DanHoug Samba Member
Joined: December 05, 2016 Posts: 4795 Location: Bemidji, MN
Posted: Thu Feb 08, 2018 6:26 am Post subject: Re: Beware of Thermex brand front heater core |
thanks, Dave. looks way better!
on another observation on that core... there was very little flow restriction that i could detect via backpressure on the inlet. it'll be interesting to see how it heats.
-dan |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Thu Feb 08, 2018 7:42 am Post subject: Re: Beware of Thermex brand front heater core |
i'd love to do that! anyone have a new bad core they removed due to no heat they want to send me? it'd be very interesting to see if there are anomalies in the water flow.
-dan |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4097 Location: East Kootenay, British Columbia
Posted: Thu Feb 08, 2018 11:01 am Post subject: Re: Beware of Thermex brand front heater core |
Anyone have an idea of how much water is passing through the heater core while driving? _________________ Currently:
Posted: Thu Feb 08, 2018 11:23 am Post subject: Re: Beware of Thermex brand front heater core |
on an '85 i had, i wanted to increase the front heater output so i added a 12v hot water circulating pump in the line to the front heater. made a dramatic difference in heat. so my short answer would be, "Not Enough".
mind you, this was for a van being driven year round with -30F winter temps.
-dan |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Thu Feb 08, 2018 4:18 pm Post subject: Re: Beware of Thermex brand front heater core |
DanHoug wrote: |
-dan |
If I don't have to send mine back for a refund, I'll send it over. I'm still not sure the test is apples to apples though. Was the flow rate the same? Pressure? _________________ '87 GL w/ Reimo top |
Posted: Thu Feb 08, 2018 4:30 pm Post subject: Re: Beware of Thermex brand front heater core |
dobryan wrote: |
Slimvest wrote: |
If I don't have to send mine back for a refund, I'll send it over. I'm still not sure the test is apples to apples though. Was the flow rate the same? Pressure? |
Right now Dan's test is an apple. He has not tried a Thermex for comparison. |
Maybe I wasn't following all the details, but wouldn't the flow rate/pressure from a garden hose be different from the vanagon cooling system? Or does it matter? _________________ '87 GL w/ Reimo top |
Posted: Thu Feb 08, 2018 4:52 pm Post subject: Re: Beware of Thermex brand front heater core |
as Dobryan says, all i have is just one Apple. no other Apple or Orange to compare with.
that said, the test proved what i wanted it to... namely that there wasn't short circuiting in the core. it distributed incoming hot water nicely over the entire surface, and that is flow rate independent. what we DON'T know is:
- does a proven bad Thermex have the same heat distribution?
- does the reduced fining of this core compared to the stock one reduce heat transfer? (there's more flattened tubes however which increase the Delta T onto the fins)
- does it bleed air as easily as the stock?
i think i have time to start the R&R this weekend. as always, the proof of the pudding is in the tasting. my current heat output sucks... bad foam, old heater core, frickin' mouse nest present observed (and pulled out) thru Mullendore port, locked up fan.
aaaand just to throw another variable in this equation, i'm pulling out my perforated restrictor plate and going to figure out some sort of fresh air flap. or maybe duct tape.
-dan |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Sun Mar 18, 2018 9:54 am Post subject: Re: Beware of Thermex brand front heater core |
Lots of good info here. Thinking of dropping my dash to reseal the heater box to the front cross member and will be replacing the heater core "while I'm at it". _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
boat_builder Samba Member
Joined: July 19, 2007 Posts: 610 Location: Republic of Ireland
Posted: Mon Sep 24, 2018 1:51 pm Post subject: Re: Beware of Thermex brand front heater core |
I'm having the exact same problem over here in Ireland with a new thermex heater matrix.
Blowing cold air and I can't get any more air out or coolant into the system. I've revved it pretty hard and driven about 40 miles and its still stone cold.
Looks like the dash has to come out for a third time!! |
VeeDubDaySpa Samba Member
Joined: February 29, 2008 Posts: 368 Location: Bend, OR
Posted: Sun Dec 09, 2018 7:33 pm Post subject: Re: Beware of Thermex brand front heater core |
This is all very interesting. So does anyone know why GoWesty stopped selling their "new" model??? _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
gbrandt Samba Member
Posted: Mon Dec 10, 2018 6:53 am Post subject: Re: Beware of Thermex brand front heater core |
VeeDubDaySpa wrote: |
This is all very interesting. So does anyone know why GoWesty stopped selling their "new" model??? |
I see it on their website, just not in stock. Is it no longer available? _________________ 'Lucky' our 1987 Red Westy, ASV 1.9 TDI ~130HP, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
Posted: Mon Dec 10, 2018 9:48 am Post subject: Re: Beware of Thermex brand front heater core |
I think there is some confusion here. About two years ago GW started selling an in-house designed core made from brass and aluminum. I have this unit and it seems to work fine. I don't get as much heat as I used to but I also failed to get the heater valve hooked up to the wires correctly and cant open it all the way.
GW stopped selling this particular unit and now sells an off-the-shelf core that is supposed to be better than OEM. _________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
Posted: Wed Dec 12, 2018 10:34 am Post subject: Re: Beware of Thermex brand front heater core |
GW stopped selling this particular unit and now sells an off-the-shelf core that is supposed to be better than OEM. |
Yes this. I called them and the guy I spoke to said that they made one batch of them, then this other version came available. He made it seem like it was more economical for them to sell the one from ?Denmark?
I said, ok Ive heard people are having trouble with heater cores and I wanted to make sure it wasn't a design flaw that stopped the production on the "improved" version - and he said, yeah - we had a handful come back saying that they weren't heating, and he mentioned the flow issue mentioned in this thread...
... I have one I was going to install but now not sure how confidant I am in it... _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Wed Dec 12, 2018 10:40 am Post subject: Re: Beware of Thermex brand front heater core |
The 2 heater hoses that go from engine to the dash are easily access under the middle of the van. You could simply cut them there and splice in your replacement heater core for a stationary test.
Or hook it up in place of the rear heater if that is easier in your vehicle.
Mark
... I have one I was going to install but now not sure how confidant I am in it... |
Posted: Fri Jan 11, 2019 6:12 pm Post subject: Re: Beware of Thermex brand front heater core |
I cut my Thermex one open to see why it wouldn't heat up.
I reckon the gap under the scalloped edge of the divider lets all of the coolant flow in one pipe and directly out the other without being forced through the small passageways at all.
Hence why the pipes feel hot but the core doesn't produce heat.
Foursome vehicle heaters in the UK make a really good heater core. It works great.
Posted: Fri Jan 11, 2019 8:42 pm Post subject: Re: Beware of Thermex brand front heater core |
that's so crazy bad. thanks for cutting one open. _________________ -dan
www.thefixitworkshop.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jan 11, 2019 9:11 pm Post subject: Re: Beware of Thermex brand front heater core |
Ridiculous. You could do better than that with a piece of window screen & a pack of drinking straws...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
