What did you do to your Beetle this week?
Page: Previous  1, 2, 3 ... 284, 285, 286 ... 296, 297, 298  Next
Digger89L
Digger89L is offline
PostPosted: Mon Nov 05, 2018 10:34 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Restored the windshield wiper assembly for my 66 Bahama Blue project car. Disassembled it a while back (after taking LOTS of photos so I'd remember how to put it back together!!) and then ordered some small replacement parts from Wolfsburg West: nylon bushings, some tiny c-clips, rubber grommets, etc. I soaked the parts (except for the motor, of course) in a vinegar / water solution for a couple of days to remove the rust; then wire-brushed them clean; primed them and then painted with semi-gloss Rustoleum black spraycan paint. The re-assembly went fairly smooth (thanks to the reference pics!!) ...only problem was with the 4 nylon bushings: they were VERY tight on the posts, so once I had pressed them into the connecting arms, I had to ream them out with an electric drill and small bit to get them to fit on the pivot mounting posts. I figured if they were too tight it would put undue strain on the 52 year old wiper motor. Now I see what guys charge so much for reconditioned assemblies: all told it took me about 5 hours to complete the work, plus parts costs (not including paint drying time) !!
"If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken."
shano63 Premium Member
shano63 is offline
PostPosted: Thu Nov 08, 2018 3:02 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Took it for an 80 mile run today. Perfect fall day
63 T1 Ragtop Gulf Blue
70 Westy
04 Wrangler Rubicon 5spd
08 Ranger 5spd
08 civic 5spd
Chris
79SuperVert
79SuperVert is offline
PostPosted: Thu Nov 08, 2018 6:15 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Fall tune up. Oil change, valve adjustment, spark plug gapping and cleaning, belt check, dwell gap adjustment, distributor lube, fuel pump screen check, timing, brake adjustment, silly smile test drive. Very Happy
Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun Nov 11, 2018 4:44 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Fixed my 67 backup lights. It was a bugger to see backing up in my driveway in the morning.
Then to celebrate. I took the car for a drive in the country. Cool
Have a great week.
scottyrocks
scottyrocks is offline
PostPosted: Sun Nov 11, 2018 8:10 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Got the bug running properly after 4 months (weekends only) of searching for the problem.
Problem was the condenser, but I had installed the replacement incorrectly, replicating the problem with the first one.
Once I got that fixed, I reset the accelerator pump diaphragm, did an oil change, and now I'm all set for a few weeks of driving before it's put away before the snow.
– D. Tartt, 'The Goldfinch'
MeeferMadness
MeeferMadness is offline
PostPosted: Sat Nov 17, 2018 5:39 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Took my 59 and my beautiful wife out for lunch at DQ and a short drive. Gave the car its first oil change. Must have all of 50 miles on it now!!
BTW what is the easiest way to drain the oil from fan shroud mounted Fram filter on my Okrasa build)
Bruce
Oct 58 Capri Blue sunroof
fjar226
fjar226 is offline
PostPosted: Sun Nov 18, 2018 8:15 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Did a brake job on all 4 wheels ,,changed out the wheel bearing on the front spindles .... things still mto do is install wiper assy, drop the ass 2 inches ,buy and install exhaust
View user's profile Send private message Send e-mail Yahoo Messenger Classifieds Feedback
scottyrocks
PostPosted: Sun Nov 18, 2018 12:33 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
After getting 'er running last weekend, this week I had a starter system failure. Currently in the process of sorting it out.
67_13Deluxe Premium Member
Samba Resident Alien
67_13Deluxe is offline
PostPosted: Mon Nov 19, 2018 7:06 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I gave it new front wheel bearings and grease seals. The weird thing is the driver side is popping my dust cap off. When I removed the drum my grease cap was off and the bearing was stuck on the spindle. I guess I better smooth that out.
Mark.P
Mark.P is offline
PostPosted: Tue Nov 20, 2018 3:50 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I've finished biulding a third cave so I can start my vert resto project
Cave one now houses my 66 spit screen camper ( Gerry )
cave two & three now houses the new project 66 vert that need full resto
OOOOO and by the way this is my first ever post on here ... so hello everyone
REDKAFER
REDKAFER is offline
PostPosted: Sun Dec 09, 2018 8:46 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Alternator issues were giving me a headache, so instead of trying to sort out the integrated regulator I scrapped that and went back to a generator. All sorted and ready to take on the winter. Also, all lights with the exception of the headlights are now LED... HUGE improvement. For anyone thinking about that upgrade, they sell DOT-style flashers that are actually tiny compys for use with LED turn signal lamps. WAY better than wiring in resistors to prevent hyper-flash...
