spider74j Samba Member
Joined: June 07, 2018 Posts: 1 Location: Winchester NH
Posted: Sun Jan 06, 2019 9:51 am Post subject: Cuting pan for California Clipper |
Everything I have been reading about cutting my chassis has referred to removing 14 1/4" out of the pan. Today, I set my body where it goes at the front, marked a spot on the pan at both sides, then moved the body to the rear, and marked a spot both sides. When measuring mark to mark, I am getting 15 1/4". Does anyone know what is recommended for a California Clipper?? Also I am searching for any paperwork that would have come with these bodies originally. I am building one with my son that has been in my family for about 40 years. Thanks.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sun Jan 06, 2019 11:28 am Post subject: Re: Cuting pan for California Clipper |
Glad to see you and your son working together on your buggy!
You're doing it correctly. Mark and cut the chassis so the body fits, not to a random number. Don't forget the rear bulkhead rail of the floorpan which runs laterally, will also fit under the rear edge of the body tub.
Please make your son wear eye protection when he's cutting steel with a hammer and (wood) chisel.
I believe the California Clipper was one of the Sandwinder family. I believe the maker of the Sandwinder was Don Rountree. His son is still involved with them
https://www.thesamba.com/vw/forum/album_search.php?search_author=Sandwinder2 |
