tsimek2 Samba Member
Joined: September 07, 2017 Posts: 27 Location: High Point, NC
Posted: Sun Dec 09, 2018 6:44 am Post subject: Crankshaft doesn't turn. |
I am a newbie. I am completely rebuilding a 65 type 2 engine.
I have bought new bearing (crank and cam), new crank shaft, new connecting rods and rod bearings.
Everything spins when the case is split. Everything seems to fit fine.
When I put the cases together the crankshaft doesn't want to turn.
Any Ideas?? |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sun Dec 09, 2018 6:50 am Post subject: Re: Crankshaft doesn't turn. |
Swap the old bearings in and see what happens. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Sun Dec 09, 2018 6:57 am Post subject: Re: Crankshaft doesn't turn. |
theKbStockpiler wrote: |
Swap the old bearings in and see what happens. |
Even thought I put a new crank shaft in? When I opened up the case originally the crank shaft was completely sheared.
I'll have to find them, but I'll replace them.
Thank you. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Sun Dec 09, 2018 7:01 am Post subject: Re: Crankshaft doesn't turn. |
ˇBienvenido a la Samba!
A broken crank will thrash the main saddles somewhat, but an align-bore usually cleans it up. Make sure the bearing set shows the correct oversize.
Suggest tearing it open, measure all the main journals & bearings, then report back here.
Might also have an unseated #1 main bearing - look for damage on it's locating pin hole. This kinda goof will lock them up every time:
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Last edited by FeelthySanchez on Sun Dec 09, 2018 7:25 am; edited 2 times in total |
Posted: Sun Dec 09, 2018 7:05 am Post subject: Re: Crankshaft doesn't turn. |
FeelthySanchez wrote: |
Tear it open, measure all the journals & bearings & report back here.
Might also have a misaligned #1 main bearing - look for damage on it's locating pin hole:
I'll do that. It's going to be tough to do it today as I'm in the middle of a snow storm in NC. I will take the measurements.
Thank you |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Dec 09, 2018 7:14 am Post subject: Re: Crankshaft doesn't turn. |
As mentioned above one of the things that occurs most is bearing shell missed the indexing pin and you crushed the bearing on pin during case assembly ... If bearing is crushed, its toast.....
Usually what I do is before setting crank, is set the bearing separate and being sure its seated properly in saddle I mark bearing shell at case line either with felt marker or slight scribe line from sharp blade...IF when setting crank, you do not see the scribe line set properly on case half it means bearing/pin combination is not set properly....
RWK Samba Member
Posted: Sun Dec 09, 2018 8:55 am Post subject: Re: Crankshaft doesn't turn. |
New or reground crank? either way check for straightness had a reground crank once that was bent a little, just enough to prevent easy turning when case bolted together. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
oprn Samba Member
Joined: November 13, 2016 Posts: 12709 Location: Western Canada
Posted: Sun Dec 09, 2018 4:27 pm Post subject: Re: Crankshaft doesn't turn. |
The most common rooky mistake is the locating pin one already mentioned.
However it would be rare in my limited experience for a case to be reusable that has had a crankshaft break in it. Check and measure that case every way to Sunday! |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Sun Dec 09, 2018 7:13 pm Post subject: Re: Crankshaft doesn't turn. |
I wouldn't attempt a rebuild without a known quality line bored used case (rare these days) or a known quality new case. The bearing dowels, crank, bearings themselves etc, should be 100% also. But, start with the case. Otherwise, as Jerry Jeff Walker said, you are "just pissin' in the wind." _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Mon Dec 10, 2018 7:57 am Post subject: Re: Crankshaft doesn't turn. |
Quote: |
Usually what I do is before setting crank, is set the bearing separate and being sure its seated properly in saddle I mark bearing shell at case line either with felt marker or slight scribe line from sharp blade...IF when setting crank, you do not see the scribe line set properly on case half it means bearing/pin combination is not set properly.... |
This method is very easy and effective to notice during assembly.
