When was the change from Door Check Straps to Door Check Rod
Page: Previous  1, 2
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Tue Mar 31, 2015 6:16 pm    Post subject: Reply with quote
Martin Southwell wrote:
A gentle bend before fitting is required, as I've been finding out!
It appears to me that a sharp bend is needed just past the bolts that attach it, then some sweeping curve.
Is this what you have found Martin?
(I'm laughing a bit because my 49 is named Martin too Very Happy )
virtanen
virtanen is offline
PostPosted: Wed Apr 01, 2015 9:38 am    Post subject: Reply with quote
Here an original strap from a late 51 split.
Note the arrow shows the shorter side located the center side of the car.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
nlorntson
Crazy VW Lady
PostPosted: Mon May 28, 2018 8:01 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
Does anyone have a source for the rubber bumper part of the check straps?
virtanen
virtanen is offline
PostPosted: Mon May 28, 2018 9:16 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
I have them.
Mika
New projects
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Tue Dec 11, 2018 1:49 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
nlornston. Thank some of these people that help you once in a while. It's a nice thing to do.....
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
Grant Reiling Premium Member
Samba Slow-Change Artist
Grant Reiling is offline
PostPosted: Tue Dec 11, 2018 3:12 pm    Post subject: Re: front door check rods Reply with quote
ZENVWDRIVER wrote:
i have 2 reliable sources to answer such questions...the first is a 2 book set called the Car of the Century. It covers almost all changes to the type one car from 1930 by serial number. That was compiled and offered through JT Garwood. i got my set in 1993. Are they still available?
i still have my 1952 Zwitter and play with it some. Bought it from my brother in 1993. He bought it in 1972. It is an original Hoffman car shipped to the USA in 1952. i am really into busses now and have 9 form 1960 to 1972. We are doing a 1962 sub hatch with major patina for my 16 yr old son right now. Still have some bugs though...the 52, a 54 complete pan, 62 rag, 63 sedan and a 66 Denmark car. Only the fifty two runs and drives.
My second source is an original VW Type one Spare Parts list in book form. It states on page8-35 that a check rod 111 837 249 left and 250 right were used up to ch no. 1-397022 (9/52)...L & R were the same. and a different one 111 837 251 from ch no. 397023 (10/52) to 929745 (8/55) and yet another 111 837 257 from ch no. 929746.
According to JT Garwood 1951 bodies beginning with ch. no. 1-0220472, standard and deluxe recieved a new black spring steel door check strap replacing the leather type used in 1950...that was the same body that recieved the first Wolfsburg crest and on and on the changes for 51 were listed.
Hope that answers your question.
ZEN.
So mine being Ch. 1-0334 939, (March, '52) - suggests it ought to have the ROD type then right? Question
...I just want to get it correct and memory fails WRT what it has/had prior to body work.
Who can confirm this?
TIA
GRR Arrow
1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water
Splitdog
Splitdog is offline
PostPosted: Tue Dec 11, 2018 3:35 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
No. Strap-type. Until 10-52.
CH³NO²
Z = z² + C
#notacallooker
PostPosted: Tue Dec 11, 2018 5:17 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
OK thanks Jim! Cool
See results at KP2019. Idea Arrow
Happy Holidays,
Grant
Misaru Emoto
Splitdog
Splitdog is offline
PostPosted: Tue Dec 11, 2018 6:47 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
Right on. Cool
CH³NO²
Z = z² + C
#notacallooker
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Tue Dec 11, 2018 7:40 pm    Post subject: Reply with quote
billmetric wrote:
what was wrong with the straps that they needed to be "updated" ? the straps seem to be about the simplest least likely to malfunction door check to me, the rods seem to be overly complicated in comparison, I have seen people selling the rod retrofit kits as NOS in VW wrappers, never knew what the deal was before, Thanks!
The straps eventually torn the body where it rode against the Pilar
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
https://music.youtube.com/watch?v=0-PSeV52tZ4&si=wpcuRnQyvIFo2nCJ
https://music.youtube.com/watch?v=PaCorLXzC5w&si=cbzT8fjlzVlIWfSV
https://music.youtube.com/watch?v=_aoE5aYSutY&si=mkZKPxd_41QA1kfs
https://music.youtube.com/watch?v=_NzUyyVexAE&feature=share
https://music.youtube.com/watch?v=UI8yUrIWS7E&feature=share
PostPosted: Tue Dec 11, 2018 8:40 pm    Post subject: Reply with quote
Interesting. Surprised ...
Was there some kind of sagging or misalignment issue that causes interference with the door slot then?
-'cause I agree with bill metrics' post about the strap-type being the simplest, most fail-safe door check solution. Idea
Were any of you able to determine how it failed, etc.?
I'm obviously curious as this is the direction I've been pointed towards on my car which is at mid-paint stage now> Idea
All input is welcome and appreciated. Cool
Misaru Emoto
WrennMetallWerks
PostPosted: Tue Dec 11, 2018 9:13 pm    Post subject: Reply with quote
From what I have discovered it is the position of the strap coming out of the Pilar. It is fine until the door swings wide open and over the years the strap begins to can opener the slot. Any of you that have a check strap car that is OG would notice it if looked at closely. When we repaired those sections on the 47 we built up the metal between the skin and the inner support so it could take the force of the strap for decades to come. 😎
PostPosted: Tue Dec 11, 2018 9:55 pm    Post subject: Reply with quote
Thanks for your insights Jason, much appreciated.
A bit late for beefing up metalwork now, though perhaps having things freshly renewed will ensure there's little concern (for me as the user) of fatigue or failure. Wink
Happy Holidays!
Grant
Misaru Emoto
virtanen
virtanen is offline
PostPosted: Wed Dec 12, 2018 10:23 am    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
Here pics of a NOS never used opening for door check strap.
Mika
New projects
WrennMetallWerks
PostPosted: Wed Dec 12, 2018 2:56 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
Man dude. Did you just get this? To bad this wasn’t around when I was asking about that area to the readers in the 47 thread.
virtanen
virtanen is offline
PostPosted: Wed Dec 12, 2018 10:02 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
I got it only few weeks ago, sorry.
Mika
New projects
WrennMetallWerks
PostPosted: Wed Dec 12, 2018 10:12 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
No need to apologize bro. Just giving you hard to time
my friend. I am your number one fan when I comes to how awesome you are about help all of us. Very Kool man 😎 please keep it up.
jnr356
jnr356 is offline
PostPosted: Thu Dec 20, 2018 7:58 pm    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
wasn't the change from straps to rods because one piece windows finished?the straps weren't a great design and with vents windows fitted the newer rod design was able to be implemented.
melburgluft.com
australias real aircooled community
Florian84
Florian84 is offline
PostPosted: Thu Mar 31, 2022 10:53 am    Post subject: Re: When was the change from Door Check Straps to Door Check Rod Reply with quote
Hi, I came across this post while looking for parts.
For those who are looking for information, here is the spare parts catalog from September 1950.
Greeting Flo
Page: Previous  1, 2
Page 2 of 2
