Oil Cooler w/sender
i_luv_my_bus76
i_luv_my_bus76 is offline
PostPosted: Thu Dec 20, 2018 7:27 pm    Post subject: Oil Cooler w/sender Reply with quote
I am building a 1955cc engine AS41 case for my 1970 Fasty...
I was wondering if anyone knows where I can get a cooler sender combo
Bobnotch
Bobnotch is offline
PostPosted: Fri Dec 21, 2018 2:29 pm    Post subject: Re: Oil Cooler w/sender Reply with quote
What kind of sender combo? Oil pressure and idiot light? Or a correct pressure oil light switch?
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
i_luv_my_bus76
PostPosted: Fri Dec 21, 2018 4:56 pm    Post subject: Re: Oil Cooler w/sender Reply with quote
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Dec 21, 2018 5:09 pm    Post subject: Re: Oil Cooler w/sender Reply with quote
Well, you can probably find them separately in the classifieds.
Bobnotch
Bobnotch is offline
PostPosted: Sat Dec 22, 2018 3:04 pm    Post subject: Re: Oil Cooler w/sender Reply with quote
Yup, either set up separately with a "T" or a VDO combo unit from one of the major parts sellers like Air cooled.net or CB Performance.
Tram wrote:
Tram wrote:
Meanman
Meanman is offline
PostPosted: Wed Jan 30, 2019 11:36 am    Post subject: Re: Oil Cooler w/sender Reply with quote
ISP WEST has them
https://www.vwispwest.com/
Critter1
Critter1 is offline
PostPosted: Fri Feb 01, 2019 2:48 pm    Post subject: Re: Oil Cooler w/sender Reply with quote
I think what the OP is looking for is just an original type-3 oil cooler with the sender hole.
Justin
sparkywig
sparkywig is offline
PostPosted: Sat Feb 02, 2019 3:44 am    Post subject: Re: Oil Cooler w/sender Reply with quote
I'm also looking for an oil cooler as well, with little success.
They're obsolete and unless you find a NOS one, not available new anymore, .
The part number is 311 117 021B, a later replacement that is similar and fits T25/Vanagon is 070 117 021A.
I've had a few coolers cleaned, flushed and pressure tested, but not confident enough to fit one to my new build stroker engine.
rusty old nail to sow's ear
Click to view image
Click to view image
gt1953
gt1953 is offline
PostPosted: Sat Feb 02, 2019 7:02 am    Post subject: Re: Oil Cooler w/sender Reply with quote
The items are available, most pre owned. I was fortune enough to clean mine and reuse it. Mine was rather nasty to start with.
after
68 type 1
72 type 1
73 type 1
72 Squareback
59 Euro bug, 62, 63, 67, 69 type ones 68 & 69 type two, 68 Ghia all sold
Critter1
Critter1 is offline
PostPosted: Mon Feb 04, 2019 8:49 am    Post subject: Re: Oil Cooler w/sender Reply with quote
An oil pressure switch can be secured to the case just behind the distributor. Obviously its easier to do during an engine build. Pull the oil galley plug, drill & tap it for the pressure sender. Once this is done, you'll never have to worry about sourcing a Type-3 specific oil cooler. A Type-1 cooler works fine and fits in its place.. just without the sender hole.
Too many people get freaked out about an obsolete part. There's always solutions. In this case, its a factory looking solution.
Justin
