mojan_n Samba Member
Joined: February 18, 2018 Posts: 144 Location: Fremont
Posted: Wed Jan 16, 2019 12:02 am Post subject: Rear shock absorbers need replacement ? |
Hi guys,
I was checking my shocks to see if they need to be replaced.
Visual inspection: There is no sign of oil leak on all four.
Bounce test: front shocks are not bouncy at all but both rear shocks are little bouncy when I compare it with fronts.
Dose it mean rear shocks are bad? Or this is normal behavior for a Bug since there is more weight on rear?
Which shock you recommend ( if I need to change the rear shocks)?
1- autozone: Gabriel Guardian Shock
2- autozone: KYB Excel-G Shock
3- Wolfsburg West
Thank you,
Mojan |
Raisedup58 Samba Member
Joined: December 26, 2011 Posts: 263 Location: Pocatello, Idaho
Posted: Wed Jan 16, 2019 6:37 am Post subject: Re: Rear shock absorbers need replacement ? |
Need some info before we recommend shocks.
Is the car stock or lowered?
What year is your car?
What kind of driving are you going to be doing with your car? _________________ L245 Original Paint Light Bronze 1958 Ragtop
L456 Original Paint Ruby Red 1961 Sedan
Orignal Paint Beetle Wheel Collector
Instagram: Raisedup58
VW's At The Springs
facebook.com/vwsatthesprings |
gt1953 Samba Member
Posted: Wed Jan 16, 2019 6:55 am Post subject: Re: Rear shock absorbers need replacement ? |
If the vehicle is stock height you will want an oil filled shock and not a gas type. Autozone does offer lifetime warranty on shocks. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Wed Jan 16, 2019 7:25 am Post subject: Re: Rear shock absorbers need replacement ? |
If the rear end is sagging, consider air-adjustable shocks to raise it while you're at it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Wed Jan 16, 2019 8:20 am Post subject: Re: Rear shock absorbers need replacement ? |
Disconnect the bottom of the shock, push it up, pull it back. All your answers will be revealed. |
Posted: Wed Jan 16, 2019 8:45 am Post subject: Re: Rear shock absorbers need replacement ? |
Raisedup58 wrote: |
What kind of driving are you going to be doing with your car? |
64 stock. Comfort driving.
I have to say the front shocks are KYB are they gas shocks? but the rears are stock type oil shock. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Wed Jan 16, 2019 9:05 am Post subject: Re: Rear shock absorbers need replacement ? |
don1357 wrote: |
Agree here.
You can't really tell unless you unhook or remove one.
I recently replaced the front shocks on my Bus because they were some wacky old ones. They seemed fine but one was clearly bad when I took it off and and pulled it up and down.
The back might be bouncy/bouncier because of the torsion bars.
The front might be less bouncier than normal if it has gas shocks up front.
I agree on oil shocks too - nicer ride from personal experience
Gas shocks up front really suck in my opinion. Harsh ride.
In the rear can be ok as it will sometimes give you a little more control around corners. _________________ How to Post Photos
Posted: Wed Jan 16, 2019 1:23 pm Post subject: Re: Rear shock absorbers need replacement ? |
don1357 wrote: |
Will do that today
So since they are oil shocks when I push it up and pull it back I should feel resistance right? This resistance will tell me shocks are good?
Also oil fill shocks don’t expand on their own? |
Posted: Wed Jan 16, 2019 2:34 pm Post subject: Re: Rear shock absorbers need replacement ? |
mojan_n wrote: |
don1357 wrote: |
Will do that today
All the shocks do is slow things down so you don't hit a pot hole and go bouncing into incoming traffic. When you push, you'll feel resistance but it should travel all the way in. When you pull you should feel resistance but it should travel all the way out. that resistance should be there throughout the entire movement; if the shock has play to it, a few inches of travel before there is resistance, they are bad.
If they are good you can still pull them out and paint them. |
gt1953 Samba Member
Posted: Wed Jan 16, 2019 2:59 pm Post subject: Re: Rear shock absorbers need replacement ? |
The air shocks can ride harsh. If the car is really sagging do consider re indexing the torsion bars. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Wed Jan 16, 2019 7:01 pm Post subject: Re: Rear shock absorbers need replacement ? |
don1357 wrote: |
mojan_n wrote: |
don1357 wrote: |
Will do that today
Yes to what he said above and correct, they do not expand on their own like gas shocks _________________ How to Post Photos
Posted: Thu Jan 17, 2019 12:13 am Post subject: Re: Rear shock absorbers need replacement ? |
Okay, I removed the rear oil filled shocks and tested them they are in a good shape I’m done with rear shocks!
Front:
The only thing bothers me is the front KYB GR-2 shocks, they are in good shape but I want to switch to oil filled shock for a better ride. What is your recommendation on oil filled:
Wolfsburg West oil filled or Cofap Oil Filled? |
Posted: Thu Jan 17, 2019 12:40 pm Post subject: Re: Rear shock absorbers need replacement ? |
Any suggestion:
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
Posted: Fri Jan 18, 2019 8:08 am Post subject: Re: Rear shock absorbers need replacement ? |
I replaced all four of mine (previous owner had installed gas-filled) with the WW models, and have been happy with them. _________________ '66 Beetle |
Posted: Fri Jan 18, 2019 8:40 am Post subject: Re: Rear shock absorbers need replacement ? |
The reality is that type 1s are lightweight cars, the average compact car weighs at least half a ton more. As such they don't tax the shocks that much; anything from a recognizable brand will work just fine. |
