Bigjacksauto Samba Member
Joined: June 18, 2018 Posts: 225 Location: Syracuse NY
Posted: Thu Dec 06, 2018 11:45 am Post subject: Sheet metal availability question inside above heater channel an |
I have looked all over and this sheet metal does not seem to be available anywhere ?
_________________ https://www.facebook.com/groups/2778888602388847/?ref=share
1968 Beetle "Herbie" replica Father Son Project
1960 Beetle deluxe / Flint/Pebble Grey og 1200cc 36hp
1975 Westfalia bus sold
1967 SO 42 Westfalia Bus
(o\_!_/o) |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Thu Dec 06, 2018 1:23 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
Thanks sadly I looked at that piece several times and thought that it went below that section, thanks again _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
(o\_!_/o)
Last edited by Bigjacksauto on Thu Dec 06, 2018 7:26 pm; edited 2 times in total |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Thu Dec 06, 2018 1:56 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
Bigjacksauto wrote: |
it won't below that section thanks again |
??? _________________ In Stereo, Where Available! |
carcrazed Samba Member
Posted: Thu Dec 06, 2018 4:11 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
Unless something has changed in the past couple of years, I couldn't find them either and had to make my own. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Thu Dec 06, 2018 4:37 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
I used the WW metal referenced above by mukluk. It has to be modified to allow the heater duct to pass through but fit well otherwise. A picture before welding of the left side but same idea.
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9879 Location: Huntington Beach, CA
Posted: Thu Dec 06, 2018 7:28 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
I believe that part goes below the part I am looking for. _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
(o\_!_/o) |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1896 Location: San Fernando Valley, CA
Keith Samba Member
Joined: August 15, 2005 Posts: 3635 Location: Brodheadsville, PA
Posted: Fri Dec 07, 2018 10:29 am Post subject: Re: Sheet metal availability question inside above heater channel an |
I believe that part goes below the part I am looking for. |
This is the part you are looking for on their site. klokkerholm replacement panels are garbage, so if you can find this part from someone else, that would be your best bet. Use the entire part or cut off what you need.
The picture shows it upside down and from the back view.
http://www.klokkerholmusa.com/65-79-rear-cross-member-drivers-side/
http://www.klokkerholmusa.com/65-79-rear-cross-member-passengers-side/ _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
TryToBeOriginal Samba Member
Joined: July 23, 2012 Posts: 266 Location: Georgetown, Texas
Posted: Fri Dec 07, 2018 6:34 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
the part you have circled in your post is definitely the cross member but if you need the part that goes over top of the cross member you need this:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113813111BH
somewhere around here was an amazing exploded diagram of how all these parts meet up. I'll have to see if I can find it. |
Posted: Sat Dec 08, 2018 5:24 am Post subject: Re: Sheet metal availability question inside above heater channel an |
TryToBeOriginal wrote: |
Is this the diagram?
This discussion is also helpful:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Sat Dec 08, 2018 3:14 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
Yup that's the one! I Remember the original thread that was in and the guy restoring the beetle but couldn't remember the name of the thread... It's a shame that beetle sold. |
KnightLife75 Samba Member
Posted: Sun Dec 09, 2018 7:53 am Post subject: Re: Sheet metal availability question inside above heater channel an |
So is the green piece in the pic a separate piece from the cross member? Or is that crossmember repair piece? |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1288 Location: South West (Pa.)
Posted: Sun Dec 09, 2018 10:03 am Post subject: Re: Sheet metal availability question inside above heater channel an |
It's this piece in my included link. It attaches to the outside. When you purchase the crossmember it's already attached. When I did mine I bought the end cap , took the old one off and welded the new one on. It probably added an extra 4 hours of hassle to try and save a few bucks and I was sorry I didn't just buy the cross member. Photo below of when I did mine.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111805091CC
i |
Posted: Sun Dec 09, 2018 6:02 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
Great info, thanks everyone. Time to place another order. _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
(o\_!_/o) |
Posted: Tue Dec 18, 2018 5:50 am Post subject: Re: Sheet metal availability question inside above heater channel an |
My son and are in the process of replacing the crossmember now.
Picture below is not from ours but gives an idea on the gap
First question where the chassis mounting bolt goes through the top crossmember piece then down through the splash panel inner crossmember piece there is approximately 5/16" of an inche gap between both panels.we are considering drilling the tack welds and moving the inner plate a little so that it will be almost flush. What we are finding is that if we bolt down as is the upper piece distorts as it is pulled down . Any one else run into that.only other idea is to weld in some metal between the two?
Second question
How is the heat tube connected as it goes through the crossmwmber.
Any tricks to getting it out before we tackle that?
Third question any torque spec on the 3 bolts on crossmember replacement?
(o\_!_/o) |
Posted: Tue Dec 18, 2018 10:57 am Post subject: Re: Sheet metal availability question inside above heater channel an |
First question where the chassis mounting bolt goes through the top crossmember piece then down through the splash panel inner crossmember piece there is approximately 5/16" of an inche gap between both panels.we are considering drilling the tack welds and moving the inner plate a little so that it will be almost flush. What we are finding is that if we bolt down as is the upper piece distorts as it is pulled down . Any one else run into that.only other idea is to weld in some metal between the two? |
This is the same car after mounting back on the chassis. I didn't notice it at the time but it appears there may be some minor distortion. Test fit and tighten the bolt before you paint.
Second question
Any tricks to getting it out before we tackle that? |
Heater channel goes to -- not through -- the cross member.
Posted: Tue Dec 18, 2018 12:45 pm Post subject: Re: Sheet metal availability question inside above heater channel an |
That looks great.
Definentley testing over and over before fully installing.
I will maybe just shim up inside gap a little _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
(o\_!_/o) |
Posted: Wed Dec 19, 2018 7:58 am Post subject: Re: Sheet metal availability question inside above heater channel an |
Hokie87 wrote: |
Second question
Hokie it looks like the metal compressed down about a 1/4" or so,does that sound about right? Also did you torque it to a certain spec? _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
(o\_!_/o) |
