Rear Apron. Repair options
emersonbiggins
emersonbiggins is offline
PostPosted: Tue Dec 18, 2018 9:38 pm    Post subject: Rear Apron. Repair options Reply with quote
I have searched a couple of times and haven't found a thread that talks about the rear apron repair or replacement with a fiberglass cover.
Do most people just hammer around on them until they are "straight enough"
How are the fiberglass ones? Do they stand up over time.
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Dec 18, 2018 11:23 pm    Post subject: Re: Rear Apron. Repair options Reply with quote
As close as the apron is to the muffler, I would not want a fiberglas part there!
Erik G
Erik G is offline
PostPosted: Wed Dec 19, 2018 9:22 am    Post subject: Re: Rear Apron. Repair options Reply with quote
ehhh, fiberglass and heat are ok, look at all those side pipe corvettes. Glass packs are literally fiberglass packed into a muffler, and all the header wraps / fixes are fiberglass
but I have zero experience with the part in question
bkeith85
bkeith85 is offline
PostPosted: Wed Dec 19, 2018 2:58 pm    Post subject: Re: Rear Apron. Repair options Reply with quote
Mine was pushed in just below the latch. It was probably an inch deep and went out about 10" on each side. I used a dent puller with those pins that you use with a spot weld gun. It took a good week or so of pulling a little at a time, then starting all over with more pins a pulling. You have to start on the outside edge of the dent and work your way in. Once you have pulled on all of them, cut them off and do it again. Over and over. Once it was pretty close to the right shape, I used a shrinking disc to get the high spots down. I still had to use body filler to get it looking right.
Before:
After:
It's hard to see in the after picture, but I'm happy with the results. It still needs some glazing putty to fill some sanding scratches, but I needed to get some primer on it before the Invasion.
I looked into cutting the apron off and straightening it, but that is a job I didn't want. I also had some access to the back of it when I replaced my cargo floor, but I still couldn't get to it enough to knock the dent out. I tried using a 2x4 through the bellows hole when the engine was out, but that probably did more harm than good. It's just a crappy place to have a dent. It's a shame that so many of our cars have one there.
My build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=614323&highlight=
Bobnotch
Bobnotch is offline
PostPosted: Wed Dec 19, 2018 3:05 pm    Post subject: Re: Rear Apron. Repair options Reply with quote
I know I normally bash it into submission, and tweek it how I want it to look like. From what I understand those fiberglass covers are just that a cover. It goes over the existing rear apron.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
