section was broken from the ring, you might want to replace. But that crack won’t prevent the ring from doing its job.
It’s an OEM strut top, by the way.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Nico2 Samba Member
Posted: Sat Nov 17, 2018 4:40 pm Post subject: Re: Super beetle strut mount - broken ring |
Thanks everybody!!
Nothing to worry about, great!
I am going to replace all major front parts. Bushings, tie rods, ball joints.
Most concerned about the wheel alignment afterwards.
All really looks stock! Amazing after so many years!!
Thanks again for the fast responses!! |
Millertime610 Samba Member
Joined: September 12, 2019 Posts: 10 Location: Long Island, New York
Posted: Sat Mar 04, 2023 11:52 am Post subject: Re: Super beetle strut mount - broken ring |
Hey all!
Looking to service my struts on my SB and need some help!
From the upper shock mount to the body, for the 3 bolts, its a flat washer and a nylock nut. What size are those nuts? Its a 14mm wrench but no vendors seem to supply a set.
Are they 8mm/1.25 ? _________________ 08' Rabbit
72' Super - "Oscar" He's a bit grouchy... |
