JP6210 Samba Member
Joined: October 14, 2015 Posts: 119 Location: Beaufort, NC
Posted: Sat Dec 15, 2018 9:23 pm Post subject: Weird Turn Signal Help |
Hi All- I am trying to troubleshoot my 76 Westy- having some weird turn signal issues and looking for some direction-
Right turn- blinker light and alternator light come on- no lights blinking on exterior.
Left turn- blinker light comes on, blinks fast and lights on exterior blink fast.
E-flasher- nothing happens when I pull the switch. Have checked all the grounds...I think.
The difference between left and right is what is really confusing me-
Thanks for any help!
JP _________________ '76 Chrome Yellow Westy "Tallula" |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sun Dec 16, 2018 9:36 am Post subject: Re: Weird Turn Signal Help |
weird stuff happens when the hazard switch pops open. zip tie closed after you are sure it has not popped out springs and what not. Reach under the dash and feel the hazard switch box. feel like its still one piece? |
JP6210 Samba Member
Posted: Sun Dec 16, 2018 5:15 pm Post subject: Re: Weird Turn Signal Help |
Eswitch seems ok- nothing obvious open/broken. I did take the opportunity to make sure the connections were solid. Next step for me is to follow the Bentley and do the turn signal switch test, the relay test and the eswitch test. Unfortunately, I have been slowly working through PO hacks in the wiring and trying to bring things back to where they should be- _________________ '76 Chrome Yellow Westy "Tallula" |
Posted: Tue Dec 18, 2018 5:25 am Post subject: Re: Weird Turn Signal Help |
make sure you don't have a wrong type bulb in there somewhere, and your contacts on both bulb and bus are looking good. |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Tue Dec 18, 2018 7:05 am Post subject: Re: Weird Turn Signal Help |
A fast blinker almost always means I have corrosion on a bulb somewhere in my bus. Check and clean all your bulbs, and check the tail light ground connection to the body of the bus (it is on the right side of the engine hatch) This connection gets loose and corroded over time and has the same effect as corroded bulbs.... |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Tue Dec 18, 2018 8:29 am Post subject: Re: Weird Turn Signal Help |
JP6210 wrote: |
JP |
This is fascinating.
a) ignition only, both idiot lights (oil and alt) go on? Do they shut off normally upon starting?
b)) if you turn on the ignition only engine-off, what does the right turn indicator do?
Make a note to yourself that the alt/oil/turn indicator bulb sockets are 12 volts (+) when ignition is on, the wires leaving the bulb holders are the ground path,
Colin _________________ www.itinerant-air-cooled.com |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Tue Dec 18, 2018 11:28 am Post subject: Re: Weird Turn Signal Help |
Check the fuses...I had all kinds of strange things like this going on. They can be hard to see, especially for me...takes lots of light and the strong glasses I wear for watching Matlock. Sometimes those fuses are broken and it's hard to see. Sometimes they look fine but don't work. |
JP6210 Samba Member
Posted: Thu Dec 20, 2018 9:02 pm Post subject: Re: Weird Turn Signal Help |
So...current state:
Have checked all the fuses, and actually replaced with the correct ones in a few cases. Ignition on, pre start, alt and oil lights go on, then out when the engine starts. I still need to check and see what happens with the ignition on and the right signal. But some new symptoms have developed- right turn now blows the fuse. And, while checking I seem to have fried the relay- puff of magic smoke and the lovely Taiwanese relay the PO had in there bubbled and filled my bus with a really unpleasant smell. New, proper relay on the way...
In the meantime, I feel like the turn signal switch itself does not feel smooth- hard to describe other than it feels a bit crunchy- My self cancel function has never worked so I plan on taking it out tomorrow and examining it closely. It passed the Bentley tests, but... And my horn does not work.
And I am still suspicious of the emergency flasher switch- it has not come apart, and passes the Bentley tests, but seems like there are a few failure possibilities there. If the rain stops tomorrow I will trace current per the diagram- I have 12V to the e switch, and from the switch to the relay. Ground checks out at the relay for continuity. I tried jumping the relay, from the white to the other positive contact, in the absence of a relay to continue checking voltages down the line, but that is when the fuse(s) blew.
