dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Sun Dec 23, 2018 5:31 pm Post subject: Gear shift |
Hi
Looking for quick gear shift for a RHD 1954 oval with a 30hp engine & original gearbox. Can anyone recommend what would be best & forward a picture if possible.
Thanks for your help |
D-train Samba Member
Posted: Mon Dec 24, 2018 3:10 am Post subject: Re: Gear shift |
Gene berg shifter will do the trick. _________________ shiny paint doesnt make it worth any more |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Tue Dec 25, 2018 6:21 pm Post subject: Re: Gear shift |
I agree that the GeneBerg unit is an excellent product; I've had one in my hand for at least 20 years in my hobby-driving Ghia. But it might be a visual overkill for an otherwise stock oval, with its T-handle, tall metal base and pleated rubber boot. You can achieve the short-throw effect with a good "short shift kit" which uses your stock original shifter. Make sure you spend a few $ more to get the premium aluminum kit, not the hard plastic one. If you paint up the aluminum base base in semi-gloss black, it will not be visually prominent in your interior. http://vwparts.aircooled.net/Quick-Shift-Kit-Standard-Transmissions-p/quick-shift-kit.htm
A high-performance shifter which would not look out of place in your car could be this one- http://vwparts.aircooled.net/Vintage-Speed-Classic-12-Shifter-155-795-52200-p/155-795-52200.htm
Has the benefit of being bent rearward so that you don't have to reach so far forward to get to 3rd gear. The pull-up ring under the shift knob is so that you don't need to push the shifter down when going into reverse.
Both of these shifters, and any aftermarket one, depends on the shift rod bushing in the tunnel just to the rear of the shifter being in good shape. http://vwparts.aircooled.net/Shift-Rod-Bushing-Bee...1-259a.htm |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Dec 25, 2018 6:30 pm Post subject: Re: Gear shift |
Agree on Vintage Speed units, come in black and ivory
Performance with stock appearance |
dave1 Samba Member
Posted: Tue Jan 01, 2019 6:35 am Post subject: Re: Gear shift |
Hi Guys
Thank you for feedback. I have just purchased a gene burg shifter
although for a stock gearbox & 30hp engine it does have the added speedwell supercharger along with some body mods so I think it will be well suited thanks again. |
