Muftobration Samba Member
Posted: Mon Oct 22, 2018 7:28 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Quote: |
The big question is, since they appear to be directional with those blades are there two "lefts" and two "rights?" While I'm sure it does not affect the function, I'd want to see a pic of all four before deciding. |
I was intrigued as well. The ad showed four wheels, all identical. Google images also shows identical wheels, not two one way and two the other. |
flomulgator Samba Member
Joined: March 07, 2013 Posts: 950 Location: Leavenworth, WA
Posted: Tue Oct 23, 2018 9:41 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I didn't really think to notice that but yeah that's kind of odd. Logical though as if they had a proper right and left that would cost double to manufacture. I think these are a bit like a barely-functional rear wing, more of a homage to racing than functional. Turbine wheels in racing I believe were oriented such that they sucked air out from under the car at high speeds / rates of rotation thus increasing downforce. I believe they were banned and thus a short lived trend in motorsports, which would make sense as to why these are rare. My history here is shaky though, feel free to correct me. _________________ She's built like a steakhouse, but she handles like a bistro! |
HOPS Samba Member
Posted: Thu Nov 15, 2018 7:48 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Are there any wheels in 15 or 16" that the original chrome hub caps from the 14" fit onto? |
bogle Samba Member
Joined: November 28, 2018 Posts: 8 Location: San Antonio
Posted: Fri Nov 30, 2018 8:16 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Is it possible I found another wheel option? I have an '87 Syncro Westy, and am looking to move from the stock 14" steel set. Hoping to find a set of (5) steel or aluminum 16" wheels - 6.5" wide that I can snug into the clamshell.
I was sent the following from Joy City Tires:
"This is probably the closest wheel you'll find that's readily available:
http://www.rtxwheels.com/en/wheels/rtxwheels-stern-silver
16" x 7"
5x112
+35 offset
1488lb load rating
You can use a 5mm spacer if you want to get the offset lower.
They are $630 taxes included for four if you want them." |
Posted: Fri Nov 30, 2018 8:52 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
The 7.0” width is nice, most MB wheels are 7.5. However, that weight raising is pretty low for a syncro westy (although most wheels ratings are just manufacturer guesses) _________________ She's built like a steakhouse, but she handles like a bistro! |
goskiracer Samba Member
Joined: January 15, 2009 Posts: 339 Location: Oslo, Norway
Posted: Tue Dec 11, 2018 12:40 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
https://www.oponeo.co.uk/steel-wheel/alcar-kfz-9905#20370798
The Alcar steel wheels for MB popped up recently for me while looking for winter wheels.
7x16 33ET 66.5 mm centerbore
These are listed as compatible with the MB E-class so the weight checks out. At 800 kr a wheel here in Norway they are a bargain! _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
Marshj Samba Member
Posted: Fri Dec 21, 2018 5:27 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I’ve only seen a few of these, maybe 1 set on a Vanagon. New wheels on 1990 Multivan Westfalia pop top.
They are 5x112 and ET 45. Had to get the centerbore machined beyond 63mm
Have a 12mm spacer in the front ( could get away w 8-10mm ) and 7mm in the back. Very happy with how these Audi wheels turned out.
Thanks to a forum member, Zerin, for getting these to me.
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Tue Dec 25, 2018 11:13 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Those look great.
Marshj wrote: |
_________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Sun Dec 30, 2018 1:59 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Muftobration wrote: |
Can anyone identify what wheels these are? I think it's a nice style on the Vanagon.
Those look like Audi ultrasport wheels _________________ 91 CARAT |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Tue Jan 15, 2019 7:07 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
borninabus wrote: |
i want 15" rims and i'll just make this simple: what is the easiest (as in least amount of modifications) route?... |
i've decided that for my purposes eurovan steelies are the best choice.
i have the rims and am prepared to make the needed mods.
what size spacers will i need? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Vnyd Dog Samba Member
Posted: Mon Jan 21, 2019 9:02 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
OK flame suit on. At 153+ pages, I can't physically go through looking for the specifics of what I'm after. Does anyone (looking at Chris) know of a black 16" wheel, in the recommended offsets for 2WD non-lifted, in a width that properly supports a 215/65/16 A/T Tire? Is there perhaps an Audi/MB wheel that fits? Or is my best bet to find one of the Audi/MB wheels from literally page 1 and have them powdercoated Black?? Thanks! _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Tue Jan 22, 2019 5:43 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I use CLKs on my stock height '87 2WD Westy with 205/65R-16s. 215s might require spacers. Don't know.