All of that would seem to point me towards the actual turn signal switch. Maybe... _________________ '76 Chrome Yellow Westy "Tallula" |
JP6210 Samba Member
Posted: Sat Dec 22, 2018 3:26 pm Post subject: Re: Weird Turn Signal Help |
So- turns out crunchy feeling in a turn signal is not a good thing...
Replaced today and cleaned up more connections, replaced a bulb and turn signals and hazard switch are working as they should. Thanks for the suggestions and help!
SGKent Samba Member
Posted: Sat Dec 22, 2018 6:05 pm Post subject: Re: Weird Turn Signal Help |
good work! _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
JP6210 Samba Member
Posted: Mon Dec 24, 2018 10:04 am Post subject: Re: Weird Turn Signal Help |
And one more FYI... I purchased a new emer flasher switch from BD at the same time- the shaft for the original knob, does not fit the new switch- so, either verify the size or order both the switch and the knob, and I would still verify with BD that the two they sell are compatible.
Happy Holidays all-
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Mon Dec 24, 2018 10:47 am Post subject: Re: Weird Turn Signal Help |
orwell84 wrote: |
They can be hard to see, especially for me...takes lots of light and the strong glasses I wear for watching Matlock. Sometimes those fuses are broken and it's hard to see. |
Wow, a flashback to when my grandfather who was legally blind actually used to watch Matlock with his miniature telescope looking thing to see! _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
JP6210 Samba Member
Posted: Thu Jan 03, 2019 11:18 am Post subject: Re: Weird Turn Signal Help |
So- new symptom... Flasher and signals all work as they should. But now when I start the bus the dash indicator blinks and I can hear the relay clicking without the flasher switch or turn signals turned on. It is somewhat sporadic and there are no outside lights flashing when it happens. It does not seem like there s any voltage on the white wire that feeds the flasher relay when it happens. I’m a little stumped. Any ideas or direction would be much appreciated. My limited electrical knowledge says that it must be back feeding from the turn signal switch but the switch is new, and operating correctly. I guess my next step is to see if I can unplug the turn signal switch when it is happening and see if that stops it.
JP6210 Samba Member
Posted: Sun Jan 06, 2019 12:25 pm Post subject: Re: Weird Turn Signal Help |
Hi Folks- bumping this up to see of anyone has any ideas around my turn signal dash light and flasher operating with ignition on but no emergency switch or turn signal on. I have checked the e switch and my turn signal switch is new. Signals, and emergency flashers work as they should and there are no lights flashing on the exterior when this happens. Thanks!
busdaddy Samba Member
Posted: Sun Jan 06, 2019 2:20 pm Post subject: Re: Weird Turn Signal Help |
How big a wattage is your arrow bulb in the fuel gauge?, does it still click constantly if you remove the bulb? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
JP6210 Samba Member
Posted: Sun Jan 06, 2019 4:27 pm Post subject: Re: Weird Turn Signal Help |
busdaddy wrote: |
How big a wattage is your arrow bulb in the fuel gauge?, does it still click constantly if you remove the bulb? |
Hi busdaddy- I will check- I assume, (and I should not), that you mean the TS indicator bulb in the cluster? Or should I be checking something related to the fuel gauge? _________________ '76 Chrome Yellow Westy "Tallula" |
Posted: Sun Jan 06, 2019 4:58 pm Post subject: Re: Weird Turn Signal Help |
Yes, the indicator bulb.
Is there power to the fuel gauge and idiot lights when the key is on?, the flasher could be trying to feed that circuit through the indicator bulb. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
JP6210 Samba Member
Posted: Mon Jan 07, 2019 5:53 am Post subject: Re: Weird Turn Signal Help |
busdaddy wrote: |
Is there power to the fuel gauge and idiot lights when the key is on?, the flasher could be trying to feed that circuit through the indicator bulb. |
Yes- the fuel gauge and oil and alt lights come on when turning the key on- the idiot lights go out when the engine starts. I still need to check the bulb- _________________ '76 Chrome Yellow Westy "Tallula" |
