Deluxe Trim End caps
bmx2c4me
bmx2c4me is offline
PostPosted: Sat Dec 15, 2018 3:14 pm    Post subject: Deluxe Trim End caps Reply with quote
Are there trim ends with longer tabs or what is the proper means of installing end pieces on the rear hatch?
Home of the Annual Simple Transport Air Cooled shows!
http://www.simple-transport.com
hitest
hitest is offline
PostPosted: Sat Dec 15, 2018 4:12 pm    Post subject: Re: Deluxe Trim End caps Reply with quote
Just so I'm clear- that is a rear hatch strip, right? And not a cut down one? The reason I ask is the end looks to be in great condition- and the mounting screw was installed crooked.
There are varying lengths of the tabs. The shortest ones are on the strip between passenger and cargo door. That tab your holding looks like a repop to me. They are sooo common at swap meets I'm sure you'll find the right tongue length.
Stuff more black trim per foot in the hatch than you did on the driver's side- to allow for shrinkage.
FU#5
j.pickens
j.pickens is offline
PostPosted: Sun Dec 16, 2018 7:05 am    Post subject: Re: Deluxe Trim End caps Reply with quote
Don't think the wide hatch deluxes had the end caps on the hatch trim ends.
BeaterBarndoor wrote:
Red Fau Veh wrote:
PostPosted: Sun Dec 16, 2018 9:15 am    Post subject: Re: Deluxe Trim End caps Reply with quote
They are there on my old low mileage 1964 13-Window.
Hard to see in this photo but you can sort of see the little bent-over "spike" on the edge of the back hatch trim:
Here's a photo from a "trim ends" ad on here, I see a few different styles and hole positions:
bmx2c4me
bmx2c4me is offline
PostPosted: Sun Dec 16, 2018 2:14 pm    Post subject: Re: Deluxe Trim End caps Reply with quote
Got it. Thanks for the info. Why would I assume that an aftermarket item would work without modification?!
