JD1979 Samba Member
Posted: Fri Dec 21, 2018 7:17 pm Post subject: Oil questions |
So I am getting a little frustrated. I checked my oil level and the dip stick showed just a little above first line on dip stick. So I added half a quart and checked oil level seemed good, however car seems to be running rough and heard a noise. Are you supposed to check oil when car is cold? What are indications that I put too much oil in ? Why am I having trouble figuring out if I have correct amount of oil in? Thank you |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Dec 21, 2018 7:31 pm Post subject: Re: Oil questions |
Make sure your car is on a level surface before checking. Also, the engine should be off for at least ten minutes before checking.
Personally, I let the car sit for an hour before checking.
Pull out the dipstick. Pay no attention what the oil level says. Then wipe the dipstick clean and reinsert fully. Take out the dipstick once again and check the level. This is your true reading.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76898 Location: Sneaking up behind you
Posted: Fri Dec 21, 2018 7:34 pm Post subject: Re: Oil questions |
JD1979 wrote: |
What are indications that I put too much oil in ? |
If there's too much it usually gets pissed out past the oil slinger and you'll see it around the crank pulley. _________________ Glenn
Member #1009
#BlueSquare |
Zundfolge1432 Samba Member
Posted: Fri Dec 21, 2018 7:37 pm Post subject: Re: Oil questions |
Deleted
Last edited by Zundfolge1432 on Sat Dec 29, 2018 4:29 am; edited 1 time in total |
JD1979 Samba Member
Posted: Fri Dec 21, 2018 8:09 pm Post subject: Re: Oil questions |
So I did all that added the extra oil then the car seemed to bog down and hesitate. So I just used a vacuum extractor sucked out some oil and now car runs good again. Restested the dip stick and it is below the middle line??? Oh when I i initially did the oil change I used a mechanics gun and set it to 2.5 quarts |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sat Dec 22, 2018 1:59 pm Post subject: Re: Oil questions |
You need to read your Owners Manual that you can access here:
https://www.thesamba.com/vw/archives/manuals/type1.php
Lots of stuff in that you need to know. Only bad advice in it is how to run the engine in too low or high of gear. Most likely to help VW sales against other manufactures of full automatic transmission cars of the time. _________________ In Stereo, Where Available! |
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Sat Dec 22, 2018 4:24 pm Post subject: Re: Oil questions |
I know you said you initially added the correct amount of oil, but just double check the length of the dipstick and or the dipstick tube is correct.
It's happened before. |
Frodge Samba Member
Posted: Sat Dec 22, 2018 9:04 pm Post subject: Re: Oil questions |
Check it first thing in the morning. I’ve had the dipstick level anomaly. I find it gives the most consistent reading before you start it first time of the day. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sat Dec 22, 2018 9:54 pm Post subject: Re: Oil questions |
JD1979 wrote: |
Restested the dip stick and it is below the middle line??? |
Middle line???
All the stock T1 dip sticks I have seen have two lines...
Like these. These are two sticks, one from a 36HP while the longer one is for 1200/1300/1500/1600 :
Here is the thread the pic came from:
https://www.thesamba.com/vw/forum/viewtopic.php?t=284280
Please post a pic of your dip stick and describe where the oil level rests when you insert the clean stick.
What the folks above have been trying to describe is how the dip stick measures the oil level in the crankcase. If your engine has recently been running, some oil is still in the upper areas of the engine and needs some time to drain back down into the bottom of the case.
Also, while the engine is running, oil splashes around inside the case. Some may splash on the dip stick ABOVE the Max line. You need to wipe the stick clean before checking so you are measuring the level of the oil resting in the case and not a false reading. _________________ AshMan40
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Mon Dec 24, 2018 10:41 am Post subject: Re: Oil questions |
Glenn wrote: |
JD1979 wrote: |
If there's too much it usually gets pissed out past the oil slinger and you'll see it around the crank pulley. |
mine just smokes it out,terrible smell oil passing rings. |
Posted: Mon Dec 24, 2018 10:47 am Post subject: Re: Oil questions |
I just add 2.5quarts of oil at oil change stays between the lines ,the reason you pull stick out and wipe it clean is that oill has a tendency of running up on it giving you false reading ,thus wipe repeat |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Mon Dec 24, 2018 11:33 am Post subject: Re: Oil questions |
JD1979 wrote: |
You are having difficulty figuring it out because you do not know the correct procedure.
Running rough may be unrelated to the oil - probably is.
The 'noise' may be unrelated to the oil. What does it sound like and where is it coming from and under what conditions does it happen? _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Mon Dec 24, 2018 9:39 pm Post subject: Re: Oil questions |
I've worked on a few hundred of these engines since the late 60's, and I can't recall engine oil level being the direct cause of a rough running engine. I'd start from scratch on the rough running.
1) Electrical - points, plugs, condenser, rotor button, cap, wires, coil (including 12 V feed wire to the coil)
2) Compression - WOT on warm engine, all plugs removed +/- 10% between all cylinders
3) Fuel - carb adjustment or overall well being of the carb, pump output, clean fuel & filter, no leaks (gasoline or vacuum)
4) Valve train - cold lash set properly.
Dozens of reasons for rough idle or performance, but oil level????? |
JD1979 Samba Member
Posted: Wed Dec 26, 2018 7:47 pm Post subject: Re: Oil questions |
I feel like an idiot rn. So I guess I have that bad of a leak where I lost almost two quarts of oil in a span of 3 weeks I just added about 1.5quarts got the level correct. I hope the noise I heard was not something related to a bearing or something messing up do to low oil. I guess I need to do a compression check now? I did not run it long with low oil but it did happen. So I guess I need to plan on building a new 2200 engine. The frustration is real Because I just did oil change 3 weeks ago and did not think I could lose that much oil. |
Posted: Wed Dec 26, 2018 8:52 pm Post subject: Re: Oil questions |
I have owned 58 different AC VW's since 1971. Many of those had operator's manuals in them, and in one of those manuals, I remember reading, "Check and top off engine oil daily". Seemed a little extreme, but experience tells us all that it's nearly impossible to build an engine from a used case that doesn't leak oil from SOMEWHERE - especially as the engine piles up some use and miles. |
Posted: Wed Dec 26, 2018 9:03 pm Post subject: Re: Oil questions |
JD1979 wrote: |
Is the oil pressure warning light working?? _________________ In Stereo, Where Available! |
JD1979 Samba Member
Posted: Thu Dec 27, 2018 8:21 am Post subject: Re: Oil questions |
Yes, the red light comes on but only flickers sometimes when it is about to stall. It never just stays on. |
Posted: Thu Dec 27, 2018 9:57 am Post subject: Re: Oil questions |
JD1979 wrote: |
If that light stayed off while driving then you should not have had any oil pressure problem.
If it flicked while going around a curve or corner then you should check oil pressure ASAP. _________________ In Stereo, Where Available! |
