deansplit Samba Member
Posted: Thu Jan 17, 2019 1:05 pm Post subject: Rear track widths - narrowest possible without major mods |
Does anyone know a source of information for this? I need to find out what rear suspension options give the narrowest track width. I'm using a 71 swing axle chassis so that's my limitation. It's to enable me to calculate if my wheels will fit in a 356 coupe build.
Thanks |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Jan 17, 2019 3:27 pm Post subject: Re: Rear track widths - narrowest possible without major mods |
VW published track widths, wheel sizes, wheel base, turning radius, horsepower, weight, etc. in the owner's manual of each car. The technical section here on the Samba has scanned copies of those manuals for most years.
1971 swing axle? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri Jan 18, 2019 8:25 am Post subject: Re: Rear track widths - narrowest possible without major mods |
Thanks Brian, Yes a J reg (UK) which is Aug 70 to July 71.
Had a look, but the Owners manuals you mention only give a basic spec, ie track width, but not lengths of axles themselves...? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Fri Jan 18, 2019 10:51 am Post subject: Re: Rear track widths - narrowest possible without major mods |
So, ideally you would be looking for the drum face to drum face distance of a stock IRS rear. From there, you will likely need to modify things if you need it narrower.
I may have that number written down in the shop. I'll be back. _________________ nothing |
Posted: Fri Jan 18, 2019 11:08 am Post subject: Re: Rear track widths - narrowest possible without major mods |
Sorry, I don't have it. I have split bus, early bay, and late swingaxle beetle, but not an early IRS beetle. I did have a "track width" at 60 3/4", but I think that is to the outside of the rear tires, stock wheel/tires, with engine in. _________________ nothing |