I'd say get some CLKs and powdercoat them, as several users have done. _________________ '87 Westy in Wolfram Grey Metallic |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Tue Jan 22, 2019 7:53 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Vnyd Dog,
To narrow your search, you might want to know that the mentioned CLK rims are '98-'00. Expect five bills for 4 rims.. Unless you get lucky. Mostly, if you see an ad for a set of $200 CLKs you'll be the fourth caller, and the first caller will have them relisted a few weeks later for $500. Its not a pretty game. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Jan 22, 2019 8:32 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
bobbyblack wrote: |
Vnyd Dog,
To narrow your search, you might want to know that the mentioned CLK rims are '98-'00. Expect five bills for 4 rims.. Unless you get lucky. Mostly, if you see an ad for a set of $200 CLKs you'll be the fourth caller, and the first caller will have them relisted a few weeks later for $500. Its not a pretty game. |
Got it! Thank you for summarizing! Google just spit out all the Samba threads on CLK wheels so appreciate you guys and gals getting me pointed in the right, expensive direction. Are there still forged CLK wheels to be had?? Also, rather than overboring, why isn't it possible to do a stud conversion down to 12x1.5 studs rather than opening the wheels up to fit the 14? _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
Posted: Tue Jan 22, 2019 9:29 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Yes, and no.
Since they are limited scope of years, there are few left on the road. The ones that have been on the road are rashed, pitted or generally crap. When they do pop up on CL, they are a long way away, and some guy closer has them before you can say you want them. Then, you chat with the guy who got them, and he says he knew they were worth more, and was just buying them to sell them again. Then you see the same ones pop up on the CL in a couple weeks and they sit there staring you in the face for 6 months, at $500... I will pop you a note when he renews his ad again.. Also, they often come up here on the Samba, in the classifieds, about the same $'s.. Its a game of chance/checkers/chess/what a mess. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Jan 23, 2019 9:32 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
borninabus wrote: |
what size spacers will i need? |
well...finally took a look at the EV wheels that i have stashed and they are ET55 not ET44 like others i have seen. not really wanting to use 20mm spacers so the search continues... _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Marshj Samba Member
Posted: Sat Jan 26, 2019 8:06 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I have 16” VW Passat Wagon 7 spoke wheels on my ‘86 2wd that support that tire size. I have 5mm spacers all around and machines the centerbore to clear the hub. The hardest part was finding a local machine shop. I had to get longer studs and longer and correct lug from T3. $119
I have seen folks who have these same wheels blacked out, see Sychrogreg
stevw72 Samba Member
Posted: Sun Jan 27, 2019 1:33 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Pacafalia wrote: |
Will these fit on my 1989 2WD Westfalia? Late Model SLK
7JX16 ET 34.
What about grease cap? Will I need to buy deep custom center caps? [/img] |
Hi I seen that these wheels had been posted up before but the O/P never received any feedback regarding fitment ,I have acquired a set for a good price and wondering if they will fit straight on or will require to be modified ? _________________ this radio station was named KOWalski, in honor of the last American hero, to whom speed means freedom of the soul. The question is not when's he gonna stop, but who is gonna stop him. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun Jan 27, 2019 3:32 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Since you have a set,why not test fit one of them.
I'm not sure but I'm going to make some guesses anyway.
Center bore: Fine
Lug nuts: They may fit or they need to be drilled out, try test fitting and you'll know. If they don't fit over the lug nuts you need to drill them out to 14 mm.
You WILL (ok, probably) need small ball or other lug nuts/bolts. Do Not run these with the vanagon bolts/nuts.
Grease caps will not fit.
34 et will be fine without spacers as long as you don't get crazy wide tires.
Even 225 wide *should* be fine on the front as long as you don't put on snow chains, check the clearance from the inside of the tire and hardware. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
