86VaNa60N Samba Member
Posted: Sun Dec 30, 2018 8:48 am Post subject: Throttle Body - considering removal to clean |
Hi Samba Family:
My son the other day asked if I've ever cleaned my throttle body in my 86 Vanagon 2WD. Of course no, I've never messed with it. It idles good and has good acceleration. (180,000mi.)
Occasionally, if I don't let it warm up 1 min, it does this thing where I give it gas and it lags and could even die. Usually if I pull over and sit for 1 min, it goes away. Happens 1 out of 50 starts - no big deal. I always thought it was a fuel vacuum lock or something.
I recently purchased a new accelerator cable, a Gowesty Mechanical Throttle position switch, Throttle Body to Intake Plenum Seal and a fancy looking boot coupler to intake. I was considering removing the Throttle bod, cleaning it, replacing the TPS, and slapping on the new cable.
I've watched a couple of YouTube videos on adjusting the TPS (Van-Again And a VW tech training video) and it seems clear. However, I'm starting to think maybe I shouldn't mess with it if it's working good.
Am I opening a can f worms?
Thanks everyone for any wise words.
Happy New Year,
Noah |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Sun Dec 30, 2018 10:16 am Post subject: Re: Throttle Body - considering removal to clean |
Our throttle bodies suffer from wear at the pivot point causing a vacuum leak and and wearing the throttle plate from use. Cleaning it up wouldn't benefit it like cleaning a MAF on a modern vehicle. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Dec 30, 2018 10:42 am Post subject: Re: Throttle Body - considering removal to clean |
No real disagreement with the above though I did remove mine to inspect and clean just because I wanted to examine the wear sometimes warned about.
It seemed fine to me, the bright light test did not reveal any untoward gaps that could not be compensated for with the idle screw.
If you do this you will probably want to have a new gasket in hand (a specific conical shaped thingy) else you may be stalled waiting for parts. |
Posted: Sun Dec 30, 2018 3:30 pm Post subject: Re: Throttle Body - considering removal to clean |
Thanks for the replies
I liked that article on the Waddington effect! Thanks
I'm going to consider this more before jumping into it. Possibly just clean it a little.
Thanks everyone |
Aryana Samba Member
Posted: Sun Dec 30, 2018 3:32 pm Post subject: Re: Throttle Body - considering removal to clean |
Because you have all the parts to do it if you need to, now it will never need it LOL! |
Posted: Sun Dec 30, 2018 9:07 pm Post subject: Re: Throttle Body - considering removal to clean |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Tue Jan 01, 2019 8:11 am Post subject: Re: Throttle Body - considering removal to clean |
Thanks for all the good advice. Since the van is running good, I'll just save this for another time. |
