Miked914 Samba Member
Joined: August 18, 2009 Posts: 127 Location: Santa Clarita, CA
Posted: Fri Jan 11, 2019 1:10 am Post subject: Pilot Bearing in Flywheel instead of Crankshaft? |
I've done a few searches and didn't come with an exact answer, so...
I've owned and worked on several T4 914's over the last 25 years but this is my only my second bus and the first one I've worked on.
1973 Bus with stock trans and stock input shaft.
I'm rebuilding my Stock engine (with 96mm p&c's, already from PO)
I have a good running T4 engine that I want to use to keep my bus on the road while doing my rebuild. This engine is from a 914 and came from a T1 to T4 conversion so the flywheel is a Kennedy conversion and not usable. The crank shaft hole is buggered up and clearanced for the T1 trans as the flywheel had the pilot bearing.
My question - Is there any reason I can't just cut the flywheel and put a pilot bearing in a stock bus flywheel and instal this with a stock clutch disc and pressure plate in my bus on the stock trans input shaft?
It looks as though the extra length of the shaft will just ride in the crank end. But will there be clearance problems with shaft and pilot?
TIA guys. _________________ Mike D.
'68 Fastback w/T4
'74 Porsche 914-6 3.0 Hot Rod
'73 TinTop Westy
'13 VW Sportwagon TDI |
Zed999 Samba Member
Posted: Fri Jan 11, 2019 2:20 am Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Can't see a problem doing that. If you are concerned you could cut the end off the input shaft. |
SGKent Samba Member
Posted: Fri Jan 11, 2019 12:42 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
just be aware that stock 2L flywheels are cast iron. It would be rare for a crankshaft to not take a new pilot bearing. Are you sure the old one is removed. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jan 11, 2019 12:43 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Zed999 wrote: |
Thanks, don't what to cut shaft as I'll be going back to original bus crank in the rebuilt engine when the time comes.
I'm going to take my flywheel over to European Motorworks today because I'm afraid of not getting the hole centered if I do it myself... _________________ Mike D.
'68 Fastback w/T4
'73 TinTop Westy
SGKent Samba Member
Posted: Fri Jan 11, 2019 1:13 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Miked914 wrote: |
Zed999 wrote: |
I'm going to take my flywheel over to European Motorworks today because I'm afraid of not getting the hole centered if I do it myself... |
so confuse us. If you have a choice of choosing which crankshaft to use, why not choose one that isn't buggered? I repeat - the stock 2L bus flywheel is cast iron and not forged. Be sure that the machine shop knows that. Some smaller 914 flywheels are forged. Cast iron can shatter when stresses are introduced. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jan 11, 2019 1:48 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
SGKent wrote: |
Miked914 wrote: |
Zed999 wrote: |
so confuse us. If you have a choice of choosing which crankshaft to use, why not choose one that isn't buggered? I repeat - the stock 2L bus flywheel is cast iron and not forged. Be sure that the machine shop knows that. Some smaller 914 flywheels are forged. Cast iron can shatter when stresses are introduced. |
Temp engine is built and running. Not really easy to swap a crankshaft. Original engine is being torn down for a rebuild. I just want to enjoy my bus while I rebuild the original engine.
This engine was going in a 914 where the pilot is in the flywheel. Now I want to use it temporarily in my bus wanted to know if it would cause any problems to put a pilot in a bus flywheel.
I'm pretty sure there is no pilot bearing in there.
'68 Fastback w/T4
'73 TinTop Westy
SGKent Samba Member
Posted: Fri Jan 11, 2019 3:17 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
I would try putting a pilot bearing into it with green Loctite and see if it holds. It looks bad but may still hold a bearing. To be sure I would start looking for a new crank. Make sure you know what the displacement is before you do that. If that is a 914 engine it may only be a 1700 or 1800 instead of a 2L. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Jan 11, 2019 5:58 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Looks like the outer shell of the pilot bearing is still in the crankshaft, just driven inward until it bottomed out in the hole... |
Bleyseng Samba Member
Posted: Sat Jan 12, 2019 11:46 am Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Nah, thats the spacer ring the stops the 914 flywheel bearing from sliding into the crank. Pretty sure all 914 flywheels are forged not cast. Just loctite the bearing in the crank ahter pulling the stop out. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sun Jan 13, 2019 2:03 am Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Porsche and industrial engines had a pilot bushing used as a backup in for when the chintzy pilot bearing failed. Too bad VW didn't do the same, it would have saved a lot of grief over the years. The bushing is seen on the right in this picture:
Posted: Sun Jan 13, 2019 5:32 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
What are you saying??? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Posted: Sun Jan 13, 2019 9:55 pm Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
The buggered up hole isn't exactly round. When I test fit the bearing in the crank it "high sided" on two points in the hole. I will try to get a proper bit in there but I'm afraid of it not being dead center.
HJ - Hey Bleyseng, WCR 50th weeklong event June 2020! _________________ Mike D.
'68 Fastback w/T4
'73 TinTop Westy
Posted: Mon Jan 14, 2019 12:49 am Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
Buy or rent a pilot bearing puller and pop the bushing out of there. If a puller will not grab the bushing you may need to use a small diameter cutter on a Dremel and grind one side of the bushing all the way through and then collapse the remainder of the bushing with a small chisel.
https://www.lowes.com/pd/Dremel-Tungsten-Carbide-C...nkQAvD_BwE |
SGKent Samba Member
Posted: Mon Jan 14, 2019 1:14 am Post subject: Re: Pilot Bearing in Flywheel instead of Crankshaft? |
I compared your photo to the photo of other pilot bearings and you've got something weird there. It is almost like the cavity is partially filled with JB weld or something then a smaller pilot bearing installed. It is already off center as well if the photo is correct.
Images from your thread and TheSamba Gallery.
