Side mirror keeps coming loose
74superTN
74superTN is offline
PostPosted: Tue Jan 15, 2019 5:15 am    Post subject: Side mirror keeps coming loose Reply with quote
So my passenger side mirror keeps coming loose and falling down. If I tighten it too tight it basically just loosens itself so I'm thinking maybe the threads in the door are shot. Any ideas?
73 Thing
80 Vanagon Westy
EDragnDean
EDragnDean is offline
PostPosted: Tue Jan 15, 2019 7:49 am    Post subject: Re: Side mirror keeps coming loose Reply with quote
Do you have the plastic washer between the mirror and the door?
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
74superTN
PostPosted: Tue Jan 15, 2019 8:54 am    Post subject: Re: Side mirror keeps coming loose Reply with quote
I don't. I had to remove it so I could get the mirror to thread the slightest bit in order to stay on. However, if I tighten it anymore than lightly threaded it breaks loose.
73 Thing
80 Vanagon Westy
HMVWNAB
HMVWNAB is offline
PostPosted: Tue Jan 15, 2019 11:56 am    Post subject: Re: Side mirror keeps coming loose Reply with quote
Thing Shop sells the mirror brackets that mount to body. Much more sturdier and can be painted to match.
What are the last 2 words of the National Anthem?
PLAY BALL!
74 Thing
74 Thing is online now
PostPosted: Tue Jan 15, 2019 12:02 pm    Post subject: Re: Side mirror keeps coming loose Reply with quote
Is it an aftermarket mirror-if so it is the screw in base. There is a problem with the aftermarket vs the original the nut and threaded portion do not screw in enough.
Let me see if I can find the thread that has photos for you.
74 Thing
PostPosted: Tue Jan 15, 2019 12:09 pm    Post subject: Re: Side mirror keeps coming loose Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=649494&highlight=side+mirror+thread++nut
In this thread you can see the photos of the original threaded portion and nut vs the aftermarket and see how much deeper the orig should thread in.
There are orig nuts and threaded portions available for sale in the classifieds, or you can run a 16Mx1.5 die down the shaft of the aftermarket mount to create more threads.
EDragnDean
PostPosted: Tue Jan 15, 2019 3:38 pm    Post subject: Re: Side mirror keeps coming loose Reply with quote
You need the washer to get the right tension, otherwise it falls. Thread issue is a stripped door/mirror or aftermarket mirror. Based on the not enough threads, I’m guessing on an after market mirror as others are saying.
