5.5" highbeam glass fell out ... now what?!
geoffraynak
geoffraynak is offline
PostPosted: Wed Dec 19, 2018 2:16 pm    Post subject: 5.5" highbeam glass fell out ... now what?! Reply with quote
stopped at the UPS store today to drop off some holiday shipping ...
came back out to the van in a really windy/sunny winter day
got in the van and hear what sounded like a beer bottle falling ... outside the van
thought it was someone next to me ... or the wind ... or something ... but NEVER expected what it actually was:
the 5.5" high-beam glass on out 4-lens SA grill fell out! right then ... on the pavement ... it is not cracked or damage ... but it is also clearly NOT secure in the housing.
is there a preferred/typical/acceptable way for me to re-secure the bulb onto the body?
any and all help welcome
thanks!
geoff
AZ Landshaper
AZ Landshaper is offline
PostPosted: Wed Dec 19, 2018 2:31 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Silicone not acceptable?
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
Steve Arndt
Steve Arndt is offline
PostPosted: Wed Dec 19, 2018 2:47 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=8324263
Steve
Steve's 87 Syncro project
Gruppe B
Gruppe B is offline
PostPosted: Wed Dec 19, 2018 2:48 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Terry Kay recommended using Goop Silicone stating that it was heat resistant and had excellent bonding characteristics for metal and glass.
Wildthings
Wildthings is offline
PostPosted: Wed Dec 19, 2018 3:09 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
I repaired some holes in my lenses two decades plus back with some kind of goo (likely a clear polyurethane, but maybe silicone?) and it is still doing its job.
geoffraynak
PostPosted: Wed Dec 19, 2018 4:07 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
thanks everyone!
seeing the other 'SA broken headlight' thread ... I'll count my blessings that all I need to do is caulk some high grade exterior silicone
thanks everyone
really do appreciate it!
happy holidays
geoff
DanHoug
DanHoug is offline
PostPosted: Wed Dec 19, 2018 7:38 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Shoe Goop and the variants in the steel roll tubes are a urethane based adhesive. i've used them to repair 'BB' holes in headlight glass and it does not seem to yellow despite years of UV exposure. remained tenacious and strong. most clear silicones will go milky but really there's no reason to NOT use a white on the headlight rim glass. it may have more UV resistance, which the glass somewhat filters anyway. either one is good but for an EXTERNAL crack or hole, i'd use a urethane.
-dan
www.thefixitworkshop.com
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Dec 19, 2018 8:54 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Yes, polyurethane caulk is what you need.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
djkeev
djkeev is offline
PostPosted: Thu Dec 20, 2018 2:46 am    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Manufacturers of Silicone have done a tremendous PR campaign making us think that Silicone is WONDERFUL STUFF!
In reality it isn't.
9 times out of 10 there are better products to use.
Silicone discolors, attracts dirt, and often fails in relatively short order.
Step away from the Silicone and use the better options available.
Dave
Ghia
Vanagon
Beetle
geoffraynak
PostPosted: Thu Dec 20, 2018 11:01 am    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
thanks for the suggestions everyone!
i ended-up goop-ing the glass back in
i removed (with partial success) the original gray adhesive material.
i may have over-gooped ... but i'm pretty sure it is water/snow/rain/dust tight
thanks for all the suggestions
geoff
IdahoDoug
IdahoDoug is offline
PostPosted: Thu Dec 20, 2018 5:30 pm    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
Better check the other one and pull it off as its undoubtedly not far behind based on others exact circumstances.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
geoffraynak
PostPosted: Fri Dec 21, 2018 5:59 am    Post subject: Re: 5.5" highbeam glass fell out ... now what?! Reply with quote
i did indeed check the DS glass
seemed good ...
and will tweak it every now and then in the future to make sure it is not loose
cheers
geoff
