vanatic Samba Member
Joined: November 17, 2007 Posts: 82 Location: Norman, OK
Posted: Sun Dec 02, 2018 8:18 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
Still hoping that some brave pioneer to come up with an awning window solution with integrated blind. |
Gruppe B Samba Member
Posted: Sun Dec 02, 2018 10:22 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
I saw this awhile back. I didn't think that they were a direct fitment. |
Posted: Sun Dec 02, 2018 10:36 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
vanatic wrote: |
Would be an easy install. Cut a piece of aluminum to the outside size of the stock window and then cut out the hole size to mount the new window in the aluminum.
Aluminum frame is fitted to the van using the stock window seal. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sun Dec 02, 2018 12:05 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
Seitz windows in the US would more exciting if their reputation was better and they had a model that would just drop in. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Dec 02, 2018 12:33 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
dobryan wrote: |
And ONLY $673... |
That might be $673CDN - about $50USD!!
I say might because (a) its a Canadian website and (b) the currency tab at the top of the page doesn't do anything... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Mon Dec 03, 2018 8:30 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
Gruppe B wrote: |
vanatic wrote: |
I've certainly thought about that but I'm hoping to avoid the multi layered approach. It would be easy but ugly. I may just weld in a panel. I'm due for seam repair and paint anyway. |
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
10degnorth Samba Member
Joined: March 07, 2018 Posts: 473 Location: Bend, Oregon
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Jan 11, 2024 7:15 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
No measurements, but I have this “before” pic from a jalousie install I did last fall…maybe it’ll help?
(Top front corner, driver side)
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
T3messie Samba Member
Joined: October 03, 2017 Posts: 209 Location: Germany
Posted: Fri Jan 12, 2024 2:36 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
43mm on the glass |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Jan 12, 2024 4:13 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
Has anyone seen this one yet?
Being sold for Landrover Defender rear window storage access.
Overall: L 1120mm (44.1") x W 50mm (2") x H 490mm (19.3")
Door Panel: L 1044mm (41.1") x H 414mm (16.3")
Out of stock of course, but at $1027.00 I can't see it flying off the shelf.
https://www.frontrunneroutfitters.com/en/us/front-...ender.html _________________ This free advice is worth exactly what you paid for it.
SnowDaySyncro Samba Member
Joined: August 31, 2006 Posts: 92 Location: Hartford, CT USA
Posted: Mon Jan 15, 2024 10:06 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
I traced the factory window to make a filler panel from prefinished black Dibond composite sign substrate and installed a CR Lawrence AW1033 window (purchased from Van Windows Direct) in a '84 Adventurewagen. While I do wish it was a bit larger and opened further, I'm very happy with what I consider to be a huge improvement over the OE sliding window. I'm actually making another one now for a tintop that incorporates electrical (and another TBD) hookup so that no holes are cut in the side of the body.
Posted: Mon Jan 15, 2024 11:33 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
That works! _________________ This free advice is worth exactly what you paid for it.
Posted: Mon Jan 15, 2024 4:29 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
Here's my current window insert project in progress, same CRL AW1033 window plus a pair of camper hookups from GW.
TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Posted: Tue Jan 16, 2024 5:42 pm Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
SnowDaySyncro- Those windows look great. Will you be offering them for sale
What is the material that goes around window? is it plastic or metal? lots of options for customization. _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
Posted: Wed Jan 17, 2024 9:48 am Post subject: Re: Flip Out Window or Louvered for Middle Center or Rear Sides |
TopBud wrote: |
What is the material that goes around window? is it plastic or metal? lots of options for customization. |
The panels are a product called MAXMETAL Lite, which is 3mm thick aluminum composite with a plastic core. Another brand name is DIBOND.
I added a layer of Peel & Seal to the inside so that it matches the 4mm thickness of the factory window for proper sealing. The inset window now has an available match from Van Windows Direct using the same model number AW1033 with VWD branding instead of CR Lawrence. It's a few bucks cheaper and quality reviews are good. My second CRL window wasn't as well-made as the first, so I plan on trying the VWD AW1033 next time around.
I got a 4x8 sheet for under $60 from a sign supply wholesaler through a friend who's in the business (I worked in a sign shop many years ago). Look for a sign supplier or sign shop in your area. It's available in black, white, and probably other colors as well. I have no plans or interest in producing them for sale. That said, I do have other window ideas that might eventually replace one of these, in which case, I'd list the take-out unit in the classifieds here. |
