Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Sat Dec 08, 2018 9:15 am Post subject: Type 4 in a Baja |
Guess I should start with the question: when installing a T4 in a full bodied sedan, does the engine get supported via the engine hanger bar? I don’t know.
But to the point, presuming it does, to what do you anchor the engine bar on a Baja bug? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Sat Dec 08, 2018 9:19 am Post subject: Re: Type 4 in a Baja |
You don’t need a rear hanger. It is nice to have the option of extra support, but it isn’t needed. The four bolts holding it onto the transmission are good enough, same as a Type 1. If you want to fab a rear hanger, you certainly can. That is the nice part about type 4 and type 3 engines, they have a provision for rear support where the type 1 engines do not. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Sat Dec 08, 2018 9:21 am Post subject: Re: Type 4 in a Baja |
I don't think it's necessary, 002/type 2/type 4 transmissions didn't mount the same way as type 1, hence the engine hanger. _________________ foam cowboy hats aren't good helmets. |
Posted: Sat Dec 08, 2018 10:17 am Post subject: Re: Type 4 in a Baja |
Exactly. Many applications of the type 4 had no bell housing mounts. The transmission and engine were hung from the rear engine hanger and the front of the transmission only.
Here is a tip, if you have the transmission solid is mounted, use the stock rubber mounts in the back and preload them slightly for support. Don’t over constrain the assembly by solid mounting at three points. Example, solid nose one mount, solid bell housing mount, and solid rear engine mounts.
If the frame horns are braced well we can get away nicely with solid nose one and bell housing mounts, but adding a third into the mix is just asking for trouble. _________________ 1800 Type 4 Berrien 295
Posted: Sat Dec 08, 2018 8:59 pm Post subject: Re: Type 4 in a Baja |
Thanks much, everyone. Y’all are the best. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
mtnroads Samba Member
Joined: December 06, 2006 Posts: 403 Location: Minkler, CA
Posted: Mon Dec 10, 2018 2:54 am Post subject: Re: Type 4 in a Baja |
lots of pics of this combo in the gallery, here's my old baja with a 2 liter hung on 002 transaxle.
_________________ pax
No Good Deed Goes Unpunished.... |
Posted: Mon Dec 10, 2018 8:03 pm Post subject: Re: Type 4 in a Baja |
Vanapplebomb wrote: |
Which type 4 do you have? |
It’s a 2.0L 914. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue Dec 11, 2018 8:26 am Post subject: Re: Type 4 in a Baja |
Check the heads carefully. The 2.0 914 heads may be the most fragile of any T4 heads. I have yet to see one that is not cracked in either (or both) the combustion chamber around the spark plug boss or inside the exhaust ports. _________________ 1800 Type 4 Berrien 295
Posted: Tue Dec 11, 2018 6:46 pm Post subject: Re: Type 4 in a Baja |
Thanks Van. Will do. My wife has been running this in her 914 and only issue is had was the oil cooler leaking. Compression was good.
She’s got a 2260 now and this one just has to go somewhere. . . . . _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