I've also found that a single dowel pin was slightly too long, so that its tip would press against the inner end of the dowel pin hole in the main bearing slightly. The crank would spin fine when the case was open, but the added pressure of the longer pin would cause a pinch of the bearing against the crank journal and stop the crank from spinning when the case was bolted together and torqued. Took some trial and error to find the actual cause. To fix that, I think I just gripped the dowel pin with vise grips and held the tip to the side of the bench grinder wheel to shorten it about a millimeter.
Ever since then, I take the sliding shaft end of a dial caliper, hold it next to the pin in the case to get the exposed height of the pin, then hold the shaft end into the bearing hole. If the caliper shaft still has some clearance, the dowel pin fit is fine. |
nsracing Samba Member
Posted: Mon Dec 10, 2018 8:30 am Post subject: Re: Crankshaft doesn't turn. |
Reasons for crankshaft not spinning = Pinched bearing/s, or the linebore was too tight, wrong bearings. Unlikely the crank was wrong dimension. Or...the camshaft gear was too big. Or you put the wrong size rod bearings. Or too tight or bottomed out end play.
Now, which one do you think you did? |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Dec 10, 2018 12:22 pm Post subject: Re: Crankshaft doesn't turn. |
nsracing wrote: |
Or a bent crank. Yes, highly unlikely, new crank, but stranger things have happened, and a lot can happen between China and you.
My money is on the case, with the broken crank and all... |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Mon Dec 10, 2018 12:28 pm Post subject: Re: Crankshaft doesn't turn. |
Dale M. wrote: |
Dale |
Do this during the assembly, then also spin the crank as you tighten up the nuts. I tighten the 6 mains and turn the crank during each one at each level of tigthness. Same goes for the 8mm studs and bolts on the exterior case flange.
If at anytime it gets tight, back up and figure out what is happening. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Dec 10, 2018 12:52 pm Post subject: Re: Crankshaft doesn't turn. |
FreeBug wrote: |
nsracing wrote: |
The original crank broke and the current new crank spins on one half but not when the case is together? Then the most likely explanation is that the case twisted causing the bore to be slightly misaligned. Try to install the new cam and cam bearings. If it doesn't turn or is very difficult, then this is it. You will need to have the case align bored(sometimes the same size works but you may have to go up a size) and the cam bore needs to be honed. This is very common when the crank breaks.
Also, double check to make sure the case alignments pins on the corners of the case didn't fall out. If they did, it will have the same effect. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1056 Location: St. Louis
Posted: Mon Dec 10, 2018 3:17 pm Post subject: Re: Crankshaft doesn't turn. |
[email protected] wrote: |
Also, double check to make sure the case alignments pins on the corners of the case didn't fall out. If they did, it will have the same effect. |
To add to Roy's idea about the same size re-align bore, you'd be wise to marker up/Dychem Blue the main bearing bores if you want to try to get away with the same size, just to make sure you aren't cutting heavy on one side of the bore and making an oval hole for one of your mains. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Posted: Mon Dec 10, 2018 5:20 pm Post subject: Re: Crankshaft doesn't turn. |
It's a good idea to back the bar up and run it through twice. Your second pass always takes a whisp off. Possibly from altering the feed path. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Mon Dec 10, 2018 5:27 pm Post subject: Re: Crankshaft doesn't turn. |
Removing and reinstalling an align-bore tool will never cut perfectly on the same center as the original cut.
The original poster said he purchased a new crankshaft... Was it a rebuilt (re-ground) crank? _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
Posted: Mon Dec 10, 2018 7:42 pm Post subject: Re: Crankshaft doesn't turn. |
You don't remove and reinstall it, you just pull the bar back and cut again. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
Posted: Tue Dec 11, 2018 9:42 am Post subject: Re: Crankshaft doesn't turn. |
Dale M. wrote: |
Dale |
I'm pretty sure I misaligned it. That's a good tip for round 2 |
