Trailing arm washer
morgan8899
morgan8899 is offline
PostPosted: Sat Dec 01, 2018 9:58 am    Post subject: Trailing arm washer Reply with quote
I think I know the answer to my question. But. I removed the trailing arms and on the drivers side there were two washers. The passenger side had three. One on the inside and two on the outside.
So does it need three? Do I add a third to the other side? Both sides were fairly loose.
I have the new bushings installed and was planning on installing them today.
jeffrey8164
jeffrey8164 is offline
PostPosted: Sat Dec 01, 2018 10:40 am    Post subject: Re: Trailing arm washer Reply with quote
My 70 only has two on each side. Towards the outside.
(Compression 8.7:1)
https://www.thesamba.com/vw/forum/viewtopic.php?t=696460&highlight=rose
runamoc Premium Member
runamoc is offline
PostPosted: Sat Dec 01, 2018 2:32 pm    Post subject: Re: Trailing arm washer Reply with quote
A 'Bentley' drawing...
Daily driver: '69 Baja owned 39 yrs. Plan B: '81 Rabbit Diesel LS Deluxe
In garage for rehab: '72 Ghia - '71 Beetle - '60 Sandrail
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
Wiring on a VW = It's just wires
didget69
didget69 is offline
PostPosted: Sat Dec 01, 2018 2:37 pm    Post subject: Re: Trailing arm washer Reply with quote
All of my IRS T1s have 2 washers on outside.
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
morgan8899
PostPosted: Sat Dec 01, 2018 7:37 pm    Post subject: Re: Trailing arm washer Reply with quote
That’s what I did. Two washers on the outside. I have a suspicion that the previous owner put in a third washer instead of replacing the bushings.
Thank you for your reply’s.
Olli from NJ
Olli from NJ is offline
PostPosted: Tue Dec 04, 2018 5:25 am    Post subject: Re: Trailing arm washer Reply with quote
I was under my new to me '71 and found that the PO only installed 1 washer and the bolts were loose. Really loose....actually scary loose....
Will I be able to R & R the bolt (washers are ordered) without removing the trailing arm from the spring plate? I will peen the bolt when I re-install it. What is the hole in the bolt for? Is it for securing the bolt somehow?
Olli
runamoc is offline
PostPosted: Tue Dec 04, 2018 6:37 am    Post subject: Re: Trailing arm washer Reply with quote
I will peen the bolt when I re-install it .... Is it for securing the bolt somehow?
Peening the 'collar' into the grooves of the bolt is what secures it. The hole??
Olli from NJ
PostPosted: Tue Dec 04, 2018 10:23 am    Post subject: Re: Trailing arm washer Reply with quote
Here is a link that shows a pivot bolt with the hole through the bolt head. The product description explains its use for safety wire installation.
http://vwparts.aircooled.net/IRS-Diagonal-Arm-Pivot-Bolt-and-Washers-113501535A-p/113-501-535a.htm
Olli
Olli from NJ
PostPosted: Fri Dec 07, 2018 7:58 am    Post subject: Re: Trailing arm washer Reply with quote
I replaced the bolts (with the oem style, grooves on the head) and installed 2 washers per side. Peened the coller into the grooves. I also applied some "tamper lacquer" so I can see at a glance if the bolt moves. Cracked lacquer means it moved.
Olli
