Getting more from a 1600 single port.
Tugmaster
Tugmaster is offline
PostPosted: Thu Dec 06, 2018 8:33 pm    Post subject: Getting more from a 1600 single port. Reply with quote
My 66 has a reman 1600 single port. 30 pict 1 carb, 305t distributer, stock exhaust. I runs good but I would like a little more performance. I live in the mountains of central California. My car is fine on the flat ground but really falls on its face on the hills.
Iíve pulled the plugs and theyíre burning clean. Iím going to do a compression check to verify the condition of the rings and valves.
Iím not a vw expert by any means. What would be some good mods to increase the performance? Better flowing exhaust? dual carbs? Ratio rockers?
I realize with a single port Iím already starting at the bottom of the barrel.
Thanks, Todd
Krochus
Krochus is offline
PostPosted: Thu Dec 06, 2018 9:12 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Turbocharge it.
I have a stock single port making so much torque through the 30pict 3 carb I had to go to a 4 puck clutch disc because the engine could overpower the clutch in 4th gear at anything over 3000 rpm. In a 1400lb rail!
1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
197? Lowered street rail. Single port 1600 GT15 turbo pict30-3 carb Megajolt ignition.
1973 Thing, all stock with a mystery motor.
Danwvw
Danwvw is offline
PostPosted: Thu Dec 06, 2018 9:33 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
As far as normal aspiration goes a lot can be done from making it a 74mm stroke to just adding 88mm slip in p&c's and a W-100 cam and dual Kadrons or something else: 1641 s.p. carb setup
1971 VW Bus Sundial Camper, 1960 VW Beetle, 1988 Porsche 924s
Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? And 1960 Beetle Original 36 Horse And Porsche 924s.
Brian_e
Brian_e is offline
PostPosted: Thu Dec 06, 2018 9:59 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=682243&highlight=flow
Brian
vwracerdave
vwracerdave is offline
PostPosted: Thu Dec 06, 2018 10:00 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
It really depends on what your realistic budget is.
My personal advice is leave it alone and drive it. I won't waste my time and money on a SP engine. Get a dual port 1600 and build to whatever you can afford, then sell the SP engine.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
FreeBug
FreeBug is offline
PostPosted: Fri Dec 07, 2018 12:04 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
I'm reading behind the lines, here, but i get the feeling you want to know about external add-ons you dont need to open the engine case to install...yes?
If you're willing to flycut the heads a little, and maybe work on the cylinders to get a good squish, with twin 34s, an exhaust, a little clean- up and valve job on the heads, a good 1 3/8 header, you would see at least 20% extra power.
The rockers can be a good idea, if you've done head work, but go do it right is quite a hassle, new pushrod length, etc...but if you bring the cylinders in to the block or flycut lots, you'll probably need to do that anyways.
But all that is a lot of buck$ for not that much bang. With a dual- port, a bit more investment,
(splitting the case) you could quite easily double your horses, as suggested above by vwracerdave. That plan is sound.
Kjell Roar
Kjell Roar is offline
PostPosted: Fri Dec 07, 2018 4:22 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
First step is 1:1.25 rockers, more open endpipes (I have TDE's with 28mm int ō instead of 22mm ō original) for better breathing, and then double ICT's. If you want more, you must open the engine.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
gt1953
gt1953 is offline
PostPosted: Fri Dec 07, 2018 7:55 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
What elevation are you running at? I have a 1.6liter single port running at 6500 feet. Pull most grades 6% at 50 mph. I mean it is what it is.
68 type 1
72 type 1
73 type 1
72 Squareback
59 Euro bug, 62, 63, 67, 69 type ones 68 & 69 type two, 68 Ghia all sold
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Dec 07, 2018 8:26 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
So much has been written over the last 50 years and there are proven combinations no guesswork. Why not start with whatís already been shown to work? Iíd start with reading Bill Fisherís book ď How to Hotrod VW EnginesĒ with commentary by Gene Berg. Yes there have been advances in technology and materials since 1970 but the fundamentals never change. There are certain combinations of factory parts which are affordable and work well together.