Digger89L
PostPosted: Sun Dec 09, 2018 10:19 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Interesting info, but not very helpful. You need to include lots of details (brand names, sources, etc.). ...just saying....
BarnFine
BarnFine is offline
PostPosted: Mon Dec 31, 2018 4:13 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Bruce
-snip-
Really nice 59 ragtop, excellent work. As for the oil filter question, one method I use for draining oil without making a mess is fashion a drain or funnel out of the side of a cardboard box, it's really easy to fashion and bend how you want it. Then cover and glue down plastic wrap so it's easy to wipe off and reuse.
67ctbug
67ctbug is offline
PostPosted: Mon Dec 31, 2018 4:48 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Not mine, but a buddy’s, learned how to drive stick in a ‘67.
'67 Beetle L41
'71 Westfalia (sold) Sad
'74 Westfalia
‘69 Plymouth
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
likestoparty
likestoparty is offline
PostPosted: Tue Jan 01, 2019 8:17 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I flat-dragged my '60 from Seattle to Dallas... Behind an '81 El Camino. This month is our 20th anniversary together, me and the Beetle. The Beetle did great, it is a previous veteran of a DC-to-Seattle crossing 7 years ago under its own power with zero breakdowns.
I made the towing lights the night before we left out of two Tupperware containers, a Harbor Freight trailer harness, a spare set of pre-62 Beetle tail light assemblies, and two Barbie doll heads as rubber bumpers on the roof.
The El Camino is actually a rarer GMC version badged as a Cabellero with the Amarillo package. I replaced the dumb standard shocks it came with with factory-correct air shocks that really helped with stability back there. My girlfriend and I traded her Honda Civic for it, and that started a murderous 3 months of me suddenly becoming an American car restorer. The right lower ball joint failed on us on our way home from acquiring it, 5 miles into owning it! You haven't lived until you find yourself suddenly grinding a layer of asphalt off of an elevated downtown Seattle waterfront viaduct at 50mph. I fixed that, only to find it devoid of coolant with breaches in both head gaskets. I tore the engine down and fixed THAT myself, too. Helluva introduction to water-cooled cars, man.
Anyway, there's too many little stories to tell here about the 5-day, 2700 mile journey to spin here now, but the most unbelievable was randomly running into my pals in the NYC ska band The Slackers from my days in The Pietasters, in the middle of NOWHERE California!
We made it! Only one pit-stop to replace a worn-out center link in the steering that made navigating through Tacoma, WA hair-raising.
And then I flew back to Seattle 3 days later to make the same trip in our 1980 Dodge TranStar RV, converted into a moving van filled with our belongings. 5400 miles of sheer terror this month!
1960 Beetle - 1600SP - DC-to-Seattle Coast-to-Coast Veteran - Flat towed behind an El Camino Seattle-to-Dallas Dec. 2018. Daily Driven 50 miles every day.
aam76
aam76 is offline
PostPosted: Fri Jan 04, 2019 10:25 am    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Removed more of the old primer to reveal OG paint. Paprika red 1960 Vert.
a.marscapone
a.marscapone is offline
PostPosted: Tue Jan 08, 2019 7:37 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Fixed my driving/fog lights and replaced bulbs with LEDs
kevzo1
kevzo1 is offline
PostPosted: Thu Jan 10, 2019 3:23 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Refurbished the windshield washer switch on my 66
Krink
Krink is offline
PostPosted: Wed Jan 16, 2019 3:38 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
Bought it.
1962 Beryl Green. Needs some TLC and is going to get it. Very Happy
TonyB
TonyB is offline
PostPosted: Sat Jan 26, 2019 9:10 pm    Post subject: Re: What did you do to your Beetle this week? Reply with quote
I put a Bosch Blue Coil and an EMPI distributor with centrifical advance and electronic ignition in this 1972 dual port 1600 and made sure it was working correctly
Then pulled the engine ...
And put it in my '62 Baja Ragtop
I've got dual carbs for it but am waiting for my headers/exhaust to show up before installing them
Page 285 of 298