If you are willing to balance, blueprint and do some cylinder head work you can unlock free horsepower. You could also look at stickies at performance forum. There youíll find countless engine build combos that people have already done. Why not use a known recipe? Damn it Iím repeating myself. Very Happy
What we think we become- Buddha
Bugsy61
Bugsy61 is offline
PostPosted: Fri Dec 07, 2018 10:33 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Here's a thread from a guy that got some spectacular power out of a single port back in 2007. It was cheap too. Mo Looker
http://shoptalkforums.com/viewtopic.php?f=3&t=108808&hilit=single+port
FullFender
FullFender is offline
PostPosted: Fri Dec 07, 2018 10:49 am    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Krochus wrote:
Turbocharge it.
x2
Keep in mind that with more performance you'll have more (possible) problems. You can only get so much out of simple bolt-ons. The best way to learn would be headfirst.
Turbo 1776 Buggy
My TurboCharged 1915cc Build-Thread. Updates soon!
Alstrup
Alstrup is offline
PostPosted: Fri Dec 07, 2018 12:04 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Supercharging or turbocharging a sgl port almost always give good bang for the buck. Especially when living at altitude. If you have a little skills in fabrication it does not have to be that expensive. Just do your homework.
If you feel that is ovewrshooting your desires or skills i can tell you this:
A stock 1600 sgl port puts out just shy of 50 hp (din) at the flywheel, at sea level.
Adding a better exhaust, a set of ICTīs, 32/34 mm Solex or Kads along with a proper distributor. (Peronally I like Solex or Kads best, but the Solex can be a little troublesome to dial in. The Kads are easier.) Such an engine typically makes 60 hp, but the torque increase is rougly 20% across the board with the most gain from 2800 & up. 20% is definitely notice abe and will make your driving experience better. Adding 1,25 rockers on intake alone will increase usable torque another 2-3% plus a couple of hp in the midrange.
This can all be done without taking the engine itself apart.
Whether that is enough for you is the real question.
T
Cusser
Cusser is offline
PostPosted: Fri Dec 07, 2018 12:18 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
I think this is the best overall answer. Especially if you don't have another vehicle for transportation as the engine swap can be done in a day.
Back in 1976 I bought a used 1600cc SP engine and rebuilt it to 1835cc dual port, it has plenty of power for such hills. I use single Weber carb, German 009, quiet exhaust, stock camshaft, stock crankshaft, stock DP heads except opened for the larger cylinders, stock F&S 3-arm pressure plate and disc, stock transmission, Maxi2 pump/filter, external oil cooler.
I haven't had this engine apart in 32 years either, so much for heat issues and unreliability of 1835cc, and I'm in Arizona desert.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
theKbStockpiler
theKbStockpiler is offline
PostPosted: Fri Dec 07, 2018 5:20 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Simple add on's would be High Ratio Rockers , Advance curve and a Header exhaust. You could put a small turbo (insta boost) Laughing on it and limit boost to about 7 pounds which is realitively easy. The rule of thumb is you get 10hp for every pound of boost. That would get you extra low range power to keep the RPM's down. Look into using a (Mod ring) for a blow through turbo set up.
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
oprn
oprn is offline
PostPosted: Fri Dec 07, 2018 6:34 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Like others have said you could spend a lot of time and cash modifying a lot of things and come out with power about equal to a 1600 DP or...
Put a nice little hair dryer on it and double your torque and HP at a lower rpm than you are running now for about 1\3 of the cost of going the other route.
Tugmaster
PostPosted: Sat Dec 08, 2018 6:07 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Wow!lots of good info. Thank you very much. I drive all back roads. Never over 60mph. Iím primarily looking for a little more power on the hills. I was thinking of dual carbs and a better flowing exhaust.
I may just live with what I have for now or look for a decent DP. Thanks again!
PostPosted: Sat Dec 08, 2018 7:05 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
I wonder what they did before dual ports became available. Oh wait there is a vintage speed forum here. Very Happy
vwracerdave
PostPosted: Sat Dec 08, 2018 8:10 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
That is true but in todays parts it is much cheaper to go dual port than to mess with the nostalgia of the SP stuff.
Krochus
Krochus is offline
PostPosted: Sat Dec 08, 2018 8:24 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
But as mentioned above. If you boost it everything else can remain stock and it will absolutely throat stomp all but the wildest dual port n/a below 2000cc builds.
Positive manifold pressure fixes the one thing even spicy NA builds lack. Low and midrange torque. 6 psi at 2800rpm up will make an otherwise stock single port FELL way way faster and more responsive than 120NA hp that you donít get most of till 4000 rpm plus.
oprn
oprn is offline
PostPosted: Sat Dec 08, 2018 10:03 pm    Post subject: Re: Getting more from a 1600 single port. Reply with quote
Our little secret is safe with these guys Krochus! Wink Very Happy
